Originally Posted by joelovotti
Thanks.
I agree with your thoughts but I see the best result somewhere between our two tries.
The issue is I don't want to blow out the white fur in his muzzle.
I used a technique from this months Popular Photography magazine and it seems to work nice.
joe
Hi Joe,
I guess it's all about what you want to conceive. One problem with the conversion to B&W is that you have only one "colour" from dark to light instead of a whole palette, and thus a B&W conversion by desaturation only tend to have only little detail. To get the most detail out of your photo, you have to spread the grays all over the dark-light range. Doing this too eagerly will result in blown out highlights and darks without detail in deed. In my opinion, this is not so much of a problem, as long as these areas are limited, and the main subject has enough details.
Back to your photo. The exposure is very good, and you have a lot of space to use the whole dynamic range between light and dark. The chance of loosing detail in the highlights or the blacks is small, if you only push contrast moderately, as I did. Personaly, I would push it even more (probably much more...). The only advise I can give is: try it, and try it into the extremes even. Not to keep the photos, but just for learning. See what happens. It's fun. Give it a try!
And in the meantime: your photo is your photo, and you have to convert it the way you like! And once again, I like this shot very much!
All the best,
Rense
EDIT: Is it just my monitor, or my eyes: has the photo a red haze?
