Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > Levels, sharpening, NS in raw editor or image editor?
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
10-21-2008, 12:42 PM   #1
Hey,
Do you use your raw editor or image editor to perform these tasks? I seem to correct exposure and white balance in my raw editor, then switch to GIMP for adjusting levels/curves, cropping, sharpening, noise reduction and general touch up.
I normally apply more than one round of sharpening, a lot of raw editors only let you apply one unsharp mask.
I was just wondering if this is a good approach, and what you guys do?
EricT is offline
10-21-2008, 12:52 PM   #2
The raw converter I use (UFRaw) does not (yet) offer any sharpening option. I adjust exposure (including curves), white balance and noise reduction (it features a very effective "wavelet" noise-reduction algorithm) in it, then switch to Gimp for additional PP (rotate, clone/heal, etc), cropping/resizing and sharpening.
I will sometimes crop directly in UFRaw, when the original shot was intentionally done with the intent to crop.
RBellavance is offline
10-21-2008, 01:24 PM   #3
Gallery Photos: 22
Originally Posted by EricT View Post
Hey,
I use PPL and I much prefer the tone curve in it to the one in GIMP.
Theoretically, since you are using GIMP, as am I, and it is currently only 8-bit, you should do as much sharpening, NR and colour correction as you can in the RAW converter since you are working with a larger bit-length. This greatly reduces the risk of posterization (banding). For an example see:
http://www.dpreview.com/learn/?/Glos...ization_01.htm
I think cropping can be done just as effectively in either. Not sure about rotation for levelling.
If and when GIMP becomes 16-bit, you should be able to export from the converter in 16-bit TIFF format and do more work afterwards with less problems.
Dan.
dosdan is offline
10-21-2008, 02:06 PM   #4
I do everything in Lightroom 2. The only time I start gimp is to pp other peoples (8bit) photos.
Oh, and to see if they fixed the GUI and added a liquify function...
Don't have PS anymore...
tcdk is offline
10-21-2008, 03:33 PM   #5
Gallery Photos: 28
I use Lightroom for 95% of my PP, except for sharpning and noise reduction. Therefore Bibble Pro works best.
- Bert
bymy141 is offline
10-21-2008, 04:52 PM   #6
Yes, I've tried ufraw, didn't really like the GUI. Currently I use Greysctoration in GIMP for noise reduction. It is also very effective, albeit very complex.
EricT is offline
10-21-2008, 04:55 PM   #7
Thanks for the replies, I guess I should start doing more in my raw editor when possible.
Does anyone know of a raw editor that allows multiple unsharp masks?
EricT is offline
10-30-2008, 11:41 AM   #8
I do everything possible while still in the RAW state and not open the image in a destructive editor until I have done all I can with the RAW editor.
davemdsn is offline
