Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > Printing photos from DSLR.....
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
03-10-2009, 05:08 PM   #1
Well I got some really good shots this week taking my kids to the zoo. I am trying to print a few of the photos and when I do, the colors are WAY off. Whites and grays are pink, everything has an orange hue to it; the photos look nice on the screen of the DSLR but the colors are all out of whack when printed. I have an Epson Stylus Photo R200 printer. Is it a setting on my computer (using Picasa), my printer or DSLR? HELP PLEASE!!!!!!
Shawn
shawn474 is offline
03-10-2009, 07:11 PM   #2
How do the colors look in Picasa? Can you test your printing to verify that none of the ink colors are clogged or empty?
AndrewG NY is offline
03-10-2009, 07:44 PM   #3
It could also be that your monitor is out of calibration as well, thus the colors you see on screen are not the colors you monitor is sending to the printer.
jglover is offline
03-10-2009, 08:02 PM   #4
Man this could be anything, this is a VERY tricky process.
I assume you're shooting jpg? First check the colour space and make sure your rpinter is printing in the same space, you should be using sRGB as a starting point.
We'll figure this out but it's gonna take a while.
Alfisti is offline
03-10-2009, 08:04 PM   #5
describe exactly what you do to get from file on the card to print you hold in your hands, so we can try to debug it for you.
monitor calibration can be an issue, but it is unlikely imho, i am rather betting on some color profile used by the printer. to isolate the issue, try to print one picture which came from elsewhere (not your camera, not your processing, not your raw converter), and see if it does the same. you could also try to use auto color balance in picasa, or even better, do white balance automatically using something in the picture you _know_ is white (can picasa do that?), this way you can put the monitor calibration out of the question (because your software does not know what your monitor outputs, all it knows is that, for instance r=g=b=128 means some midle grey, for a random example). you can also try to get a color test chart from the net and print it, see how it comes out. it could well be your monitor calibration, but i honestly doubt it.
nanok is offline
03-11-2009, 04:10 AM   #6
Thanks for all of the replies. I will post the settings and do the printer test when i get home later this week. I appreciate all of the people willing to help.
Take Care,
Shawn
shawn474 is offline
03-11-2009, 05:48 AM   #7
Initially I shot on RAW. Then to test I shot on jpeg (6mp). Both had the same problems when printing. My ink levels are all 1/2 full on the printer. I may try to clean the heads and try again to see if any of the ink heads are clogged. The pictures on the monitor look identical to the ones on the screen of the LCD when reviewing the pictures.
I will post the settings on the camera once I get home. Thanks again for all of your help.
Shawn
shawn474 is offline
03-12-2009, 04:01 PM   #8
Shawn
Whilst not answering your question, sorry, my question is;
Why bother trying to print your photos yourself, what with the cost of proper photo paper and ink?
Why not send the photos to an on-line lab, and let the professionals do the work for you?
I am sure that this would work out cheaper, and with much better results; after all this is what photo labs do for a living.
In the UK, my preferred choice is Truprint.
Regards.
Adrian
bychan is offline
03-12-2009, 04:29 PM   #9
Gallery Photos: 24
From a technical standpoint, it sounds like a printer issue really. Whether it is paper, ink cartridges of the color calibration I am unsure at this time, but monitor and camera LCD can't be both that far off. I'd imagine the camera is just fine, monitor is most likely alright and as a result it sounds like a printer to me.
Do you use brand name ink and matching paper? If you do anything else you are inviting complications like this...
Good luck, let us know what you find out...
Shawn
alderfall is offline
03-12-2009, 04:49 PM   #10
Gallery Photos: 155
I'm moving this to the printing section of Post Processing and Software, hopefully you will find your answers there, look through that forum as well, your question has probably been already answered and it's probably due to calibration or printer profile.
Damn Brit is offline
03-22-2009, 11:36 PM   #11
roy
Gallery Photos: 4
you know??
everyone starts printing thinking you hit the print button and all is well.....
prob is, that's dead wrong... i'd suggest spending about 10 hours minimum reading about accurate printing.. you'll be surprised about what you know nothing about..
roy is offline
03-23-2009, 12:01 AM   #12
Colour profile check?
Clicker is offline
04-03-2009, 05:00 AM   #13
Regards.
Adrian
that is a valid point, however some of us decided they need full control over the end result. it's a matter of choice really. some people also print occasionally, so worrying about DIY printing doesn't make much sense. as far as i am concerned, i have been through this with film (i ended up tooling my own darkroom and spending hours/nights at a time in it to get what i wanted), and with digital, the result for me was the same: i either take control over the whole process, or it's like the lottery. i thought it would be easier (better standardized) with digital, it turns out it is not. of course, your mileage may vary and all that.
nanok is offline
04-05-2009, 08:17 PM   #14
Gallery Photos: 12
It doesn't have to be a lottery. Find a shop where you can talk to the people. Arrive at settings that work then patronize that shop.
graphicgr8s is offline
