| Depending upon what HP printer you use, you can also have light cyan and light magenta in the Vivera inks. The newer printers using no light cyan and light magenta have two different dot sizes to simulate light cyan and light magenta. As far as I know, you can hardly see any difference between the two. If you go with the HP B9180 printer, you still use Vivera inks, but you have eight colors. And if you go to a Z3200 printer, you have twelve Vivera inks in the printer. The more color, the more expensive the refill. So far, I can't find third party inks for the latest cartridges used in the five color versions (#564 and #564XL) of the Vivera system. I've been using third party inks in my B9180 and Z3200 without any problems, beside the fact that you need a new profile for every paper you use. The third party ink are a lot cheaper than HP's own Vivera inks. |
