Go Back   PentaxForums.com > Photo Galleries > Post your photos! > Photo Critique
Photo Critique Looking for some honest critique and improvements for your photos? Post here!
Old 11-26-2007, 03:37 PM   #1
sajmmiller's Avatar
Curious Doe Repost for Critique
This shot was first posted in the "Post your photos!" section. I decided to reprocess it and repost here hoping to get some additional technical feedback. This version has a more neutral white balance and has been cropped to hopefully provide a bit better composition than the original.
What do you think? Does the white balance look OK? The composition? What else could I do to improve this shot?
Thanks,
Scott
__________________
--Scott
Pentax K10D + Lenses: DA 16-45 F4, DA 18-55mm F/3.5-5.6, DA 50-200mm F/4-5.6 ED
Tamron Lenses: AF70-300mm LD Di Macro 1:2, SP AF90mm F/2.8 Macro 1:1
My Zenfolio Gallery
sajmmiller is offline   Reply With Quote
Old 11-26-2007, 03:52 PM   #2
codiac2600's Avatar
White balance looks fine, colour looks good, sharpness is tack, focus is locked. The only way to improve this image is to reshoot it in the studio LOL.
If you want to spend some time in PS working on this the only fixes would be to clone out that small plant by the left ear of the doe and then use a lens blur effect on the background and foreground to really make it stand out. I'd also boost the contrast a bit to make it pop. Hope that helps and it's a great shot!
__________________
-Chris... your friendly neighborhood Moderator
Pentax K20D & K10D | Pentax LX | Pentax DA* 16-50mm 2.8 | Pentax DA* 50-135mm 2.8 | Pentax FA 50mm 1.4 | Pentax AF540 flash | Pentax AF360 flash | Sigma 28mm 1.8 | Sigma 105mm 2.8 Macro | Tamron 70-300mm Di 4.5-5.6 |
My Website
codiac2600 is online now   Reply With Quote
Old 11-26-2007, 06:07 PM   #3
Gallery Photos: 10
I think the white balance and focus is fine. The deer is looking about ready to bolt.
weatherwise2 is offline   Reply With Quote
Old 11-26-2007, 07:14 PM   #4
sajmmiller's Avatar
Thanks for the confirmation that I'm on the right track with my PP Chris! I was really struggling with the white balance. I think I'll give your PS suggestions a try.
Scott
__________________
--Scott
My Zenfolio Gallery
Old 11-26-2007, 07:24 PM   #5
sajmmiller's Avatar
Thanks for your confirmations on the white balance and focus weatherwise2.
A friend of mine also thought the deer looked quite spooked. The Doe knew I was there at that point, and I think quite curious. And, I have to tell you that she put her her down and started grazing shortly after that shot was taken. It wasn't until about five minutes later when I snapped a twig under my foot that she raised her tail, sounded her alarm, and bolted!
Scott
__________________
--Scott
My Zenfolio Gallery
Old 11-26-2007, 08:15 PM   #6
Tom Lusk's Avatar
Hi Scott-
I missed this photo first time around.
As an avid deer-chaser/photographer, I really like your photo. The pose is great as is the composition.
The only thing that might have improved the photo is if the lighting had been better. Although it may be a case of regional color variation, I've found the white chin and neck patches on the deer in this region to be absolutely bright white.
__________________
Tom Lusk
1000 Islands
Ontario
CANADA
http://www.pentaxphotogallery.com/tomlusk
Tom Lusk is offline   Reply With Quote
Old 11-26-2007, 09:25 PM   #7
SuperJared's Avatar
This photo is lacking tonality variation. Try playing with curves.
__________________
Equipment for sale :: My Photos
SuperJared is offline   Reply With Quote
Old 11-27-2007, 03:17 PM   #8
sajmmiller's Avatar
SuperJared,
Are you saying that it lacks dynamic range? I did try to stretch this version a bit more, and added a bit of an "S" curve, but any more and I'll start losing detail in the deer's white fur and black nose. I guess I really don't understand your comment. Would appreciate some clarification. Thanks!
Tom,
I'm not sure about regional variation with whites on the neck and under the chin. I'll try to pay better attention the next time, assuming I'm lucky enough to get that close again. Maybe the following version is slightly better?
Thanks everyone for all the input. I tried taking everyone's suggestions into account and came up with the following:
__________________
--Scott
My Zenfolio Gallery
Old 11-27-2007, 05:47 PM   #9
SuperJared's Avatar
No, I'm referring to color. brown brown brown.
__________________
Old 11-27-2007, 07:32 PM   #10
sajmmiller's Avatar
Ok, thanks for clarifying SuperJared....hmmm.... I think brown is the "Nature" of the photo. I'm not really sure what to do about it...??...Maybe it would work better if I desaturated the background to black and white, but left the deer in color?
__________________
--Scott
My Zenfolio Gallery
Old 11-27-2007, 09:17 PM   #11
SuperJared's Avatar
After playing with levels and curves using LAB color for about 2 minutes (sorry for the bad compression):
__________________
Old 11-27-2007, 09:37 PM   #12
sajmmiller's Avatar
Thanks for the example!
Scott
__________________
--Scott
My Zenfolio Gallery
