Go Back   PentaxForums.com > Photo Galleries > Post your photos! > Photo Critique
Photo Critique Looking for some honest critique and improvements for your photos? Post here!
Old 08-20-2008, 06:45 AM   #1
Mr Hyde's Avatar
Please Help
Please critique this shot. I tried something new. This was taken with an off camera flash. Is the shadowing distracting? Also is the image quality bad? I think I may have cropped this in a bit too tight. Please, some feedback would be greatly appriciated.
__________________
Scott from NJ, USA
Mr Hyde is offline   Reply With Quote
Old 08-20-2008, 07:27 AM   #2
Nesster's Avatar
I don't find the shadow distracting. I also like the bokeh of the feathers.
To my eyes the focus is on the forehead rather than the eye, which is a little problem here - the beak in focus isn't the center of attention in this photo... with a smidge further back focus this would be dynamite.
I'd crop a bit more off the bottom, that leg bleeding off can be cut off. Or alternately, seeing the whole bird might work.
Overall this is an interesting photo, a good flash experiment
Nesster is offline   Reply With Quote
Old 08-20-2008, 07:42 AM   #3
Peter Zack's Avatar
Gallery Photos: 61
I'd agree. The focus point is off slightly and maybe you can increase the DOF by stopping down a little. The flash helps freeze the movement and should let you use a slightly slower shutter speed. The shadow is not really an issue and you could crop a little less. I'd rather see a sharp smaller subject than a close cropped soft subject.
__________________
http://photographyandhowto.blogspot.com/
http://peiweddingphotography.googlepages.com/home
http://www.themesoftime.com/Gallery.aspx
Look and think before opening the shutter. The heart and mind are the true lens of the camera.
- Yousuf Karsh
Peter Zack is offline   Reply With Quote
Old 08-20-2008, 08:20 AM   #4
Mr Hyde's Avatar
Nesster and Peter, thank you very much for your comments and suggestions.
__________________
Scott from NJ, USA
Old 08-20-2008, 08:41 AM   #5
no distracting at all, instead the shadow make it more vivid. But just feel the image quality isn't so clean, a little bit blur.. did u hold the camera firm while taking this one, what about ISO?
lennycheng is offline   Reply With Quote
Old 08-20-2008, 05:18 PM   #6
Lowell Goudge's Avatar
I don't mind the shadow, but more the light right hand side of the photo.
It draws away a little from the subject. I like to use the flash to make the background a little less obvious. Perhaps another F stop down on the lens and slightly different lighting angle?
ALso, I am suprised at lack of deptho of field while using the flash. Hw close were you and what were your settings? I wonder if there is somethign you could have done slightly different to get better depth.
Perrhaps also a different angle?
See the photo below for a shot of a chickadee, using flash. A bit unfair because of my angle of view, directly on the side of the bird. For this, it was flash on camera. Flash off camera is a little limiting for things that move.
http://www.pentaxforums.com/forums/106132-post4.html
Lowell Goudge is offline   Reply With Quote
Old 08-20-2008, 07:58 PM   #7
Mr Hyde's Avatar
Lowell, thanks for the reply. I was using a sigma 50-500 on this shot. I believe thezoom was set at about 450 or so even though the exif data may say otherwise. I remember not cranking it up to 500. Aperature was f/10 with ss of 1/125. I should have been using a tripod but this was taken hand held. The other issue is that I couldnt get close enough to fill the frame with the bird so this is a crop. Not too severe but a pretty good crop from the original.
After looking at the photos you linked to I think I'll try with the flash mounted on the camera. This was an experiment for me and I learned something so I guess it was worth it. What I really need is to find a way to get closer to these birds without scaring them off.
__________________
Scott from NJ, USA
Old 08-21-2008, 04:26 AM   #8
I think the real need is for patience.
With these little birds it is very difficult to get a full frame. I was lucky with the chickadee to some extent.
The shot I posted is about a 10% crop. i.e. I just tightened the framing a little.
Although I was using a manual lens, my apature would have been abot the same I guess, as I was stopped down a couple of stops, and with the TC in use, the result would have been about F11 also. with a flash, hand held is OK, because the flash should freeze the image.
I like the *istD for this because it has excellent results at 400 ISO, and you can generrally stop down and still get results. I am also playing with a better beamer to project the flash futher.
Old 08-21-2008, 01:42 PM   #9
Mr Hyde's Avatar
I have looked at the better beamer and considered investing in one myself. If you get one I'd be interested to see your results.
__________________
Scott from NJ, USA
