Go Back   PentaxForums.com > Photo Galleries > Post your photos! > Photo Critique
Photo Critique Looking for some honest critique and improvements for your photos? Post here!
Old 07-06-2008, 01:40 AM   #1
m8o
m8o's Avatar
Gallery Photos: 8
The scene I'd been waiting for for a long time ("auto art" from street lighting)
I'd recently made a post about some shots I'd been hoping for, and planning for a long time. You can read about it & the plans & conditions surrounding it here... Been meaning to take this photo for a long time (of one of my cars).
The next evolution of that that I'd been hoping for occurred this evening; I had several spots in NYC in-front of this great colored building all to myself... at least enough spots so no other cars were in the frame. (I did chase one away that wanted to park behind my car... well, chased isn't correct -- I asked nicely and there were plenty of other spots a few dozen feet down the road ) The color on the car is from the reflected neon sign of the Lyric Diner behind & to the right from where I was taking the photos.
I'm posting these in the critique section because I really think they're about the best I can take, and post process. Thoughts, opinions, critiques and/or recommendations? Though, there's a near infinite number of other ways I could post-process the images; there's a fairly limited number of ways I could change the aperture and shutter speed to make a decent pic however.
These are processed 'darker' then in my other post, because I took care to make a note in my head of exactly how my eyes saw it, and these are as best I can remember "true to life" in light balance.
One thing I KNOW, is I need an off camera flash; I plan to get a 540...
(you can click the image to load where I posted the image, then click the link on the bottom of the image to get the full-rez originals if you'd like; well, not "unaltered original", but rather post-processed original )
(that white molding going across @ the car's roof line is actually level, or real close)
What I'm particularly jazzed about is the detail I got @ night-time. Such as the safety glass wire visible in the window behind the security screen that's glowing green. And in the last image, getting the foreground subject detail while still having enough DOF so the painting on the wall, and all the wall texture also in vivid detail. Hey, I'm one to never stop down, but I did tonight ... and this was a night shot!
__________________
Camera: Pentax K10D / Profile: Introducing...Me, on Pentaxforums.com / Pix: The 'm8o Gallery' / Best of m8o In Tanzania '07
Lenses: Pentax 12-24mm DA f/4, Pentax 50mm FA f/1.4 & 50mm A f/1.7, Tamron 28-75mm f/2.8, Voigtländer 125mm f/2.5, Sigma 300mm f/2.8
Other: Sigma 1.4x & 2x TC, Pentax 1.7x AF TC, HyperDrive 120 Gig SPACE
m8o is offline   Reply With Quote
Old 07-07-2008, 03:41 AM   #2
I really like these. I'm not sure what happened to the trees though? They look almost plastic? Did you perhaps use a bit harsh unsharp mask? Or were the lights really strong enough to blow the highlights of the leafs?
Really great shot, I like the second crop the best.
__________________
My Flickr - Takumar forums
PENTAX K10D, Spotmatic
Asahi Auto Takumar 85/1.8 - Asahi Takumar 105/2.8 135/3.5 - Asahi Super Takumar 20/4.5 50/1.4 55/1.8 85/1.9 105/2.8 135/3.5 150/4 200/4 - Asahi S-M-C Takumar 35/3.5 300/4 - Asahi Macro-Takumar 50/4 100/4
Zewrak is offline   Reply With Quote
Old 07-07-2008, 03:56 PM   #3
m8o
m8o's Avatar
Gallery Photos: 8
much thanx for the comment & opinion! I see what you mean. I wouldn't have, and didn't as you can see , consider the leaves.
Surprisingly, I'd say it's not the unsharpen mask. I amazed myself and was very light w/the sharpening. I chose Lightroom's standard "Landscape" sharpening to begin with, which is a level of :
- Amount of 40/150
- Radius of 0.8/3.0
- Detail of 50/100
- & masking of 0/100.
However, I found the electrical conduit (bright silver) going across on the wall just around center frame in the 1st & above center frame in the 2nd had "the jaggies" at that level. So I used that to select an appropriate sharpening level. ...and that left me with
- Amount reduced all the way to 11/150
- I did raise radius to 1.1 - 1.2 which is still really low for smoothness.
