Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > Firefox supports ICC profiles
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
04-09-2009, 02:10 AM   #1
but not by default
Expert Advice - Datacolor - Global Leader in Color Management Solutions
Very awesome to have this feature. It means with a calibrated monitor you can see images in firefox how they were intended to be seen, assuming someone made them with calibration.
UPDATE: Site mentions where to change a setting that has been renamed, the setting your looking for is now called
"gfx.color_management.mode;0" change it to '2'
WerTicus is offline
04-09-2009, 05:00 AM   #2
Thanks for posting this. I knew firefox supported this, but didn't know how to turn it on.
MPrince is offline
04-09-2009, 09:26 AM   #3
Gallery Photos: 4
Nice.
Curious now though about gfx.color_management.display_profile
Since I'm running Spyder3 and have calibrated profiles should I be plugging in the path to my Spyder3 generated profile here? Or, will FF figure that out by itself I wonder?
Venturi is offline
04-09-2009, 10:11 AM   #4
Gallery Photos: 4
Well, I plugged it in (figured can't hurt much and easily undone). I'm definitely liking what I see now.
Venturi is offline
04-10-2009, 06:00 AM   #5
yeah its much better with it... seems weird that its off by default really.
the only place profiles dont really work is video overlays, though i dont watch video's on my pc much anyway, but i could calibrate my htpc if it worked there.
WerTicus is offline
04-18-2009, 09:50 AM   #6
WoW! Thanks a lot.
Zebooka is offline
04-21-2009, 06:13 PM   #7
It's off by default because it uses more system resources and to prevent subtle color variations from affecting the overall look of web sites.. Also, it's worth noting that ICC profiles are only supported in the Firefox 3.x releases.
indytax is offline
04-22-2009, 10:05 PM   #8
Gallery Photos: 5
So, how do I turn it on?
hachoo is offline
04-27-2009, 01:16 AM   #9
You just open a new window and type “about:config” in the address bar. After hitting enter, the app will give you a warning, that changing advanced settings is only a good idea if you know what you are doing. Once you’ve confirmed, you’ll get a list of entries. Filter out the ones with the word “color” in them. At the bottom, you’ll find one called “gfx.color_management.enabled”. Simply double-click that line, and the setting in the “Value” column will change from “false” to “true”. Now quit and re-open the app. That’s it! Your Firefox now supports ICC profiles.
10character
ryan s is offline
04-27-2009, 02:36 AM   #10
Yeah i've noticed is massive image heavy threads you can take a performance hit but its not too bad.
WerTicus is offline
10-25-2009, 05:02 PM   #11
this should be stickied or at least the important link at the top put somewhere as a resource for users.
WerTicus is offline
10-25-2009, 05:21 PM   #12
Hummm. I don't have a selection for “gfx.color_management.enabled."
Just:
gfx.color_management.display profile
gfx.color_management.rendering_intent
Anybody know what this is all about?
MacGirl is offline
10-25-2009, 09:01 PM   #13
Same here
gfx.color_management.display_profile;
gfx.color_management.rendering_intent;0
I am using the latest Firefox v3.5.3 (no updates available) and the above 3 are the only GFX settings under color.
Rodney9 is offline
10-25-2009, 09:15 PM   #14
Gallery Photos: 15
I'm guessing those instructions are for an older version. I also see only display_profile,mode, and rendering_intent, but my mode is set to 2 (I don't remember ever changing this before, but that doesn't mean much). I'm guessing the fact that my "mode" is set to 2 means it is enabled for me already. When I visit the site mentioned at the top of the thread, there are a couple sample images designed to test if your browser support ICC profiles, and as far as I can tell, Firefox 3.53 already does (the word "red" is already red, etc). Do other people see something different?
Marc Sabatella is offline
10-25-2009, 09:27 PM   #15
I see the word Red in blue colour.
I see the word Blue in green colour.
I see the word Green in red colour.
Rodney9 is offline
