Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > C1 (Capture One) v4.7 was released
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
04-02-2009, 03:46 PM   #1
Capture One 4.7 release notes
Introduction
Newly architected Capture One 4 allows photographers to enhance and develop RAW digital files with
excellent color and detail reproduction. Providing best possible image quality is a cornerstone in
Capture One. Tools for this and excellent “out-of-the-box” results are part of the new Capture One 4.
Capture One 4 is designed with an easy workflow in mind, and the simplified new user interface
leaves more of the screen area to your images.
Highlighted new features
This new release of Capture One comes in three versions: 4.7, 4.7 PRO and 4.7 DB.
Capture One 4.7 is a free service release to existing Capture One 4.x owners.
Existing customers with Capture One 3.x can upgrade to a similar version of Capture One 4.7 at no
extra cost.
Capture One 4.7 includes:
- Introduction of new Enhanced Image Package file format (with .eip file extension).
o With the new file format you can combine images and their settings into one file. This
will simplify image archiving and management and make it easier to share adjusted
RAW files (e.g. with retouchers or pre-press). With the new file format your images and
settings are packaged into one file without compromising the original images and
settings. It is always possible to unpack your original images and settings. It is possible
to capture tethered directly to .eip and it is possible to convert existing files into .eip
files. The Enhanced Image Package file format is currently available for Phase One
digital backs only.
- Support for jpeg and tiff files as “input” files.
o It is now possible to make adjustments to jpeg and tiff files similarly to RAW files. The
same* adjustment tools are available for jpeg/tiffs as for RAW files. For optimal image
quality it is recommended to capture and work with images in RAW format.
- Improved quality of P 65+ Sensor+ images
o Notably in high ISO and longer exposure ranges.
- (PRO) Tethered capture support for Canon 5D Mark II and Nikon D3X
- Usability improvements notably for:
o Batch renaming and output naming
o Adjusting numeric input field using keyboard arrows keys
- Windows Imaging Component (WIC) codec and Quick Look plug-in (Mac OS) for Phase
One digital back files:
o The WIC codec and the Quick Look plug-in are imaging components that work on an
operating system level. These additions give you high-quality previews of the original
RAW files at OS level (e.g. in the Finder or Windows Explorer). 3rd party applications
supporting these components will also be able to show the high-quality previews.
Currently Phase One digital back files with .iiq and .eip extensions are supported.
You can learn more about the new release at: Capture One 4
[...... skip...........]
Known issues
Below you will find a list of known issues for Capture One 4.7 at the time of shipping.
General:
- (PRO) Setting the white balance on a connected camera from the Camera tool is supported for
Phase One Digital Backs. It is not available for Canon DSLR cameras.
- The User Guide describes features that might only exist on the Mac platform currently.
- (PRO/DB) Sessions are not cross platform compatible.
- (PRO) For EOS-1D Mark II, EOS-1Ds Mark II, EOS-1D Mark II N: These cameras only support
remote capture via the FireWire port. Clear any messages on the LCD panel of the camera
before connecting the camera, otherwise capturing will be disabled.
- (PRO) For EOS 5D Mark II, EOS 5D, EOS 20D, EOS 350D/Rebel XT: Set the camera’s
communication setting to PC connection or Normal to enable remote capture. Do not use the
Print/PTP or PTP setting.
- Browsing folders containing unsupported image files may affect application performance
- The new feature of transferring rating from a digital back to Capture One is currently only
available for P 65+
- LCC libraries/files generated prior to Capture One 4.5.x are not supported. However it is
possible to create new LCC files from the original LCC images.
- It is not possible to export a DNG from a Leica D-Lux 4 camera.
- Image previews will updated with Capture One 4.7. The first time you access folders with
existing Capture One previews the application performance can be slow
Mac:
- (PRO/DB) When you have disconnected a camera do not reconnect a camera until the
Camera tool status changes to "No Camera Attached".
- (PRO/DB) Do not open the shutter on the camera prior to opening the Live Preview window.
Doing so will generate errors on the digital back after closing the Live Preview window. The
recommended procedure for using Live Preview is to first open the Live Preview window, then
open the shutter on the camera, use Live Preview as desired, when done close the shutter on
the camera, and close the Live Preview window.
- (PRO/DB) Live Preview on the P20, P25, P20+ and P25+: The focus view displays a different
area than that selected by the user in the composition view.
- It is only possible to show the Capture One toolbar in “Icon Only” mode.
Windows:
- (PRO/DB) Library tool cannot be closed or moved from the default tab.
- (PRO) Windows drivers are required for some older models of Canon DSLR cameras to be
able to shoot tethered. These drivers are available from Canon’s web site.
- (PRO) Connecting some Canon cameras to the computer after launching Capture One might
result in tethered capture being unavailable. If you experience this, connect the camera to the
computer prior to launching Capture One.
- (PRO/DB) Live Preview for Phase One P+ digital backs is not supported.
- (PRO/DB) It is not possible to save workspaces.
deejjjaaaa is offline
04-02-2009, 04:00 PM   #2
Gallery Photos: 135
Looks like a good upgrade, have you tried it out yet? Do you have to use the combined file format or can you use it the old way, i wonder if it would affect the raw files. I want to try it, but I might wait to see how others like it.
borno is offline
04-02-2009, 04:02 PM   #3
....The Enhanced Image Package file format is currently available for Phase One digital backs only...
04-02-2009, 05:20 PM   #4
Gallery Photos: 135
Good, I'm going to try it later
borno is offline
04-02-2009, 06:49 PM   #5
there is one important update though (the lack of the said feature was a big issue) - now you can actually invoke C1 from a 3rd party application (like XnView or may be a 3rd party DAM tool) w/ a specific image as a parameter to work on it... before v4.7 it was not possible... I am using XnView a lot, so for me it is a major enhancement...
