Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > No exif in PSE 'save for web'
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
04-19-2009, 10:02 AM   #1
Gallery Photos: 7
So I recently switched from Picasa to PSE 7... In PSE your original is saved to your hardrive, the edited photo is saved in a PS file or Jpeg, then I want to resize for web to post to the forum... When I use the 'save for web' I lose the Exif...
How do I resize to a 900 x 600 pixel web size photo and retain exif?
Igilligan is offline
04-19-2009, 10:12 AM   #2
Gallery Photos: 7
So I recently switched from Picasa to PSE 7... In PSE your original is saved to your hardrive, the edited photo is saved in a PS file or Jpeg, then I want to also resize for web to post to the forum... When I use the 'save for web' I lose the Exif...
I feel like and idiot have to ask this.... but how do I resize to a 900 x 600 pixel web size photo and retain exif?
04-19-2009, 10:17 AM   #3
Gallery Photos: 9
Forum posting workflow
I do:
  • Before resizing I save the PP'ed file as named, then
  • Image >> Resize >> 800 at largest dimension (width or height) and preserve aspect ratio.
  • Immediately before saving I do a slight Unsharp Mask
  • File >> Save As >> [imagename.800.jpg]
    • I usually change the name to preserve the full-sized version
  • Upload that file to pbase
  • Link from pbase to PentaxForums.
I don't use Save for Web. EXIF is almost always attached.
monochrome is offline
04-19-2009, 10:48 AM   #4
Save for web strips the EXIF. You can make an action in PSE (I presume it supports actions) to make the resize a one button operation, and then, as Monochrome says, use the Save As.
For myself, the picture is more important than the EXIF data, so I use Save for Web.
Wheatfield is online now
04-19-2009, 11:08 AM   #5
This idiot here is getting in line behind you to wait for the answer. It was SOOOO irritating to seemingly lose the exif data.
pardes is offline
04-19-2009, 11:31 AM   #6
Gallery Photos: 60
I think the solution is to "Save As" and do the sizing there. I only have 6, and only use that as an external editor to Lightroom, so my "help" is worth exactly what you paid for it.
Canada_Rockies is offline
04-19-2009, 01:01 PM   #7
Yep, PS does the same thing. If you want the exif data available you have to "Save As" and pick a jpeg quality there.
Since I've never worried about the exif data I just use the "Save for Web" option because it's easier & I'm lazy.
bimjo is offline
04-22-2009, 06:52 PM   #8
Gallery Photos: 11
Hi Gus!
When you use "save for web", the EXIF data is stripped out. This save option is used to shrink the file size to the absolute minimum so it can be rendered on the web quickly. Even though the EXIF data is not huge, for this option, every little bit of space helps, so out it goes. Consider the "save for web" option the one you pick when creating thumbnails for a web page.
Canada-Rockies is right...use "save as" and your EXIF data should remain in tact.
navcom is offline
04-22-2009, 07:27 PM   #9
Gallery Photos: 15
This is pretty much a holdover from the days of slow dialup Internet connections, when the small amount of extra space meant several seconds of waiting per picture. It's pretty silly today.
Marc Sabatella is offline
04-22-2009, 07:32 PM   #10
yep, it should be an option.
HGMonaro is offline
04-22-2009, 08:06 PM   #11
It is an option.
04-22-2009, 08:08 PM   #12
Gallery Photos: 4
If you use a photohosting site that does resizing you can go that route. After PP'ing I save as a "10" level JPEG, usually keeping the same filename with the .jpg extension. I then just upload to my Smugmug account and then if I want to post here I choose the size that is closest to 800 along the longest side and post the photo. I have a similar problem in that I don't know how to get smugmug to export the exif, but if anyone wants that info, I either copy/paste it or more likely just direct them to the Smugmug photo which has all the info.
NaCl(of course you have to have a site that does the resizing)H2O
NaClH2O is offline
04-22-2009, 11:12 PM   #13
in "Save For Web"? I only have an earlier version is ain't there, and based on all the fuss about it, assumed it still wasn't.
HGMonaro is offline
04-22-2009, 11:27 PM   #14
Gallery Photos: 8
It still adds up. But I think the reason is more important: in a finished product like a web site, you don't want to expose technical background information. Exif can tell too much.
Of course, that isn't necessarily the case for the situation where the web site is about the pictures, rather than about something else which there happen to be pictures of. But we're a) a minority case and b) the people who should know how to do something about it.
mattdm is offline
04-23-2009, 05:21 AM   #15
I've also found that Save for Web messes with the colours in your pic. My workflow is similar to the one at the top of the thread.
Adobe seem to have dropped the ball on this feature.
asw66 is offline
