Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > Scanning film....or not?
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
05-28-2009, 09:43 PM   #31
Gallery Photos: 4
Originally Posted by Venturi View Post
Glad to hear you're liking the scanner, Steve. Did you buy the roll adapter and/or are you scanning full strips? Or are you pre-cutting your negs?
I'm still weighing the cost-vs-pain of going with the Nikon vs the Pacific Imaging.
I didn't get the bulk slide adapter (SF-210) or the roll film adapter (SA-30), though I did get the FH-3 film holder for single frames. Since all my current negatives are cut into strips of 4-6 frames, this will do for now. Once the unit goes off warranty, there is a hardware hack to enable the SA-21 negative strip adapter to scan full uncut rolls.
stevebrot is offline
05-28-2009, 11:09 PM   #32
P67
Gallery Photos: 8
Hello to all - new to these forums.
I have a Microtek I800. Not happy with it for slides - positives. I get distortion bands on astro photos along with funny coloured stars. White in the centre - blue on left side - red on right side.
It digs out shadow detail extremely well. Daytime shots are excellent - as well as B&W or from prints. Silverfast software is great.
Testing before buying is strongly recommended.
P67 is offline
05-28-2009, 11:48 PM   #33
Anyone try "Scan Cafe"
I've got a boatload of negatives and slides to digitise...
I was considering Nikon Coolscan, but I can just imagine the time it would take to 'de-dust' each frame, scan, do preliminary touch ups.. etc... So I've begun to consider sending them out. Scan Cafe caught my eye. From 24 cents a frame.. they'll scan everything and present it to you over the web. Then you select what you actually want, so you only pay for the 'keepers'. This is great for me, as I had a habit of bracketing a fare bit and not throwing anything away.
Has anyone tried this or similar?
Paul
pama123 is offline
05-29-2009, 05:38 AM   #34
Paul
define boatload. I had 5000 slides and 15000 negatives.
the scanner I used (Minolta Dimage II) had a carrier for slides, 4 at a time, and a carrier for neg's, 6 at a time.
so you de-dust 6 at a time, and batch process them. while it might have taken 30-45 minutes to do the 6 frames, it really boiled down to a few minutes every hour.
took me 4 years but I scanned everything.
I still have the neg's and slides stored in archival pages so it I need to go back I can always re-scan. I have not found th e need yet.
I have heard of places in india that are as low as $.19 per frame, but think of the cost. 20,000 frames is still about $5,000
Lowell Goudge is offline
05-29-2009, 06:16 AM   #35
Scan Cafe
Thanks for the advice,
OK... so maybe it is more like a rowboat.... about 5,000 slides and another 2,000 negatives.
I guess it came down to my not wanting to go through the tedium of doing that processing... and knowing me, it would stretch out to 4 years or more even with that lower volume of slides/negs.
I made a guesstimate of about 5 minutes per frame, including the prep, scanning, naming and managing of the files themselves etc.. .and that works out to over 500 hours.
Doing that math, though, it does come out to a lot of extra money for shipping it out, even after you deduct the price of a good scanner...
Still thinking about it...
Paul
pama123 is offline
05-29-2009, 09:15 PM   #36
Gallery Photos: 6
Minolta Scanners
I have been using Minolta Dimage Elite 5400 film scanner for a few years now. I find there is a singificant difference in time between scanning slide and negs at the same settings. Slides generally take about 1/4 of the time it takes to scan negs. Have been shooting slide mostly since I bought the scanner.
The results are quite amazing, this thing will resolve down to the film's grain.
Macroguy is offline
05-30-2009, 03:25 PM   #37
Gallery Photos: 4
Well, here is my first slide scan with the Coolscan 5000 ED:
Ricoh XR7 with Tamron 28/2.5 (02B), Kodachrome 64
I am pretty pleased with the results. On the 4000 dpi scan you can see the film's grain structure. That is impressive with Kodachrome.
