Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > SMC PENTAX DA 40MM F2.8 LIMITED, Do I have to use the HOOD all the time ?
11-04-2009, 04:53 PM   #1
Hi, I just got my new SMC PENTAX DA 40MM F2.8 LIMITED lens, I have the option to install a 49mm UV Filter without the hood, or a 30.5mm UV Filter with the hood installed.
Do you think it's OK to have the hood always installed in the lens, for indoor and outdoor photos ?, with and without flash ?, or the hood should be used ONLY while doing outdoors photos to avoid issues with the Sun ?, for me the ideal would be to leave the hood installed all the time with the 30.5 UV filter, but I do not know if that will affect some pictures, thanks a lot
brosen is offline
11-04-2009, 05:23 PM   #2
Gallery Photos: 32
Use the 30.5mm filter with hood combination. It works all the time in all situations, looks cool and it doesn't add to the size. Then again, it is your lens and there is nothing wrong with using a 49mm filter too.
creampuff is offline
11-04-2009, 05:25 PM   #3
Thanks, I am not supposed to use both filters at the same time right ?
brosen is offline
11-04-2009, 05:26 PM   #4
Actually, you have a third option--don't use a filter at all. And in my opinion, that's the best option, though others will certainly disagree. Also, I see no reason to shoot with the hood removed. And the hood should provide adequate protection as long as you are reasonably careful and don't make a habit of flinging your camera lens-down onto a concrete surface from a height of 10 feet or more.
Of course, if you're going to be shooting on a sandy beach near rough surf in gale-force winds, I would change my mind about the filter.
MPrince is offline
11-04-2009, 07:05 PM   #5
Gallery Photos: 5
Just screw your hood onto your UV filter. It will work just fine. I also replaced my lens cap with a plastic one from Adorama, just to be certain that I don't lose the one that came with the lens.
Rondec is offline
11-04-2009, 07:08 PM   #6
No need for the filter. The hood keeps anything from hitting the glass already. Just keep a blower handy if you're gonna get dusty.
deadwolfbones is offline
11-04-2009, 07:08 PM   #7
Gallery Photos: 15
The hood always either improves iq or has no effect; filters always either degrade iq or have no effect. Given that the DA40 hood also protects the lnes practically as well as any filter does, and does this wiwithout *ever* harming IQ, the sensible answer is to always use the hood, never use a filter.
Marc Sabatella is offline
11-04-2009, 07:16 PM   #8
The plastic cap you bought from Adorama replaced the small metal that screw in the hood ?, or the one attached to the 49mm filter without the hood ?
brosen is offline
11-04-2009, 07:46 PM   #9
Gallery Photos: 5
I got something like Amazon.com: Adorama 30.5mm Plastic Snap-On Lens Cap: Electronics to replace the metal screw in lens cap. I think other people have used the cap off of a Fuji film canister to replace it as well. Obviously, if you shoot without the hood, you could just use a 49 mm squeeze cap.
I guess I have a great fear of scratching my lenses, whether in the bag, or when shooting and so I use a filter all of the time. The only problem that I have noticed is that it can increase flare in certain situations.
Rondec is offline
11-05-2009, 06:11 AM   #10
For my limited lens, I have decided not to use any filter, as the opening is small for all of them, and the chance of me touching the front element is quite small. Provided that the hood is always on.
I have thought of using filters, but its hard to get high quality 49mm filter, as compared to 77mm or 67mm.
mcjm78 is offline
11-08-2009, 06:44 PM   #11
Lens-cap
u can use JVC Camcorder lens-cap Everio GZ-MC100 (source Japanese web)
that's why JVC want to buy Pentax.
julia is offline
11-08-2009, 11:16 PM   #12
Ah, that explains it!
dave9t5 is offline
11-10-2009, 10:30 AM   #13
Gallery Photos: 7
There has been a lot of debate on whether or not a UV filter needs to stay on your lens all the time. I was using them, mostly out of old habits, and have recently stopped and I have noticed an improvement in the overall IQ of my photos. I use a lens hood all the time.
reeftool is offline
11-10-2009, 11:34 AM   #14
The 49mm option is meant as an option for owners of other Limited lenses which (except the 31) all take 49mm filters. If that's not your case the smaller filter is cheaper.
Other than that a UV filter is not very useful unless you have real reason to fear for the integrity of your lens. I only use polarizers and ND filters.
kristoffon is offline
Wanted: [WITHDRAWN] SMC Pentax-DA 40mm F2.8 Limited thingy Expired Listings 0 11-09-2009 10:00 PM
Pentax SMC-DA 40mm f/2.8 Limited or Sigma AF 50mm f/1.4 EX HSM DG ? Big G Pentax SLR Lens Discussion 8 09-24-2009 04:03 PM
Wanted: [EXPIRED] Pentax SMC P-DA 40mm f/2.8 Limited Sew-Classic Expired Listings 0 07-19-2009 07:57 AM
[EXPIRED] Pentax smc DA 40mm F2.8 Limited f/2.8 tstowell Expired Listings 1 03-06-2009 09:13 PM
40mm 2.8 Limited - Lens hood Antitrust Pentax SLR Lens Discussion 4 09-16-2007 11:47 AM
