Go Back   PentaxForums.com > Photo Galleries > Post your photos! > Photo Critique
Photo Critique Looking for some honest critique and improvements for your photos? Post here!
Old 08-31-2008, 09:35 PM   #1
Dekka's Avatar
How do make this better
Still very much a newbie (have only had my K20 for just over a month now and had never played with an SLR camera before) I have been reading this forum voraciously and *I think, have been getting a small bit better.
I like this pic, but what can I do, or could I have done to make it better?
Dekka is offline   Reply With Quote
Old 08-31-2008, 10:54 PM   #2
Jimbo's Avatar
I like the shot.. but I have been told many times its all about the detail. I noticed the red line between the dogs back legs... may have been better without it.. There is one other thing that I get questioned about on my shots.. [underexposure] This may on been on the edge.. There are a lot of people in this forum that can assist you... Still a great shot. JIMBO
__________________
Camera K10 - Lens: Tamron 18-250mm - Tamron 28-75mm - Tamron 90 MM Macro / Pentax 12-24mm. Pentax 50mm 1.4. Sigma 70-200 2.8. / Sigma 2x Teleconverter..
Jimbo is offline   Reply With Quote
Old 08-31-2008, 11:33 PM   #3
Damn Brit's Avatar
Gallery Photos: 70
Can you give us the exif data please Dekka?
__________________
Gary is my name.
Canadian by adoption eh.
My forum gallery pics here: http://www.pentaxforums.com/gallery/...lbum-5983.html
Damn Brit is online now   Reply With Quote
Old 09-01-2008, 12:18 AM   #4
Taff's Avatar
Hi There
Do you wish to "make it better" in camera or pp
I believe an image is "best" when you are happiest with it, personally I would try levels in photoshop just to brighten it up slightly.
Not knowing what colour the white is in the dogs cheeks makes it hard for anyone but you to get it right
Hope this helps, I am far from expert and there are probably many more here that could help
Taff
__________________
MY FLICKER
K20D, Sigma 70-200 2.8, Sigma 28-90 macro, Sigma 18-50, Sigma 55-200, Pentax m 50mm 2.0, Osawa 28mm 2.8, Bower 80-200 4.5
Taff is offline   Reply With Quote
Old 09-01-2008, 06:52 AM   #5
Dekka's Avatar
I can pp the red out. (might suck at photog stuff but I can manipulate already good pics)
What about the crop?
Any suggestions pp or from taking the pic would be GREAT!
How did you get the exif data? (told you I was a newbie)
Old 09-01-2008, 08:05 AM   #6
pasipasi's Avatar
I'd brighten this up a bit too
__________________
Bodies:K10D (been sent away for fixing), Super Program, Super A, P30T, P3N, SF7, ME Super
Lenses: FA 50mm F1.4, FA 28-70mm F4, A 50mm F1.7, A 28mm F2.8, M 50mm F1.7 x2, M 35mm F2.8, Takumar-M 80-200mm F4.5, A 70-210 F4, Cosina 135mm F2.8, DA 18-55mm
My flickr
pasipasi is offline   Reply With Quote
Old 09-01-2008, 09:15 AM   #7
Dekka's Avatar
So like this?
Old 09-01-2008, 10:15 AM   #8
Jimbo's Avatar
Big improvement on the second one.. JIMBO
__________________
Old 09-01-2008, 10:17 AM   #9
mithrandir's Avatar
I like your post processing adjustments.
__________________
All we have to decide is what to do with the time that is given us.
mithrandir is offline   Reply With Quote
Old 09-01-2008, 10:20 AM   #10
I like the pensive mood of this shot, and The focus is spot on where it need to be.
The negative space to the right is quite prominent, the eyes are drawn to it at the expense of the main subject, suggest cropping at least half off using 6x4. Or if it suit your taste, try an aggressive 5x4 that crop some of the shadow area to the left and that red line between the hind legs.
The image is underexposed with a touch of greenish cast. If you have Photoshop, use a Level layer with Snap-to-neutral option. The snap-to-neutral ought to take care of the greenish cast. Some of the white furs are likely to blow out, use a low opacity brush (say 25%) on the level mask to selectively restore.
I've glossed over a lot of details, PM me if you need more detailed explanation.
song_hm is offline   Reply With Quote
Old 09-01-2008, 04:57 PM   #11
Damn Brit's Avatar
Gallery Photos: 70
Your PP has made it much better but I agree with Song's comments about the greenish cast and crop. A longer exposure would have been better and personally I would have pushed the Fstop a bit more to improve the DOF.
Hey, we are all learning and this forum is one of the best places to learn.
__________________
Gary is my name.
Old 09-01-2008, 08:06 PM   #12
Those are things I have not yet done in photoshop. Most of the time I have played with photos that were already good. (ie not mine) Or didn't matter (ie mine with a point and shoot)
So a further explanation would be great or if you could point me to a tutorial that would be great!
Kerri
Kerri,
This is one way to do it in Photoshop CS2 or CS3:
1) Create a Level Layer using "Layer -> New Adjustment Layer -> Levels...". On the Level dialog, click on "Options" button, select Snap to Neutral Midtones. Press OK twice, the image should brighten up, and green cast eliminated.
2) You should see the Level layer [1] above the background layer. Prepare to eliminate the blown highlights. Click to select the level mask [see 1], the white box should now be double framed. Next select the brush tool [see 2], set the brush size to something small [see 2 at top], here I use 20. Next, set the brush color to black [3]. Finally, set set brush opacity to something low [see 3 at top].
3) With mask still selected (white box double framed), brush away blown out highlight (marked red) directly on the image.
4) Finally crop as desired. Here I chose middle of the road 7x5.
Old 09-01-2008, 08:30 PM   #13
Dekka's Avatar
thanx!! will try that.
