Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > B+W Slim CPL + DA Limiteds (15 & 35) - Something's wrong
11-07-2009, 05:35 PM   #1
So today I've bought the DA 15 Ltd and the DA 35 Macro Ltd; I still haven't had a chance to play around with them (tomorrow I will) but I'm quite excited to give them a try.
Anyway, I've come across a small problem and I'd like to hear your advice. Along with the lenses I've bought a B+W Slim Circular Polarizer and I've noticed that I can't extend the lens hood on either of these lenses when the polarizer is on them. With the DA 15 I've even had a scare when it seemed like the filter was stuck in the lens and I couldn't unscrew it (I finally managed, but i would hesitate to screw it again).
So the question is, what is your experience with these lenses and polarizers? Have I got the wrong one? I got a slim to avoid vignetting, the guy in the shop confirmed it was a better choice...
Reading the manual inside the box, it says something about Type A and Type B (I should get a Type B) but the one I have doesn't resemble any of the ones pictured in the manual.
I'm not sure what to do, and I'd appreciate your advice...
gfonso is offline
11-07-2009, 06:27 PM   #2
it's because you got the slim polarizer which doesn't have the front filter threads
b+w will have new polarizers soon with a front filter thread
i think some of the other brands Hoya and Marumi have thin polarizers with a front filter thread
k100d is offline
11-07-2009, 06:30 PM   #3
Indeed, the B+W don't work on the DA15, and I ended up buying a Kenko Pro1 Digital Wideband C-PL(W) instead, which works fine (Same as the Hoya of the same name). While I had hoped to get B+W, the Kenko seem to perform rather well actually and I see nothing wrong with it.
regor is offline
11-07-2009, 06:54 PM   #4
The Marumi DHG Super fit fine and the hood will extend and retract... Obviously on the DA15 you have to retract the hood in order to adjust the CPL...
joele is online now
11-08-2009, 10:37 AM   #5
The rim of the b+w slim filters are wider than usual so they'll prevent u from using built-in hoods. I used b+w metal round hoods on top of the slim filters and did away with the lens caps altogether.
scorpioh is offline
11-08-2009, 11:25 AM   #6
Thanks for all the replies, tomorrow I'll try to return the B+W and get one that works with these lenses, I hope I can find one of the few you've mentioned...
BTW, I've taken these babies for a stroll today and I'm blown away!
gfonso is offline
11-09-2009, 02:59 PM   #7
I've returned the B+W filter today and got a full refund. They were out of Hoyas and hadn't heard of Marumi, but thankfully the next shop had the Kenko Pro1 Wideband CPL which I tried and seemed to work fine, as regor said
Since it was a bit cheaper than the B+W I also got myself a small Cokin Gradual Neutral Gray G1 (wanted darker but they didn't have any left...)
Anyway thanks for all the good advice!!
gfonso is offline
11-09-2009, 10:13 PM   #8
Hopefully you'll like it. I have good result with it and I think it's quite effective. If you have difficulty un-screwing it, use a cloth or elastic band to get a better grip as the rim is very slim and difficult to grab tight.
regor is offline
Wanted: [CLOSED] 49mm 58mm 67mm 72mm UV & CPL photobizzz Wanted Items 0 10-22-2009 09:31 PM
For Sale: [EU:selling worldwide] B&W 67mm SLIM UV MRC 010M Filter celetron Photographic Equipment for Sale 2 10-17-2009 07:47 AM
For Sale: [SOLD] DA & FA Limiteds, F50, 360 flash, ZX-7... and a Canon XT AlbertSiegel Sold Items 11 02-19-2009 06:47 PM
For Sale: [SOLD] 49mm CPL, ND 0.6, & 81A filters hwblanks Sold Items 8 08-03-2008 07:04 PM
[SOLD] FS: DA 50-200mm plus B&W 52mm CPL & UV Filters DavidDor Sold Items 4 04-02-2008 04:22 AM
