| I have used Lightzone casually for a couple of years. While I wish I could give you an authoritative response to the stepping issue, I can share what I have observed. I have seen this stepping effect on several instances, and it was usually associated with some very heavy adjustment I was making in the ZoneMapper. An example would be if I was trying to stretch the effective gamma by crushing the empty light zones and dark zones ... if I did it too much, the program can't deal with it and simply posterizes the sky into chunks of color with little gradiation. It's like LZ will "let" me attempt some severe adjustments, but the result is never lifelike or satisfactory.
I suggest starting by taking an original you've seen the problem with, and load it into LightZone. If you do not see the stepping effect, then start making *small* adjustments and note when the effect returns. I suggest that's the point of no return for the adjustment. Any more and you're asking LZ to do something that it can't really do.
Again, these are simply casual observations, I'm sorry I can't offer a better answer.
germar |
