Originally Posted by slowpez
Sweetbay, thanks so much for your comments. I think you are right on about the crop. I will give that a try. The fawn was nursing, I did get a shot of her suckling but mom is turned in the same direction. The doe finally did a bit of fawn grooming as well and those turned out OK.
All my photos seem to lack the spark that others on the forum submit so I appreciate any and all comments.
Again, thanks for commenting, Susan
I think you might have to put a note on your camera not to go above 200mm for a while and learn to use that before you go to 300
The back was cut for a reason, you, just like myself when using zooms (which i never do anymore, get an urge to get as close as possible for the details. I did this all the time. What I have come to realise afterwards is that I got very much details and not very much photos.
Don't try to go for the details only, try to grab some of the enviroment around your subject aswell. Or you will miss alot of good shots. Don't worry, your camera can handle to produce cropable pictures.
I also mentioned this in your other thread, that I wanted more of the surroundings.
Anyways, since this is what we have to work with, I would crop tight around the little one. If you don't have the whole mother, you might aswell make some more steak.
I would probably do something like this (sorry if you mind me using your picture, but its only to help)