- The rest stayed.
I'd have to attribute it to these points:
- That tree's leaves are on the small side with a waxy texture.
- There was an extreme difference in exposure for the leaves getting light from the [seemingly 1000W] spots on the wall above [not totally blowing those leaves, only in some spots, but real close when getting direct light], to little to none on the other leaves w/o a direct line to the light, & I was measuring exposure off the car; mostly off the rear wheel that was only getting ambient light from "the city" [street lights, light from the diner's windows, passing car's headlights on 2nd Ave or turning onto 22nd street right before the exposure completed, notably in the 1st] and from the red neon sign from the diner.
- With the 10 second & 25 second exposures respectively, all the branches (& leaves) had from some smear to a heck of a lot of smear (as you can really see in the 2nd) depending on how much each separate branches moved.
This conspired to smear all leaf detail & make blobs, I guess 'waxy blobs' of all the leaves ....me thinks.
Hm... what can I do? Perhaps two remotely triggered 540 flashes aimed @ the trees, & one @ the car, and a shorter exposure? I fear I'd lose the bg "brightness" then tho...
I bet you'd say the leaves looks better here:
I converted this one too, but didn't post it here. I was going for a darker exposure on the car & wheels, as my eye remembered it, which was the 1st two. The car was a bit brighter here then how my eye saw it, but I do think the leaves do look better here.
__________________
Old 07-07-2008, 04:02 PM   #4
maxwell1295's Avatar
I remember your first post with this setting. This one looks much better with the other cars in the pic. I really like the first one. How long did you have to wait for an opening? Better yet, how long before somebody parked there? Parking spots in Manhattan don't last for very long...
__________________
My Gallery
Pentax DA 35mm Limited|Pentax FA 50mm|Pentax DA 10-17mm|Pentax DA 12-24mm|Sigma EX DG 24-60mm|Pentax DA*50-135mm
maxwell1295 is offline   Reply With Quote
Old 07-07-2008, 04:33 PM   #5
m8o
m8o's Avatar
Gallery Photos: 8
Did you mean to say "much better than with the other cars in the pic"? or do you mean you like it w/the other cars better? I imagine it 's the former, but wanted to check.
That's why we love NYC in the summer... everyone leaves for the Hamptons or Poconos or Catskills, etc., on the weekend I normally/mostly live out on LI, and stay in our NYC place for a few days [usually starting mid-week going into the weekend] anywhere from every few weeks to once in several months ;my wife stays in NYC a bit under half the year so she doesn't have a 2-hr each way commute. But I definitely step-up the time & times I spend in NYC during the summer for this reason.
I parked there Thursday night; Friday was the 4th. The cars left Saturday night. I was out there from around 1am to 3:30'ish am, both times. There was only one time when I had to ask someone to not park behind me, pointing them to either of two spots just ahead. They were very kind and said no problem. ...but that really speaks to just how empty NYC is on a weekend during the summer! Of course, it helps that our NYC place is not in any sort of "night life" area; it's a highly residential area @ the north eastern edge of the Gramercy Park area.
__________________
Old 07-07-2008, 05:09 PM   #6
I meant to say "withOUT the other cars in the pic".
__________________
My Gallery
Old 07-07-2008, 05:17 PM   #7
Gooshin's Avatar
very good colour balance
but if you went through all the trouble of chasing away other people you should have then also removed your front license plate
as i still havent seen a single car that looks good with one on it.
__________________
„¸¨°º¤ø„¸¸„ø¤º°¨ „ø¤º°¨
¨°º¤ø„ OBAMA „ø¤º°¨
¸„ø¤º°¨2008 ``°º¤ø„¸
ø¤º°¨¸„ø¤º°¨¨°º¤ø„¸¨°º¤ø
Gooshin is online now   Reply With Quote
Old 11-03-2008, 09:24 PM   #8
m8o
m8o's Avatar
Gallery Photos: 8
Been whoring this around the picture threads of a few automotive forums I frequent today...
Would have been much better if the building [restaurant, Rolfs] in the background still had its lights on @ 2am, but I guess that's just in the summer. Oh well.
This one was done using the FA50/1.4 @f/8. I don't use that lens enough.
__________________
