As said before, with a slight horizontal correction, by tilting just 1.5 degrees counterclockwise, your picture fall into perfect horizontal and vertical lines.
Closely look at the first pic (your original correction) at the true horizontal yellow line. It should pass through the church's windows at the same apparent height. Also, the tower should be parallel to the true vertical line, but its tilted.
On the next picture, correction was just tilting counterclockwise be 1.5 degrees. See how the horizontal and vertical true lines now match the church's lines?
Attachment 26680
