| Moved to Photo Critique.
First of all, why do you want to crop it, what elements do you want to eliminate from the photograph?
The only thing I can see that you might want to remove is the feeding cup as that identifies the picture as an image of captive animals but it would be hard to crop that out without making the lemurs look squashed in to the frame. Apart from that they fill the frame too much for you to crop on an artistic basis. The diagonal branch helps the composition and even though your subjects are centered, the variety of poses balances it out. I think you already have the best you could get from this one and it's not too shabby.
Try googling composition and rule of thirds. Cropping should be used as fine tuning not a solution. Get the composition right and use cropping to tidy up the edges.