06-03-2009, 07:07 PM   #38
I will say that using the Minolta 5400 Elite II is a bit slow. One other thing to consider (especially when trying to scan underexposed slides) is getting software to remove scan noise. I use Neat Image, which I have found to be excellent.
The minolta is capable of some good results, and the lab I bought it off only got rid of it due to the speed of scanning not being as quick as the coolscan.
(MZ-5N + 28-200mm 3.5-5.6 IF AL)
Clarkey is offline
06-04-2009, 12:42 AM   #39
On the subject of scanners, I picked up a PrimeFilm 1800u film scanner for $3 at a yard sale. Before I go to the trouble of downloading drivers, does anyone think this thing will give decent results? I'm not familiar with the brand, but the model number kinda hints that it's only 1800ppi...
OregonJim is offline
06-04-2009, 10:00 AM   #40
Gallery Photos: 4
PrimeFilm 1800u
06-09-2009, 07:50 PM   #41
I develop B&W and scan myself with an Epson V500. Big savings over the long run, and you'll learn photo chemistry. It's a win/win. Color is another story.
Steve and Clarky: great photos! Check out those blue skies.
Jake67 is offline
08-21-2009, 03:07 AM   #42
@ Clarkey & Stevebrot: Wow! Those shots are perfect! Perfect colors, perfect detail and sharpnes... Everything perfect!
Now... I'm not sure if this is the right place to post, but here it is:
I use a CanoScan 4200F that can go up to 3200dpi, 48bits TIFF. I have the negative 35mm film pre-cut (4 frames) at the local Fuji lab that develops it.
Then... in the Canon software, I have the option to preview and scan as a batch of 4 frames, or frame-by-frame (with "calibrate at every scan" checked). What I found out is that the results are considerably different when using the two methods.
I unchecked the "descreen", "unsharp mask", "reduce dust and scratches" and "fading correction" buttons, and only left the "grain correction" at lowest... and yet! Calibrating / previewing / scanning for batch of 4 is huuuugely different from calibrating / previewing /scanning frame-by-frame.
So... if the scanner can induce such a level of "subjectivity", which then needs some amount of digital post-processing, then what's the point of shooting film?
(Before throwing any rocks, please note that 1. I love shooting film and I only exaggerated for the sake of argumentation, 2. I'm (desperately?)looking for tips in order to enhance my scanning work flow, in order to 3. use the lightroom and photoshop software at minimum).
MeFirstO is offline
08-21-2009, 08:24 AM   #43
Gallery Photos: 4
If you were "batch" processing in the darkroom, you would use the same settings for each print and your results would reflect the care you put into the process.
The scanning/pp step is similar to things you could be doing in the darkroom. When scanning negatives or slides the issues of exposure, contrast, and color balance are part of the mix just as much as if the image was being projected onto paper with an enlarger. The main difference is that you have quite a bit more control with the scanner and pp software. This is particularly true in regards to contrast and color balance. One of the main reasons I gave up on color darkroom work was effort it took to get a decent print.
08-21-2009, 12:19 PM   #44
Just got delivery a few days ago of a Coolscan 9000. I also have quite a few slides and negs that are sitting around deteriorating. The Coolscan does a terrific job of bringing them back, and it has no problems (so far) with Kodachrome. However, there is a learning curve, and this is slow going.
I originally thought I would scan to 16 bit Tiffs, but at 100megs a pop, I'll fill up some drives quickly. In all honesty, I have to say that most of my old slides do not merit that treatment. I may start with high quality JPEGS. then pp in PS, and if the slide is super, rescan to TIFF. Or I may just buy lots of USB hard drives.
GeneV is offline
08-21-2009, 01:45 PM   #45
from a purist point of view, i would highly suggest you scan at maximum everything, then downsample as a batch through Photoshop, rather than scanning at lower settings.
PS, congrats on the scanner, it is a fine piece of technology.
Gooshin is offline
