How to correctly expose birds
Posted by Marc Langille, 07-03-2009, 05:37 PM Marc Langille is offline
These values are based on the sunny 16 rule, shooting in M mode. This is 1 hour after sunrise and 1 hour before sunset.
To photograph brilliant white birds:
Stop down 1 full stop.
(from the correct sunny 16 rule exposure)
For lighter than middle toned birds: Stop down 1/2 stop.
To photograph dark birds: Open up 1/3 to 1/2 stop.
To photograph black birds: Open up 1/2 to 1 full stop.
These are rules of thumb, so some practice will be needed. Shoot AV or M mode to ensure better control and it's a necessity to compensate based on the bird's plumage. Multi-toned birds such as Mallards are tougher to expose correctly.
NOTE: this is not exposure compensation (EV value change). You are actually changing the aperture and shutter speeds to over or under expose the subject.
Regards,
Marc
07-03-2009, 05:47 PM #2
Jimbo
Thanks Marc. JIM
07-03-2009, 07:13 PM #3
dadipentak
Is there an advantage to using aperture r/t EV compensation?
07-03-2009, 07:57 PM #4
Marc Langille
Mainly for depth of field and ensure the background is out of focus. Better to shoot a clean background if possible. Less things to clutter the shot is best.
Let me know if that answers your question?
07-04-2009, 05:52 AM #5
dadipentak
I understand using aperture to control dof but I can easily imagine situations where dof and exposure considerations might conflict so I'd be more inclined to control exposure via shutter speed (or, if reducing exposure, by going to a lower ISO.) What's the downside to that approach?
07-04-2009, 12:04 PM #6
Marc Langille
I don't think there is any issue with your suggestion. Controlling exposure by shutter is only an issue if it might get too low for the conditions or subject you are shooting. Other than that, it's difficult to hit 1/4000 sec. with a moderate aperture setting in bright daylight (at lowest ISO settings and it's pure white).
07-04-2009, 12:32 PM #7
dadipentak
Ok, the bottom line is to under-expose bright white birds but how you get there may depend on a variety of considerations. The guide you provided will be useful, I think. Thanks!
07-04-2009, 02:52 PM #8
SpecialK
"NOTE: this is not exposure compensation (EV value change). You are actually changing the aperture and shutter speeds to over or under expose the subject."
What is the difference?
07-04-2009, 03:43 PM #9
Marc Langille
Normally EV comp is engaged/adjusted simply pressing the +/- button on the back. Note that you are normally adjusting the shutter speed when you modify the EV value, not the aperture.
Manual is directly changing the shutter speed or aperture yourself. I am simply clarifying which method is used to achieve the F stop adjustment. Thus it's a combination of shutter speed and aperture modifications, not just shutter speed.
I've tried EV comp only and had mixed results sometimes. Need to look at that a bit more....
Regards,
Marc
07-29-2009, 01:06 PM #10
tuco
The Sunny 16 rule is a function of the time of year too for cameras with less latitude than others. One of the several cameras I shoot has no light meter built into it at all. So I'm using the S-16 rule all the time.
My experience in low winter sun (Northern hemisphere) is to adjust one-stop. In other words, make it the Sunny 11 rule. But then again, I'm near Latitude 48°N
10-08-2009, 09:43 PM #11
colesf
This would be the perfect situation for either using an incident meter or just taking a spot reading of something close to gray, like grass or pavement. Having to use compensation seems like too much of a workaround, especially if overall lighting conditions are not rapidly changing.
10-08-2009, 10:11 PM #12
Ash
Good guide Marc.
Unless already mentioned, a small point sometimes neglected if trying to shoot in an auto mode (Av/Tv/P etc.): spot metering mode should be used in most cases with focus point at the bird being captured. And the above rules can be applied with reasonable accuracy in getting good exposure.
Formatting Correctly lovemypentax Post Processing, Printing, Software, and Darkroom 4 08-25-2009 09:20 PM
expose to the right? martez81 General Photography - Techniques & Styles 52 06-03-2009 01:58 PM
Expose to the Right: Proper use of the Histogram lastdodobird General Photography - Techniques & Styles 31 02-08-2009 09:24 PM
Expose to the right ... then what? Michael Barkowski Post Processing, Printing, Software, and Darkroom 2 09-22-2008 08:56 PM
Expose ONLY when subject comes into focus. ukbluetooth Pentax DSLR Discussion 6 11-12-2007 08:54 PM
