Go Back PentaxForums.com > Photography > Post Processing, Printing, Software, and Darkroom > LR2 starts up when a SD card is inserted
Post Processing, Printing, Software, and Darkroom Discuss photo printing, scanning, editing, and enchancement methods here.
08-15-2009, 12:25 PM   #1
Gallery Photos: 49
Any ideas on how to avoid this?
Under Edit\Preferences\Import, I tried to uncheck the box for "Show import dialog when a memory card is detected" but it doesn't "stick": when I close and open LR2 again, this option is checked again.
I'm only having this problem since I reinstalled LR2 (and everything else) recently.
Bart is offline
08-15-2009, 03:02 PM   #2
Try Deleting the Preference file.
RollsUp is online now
08-15-2009, 10:31 PM   #3
Go to Edit, select Preferences, Import tab and uncheck "show import dialog.....
That will do it.
bobrapp is offline
08-15-2009, 11:08 PM   #4
Gallery Photos: 155
If that doesn't work, check the preferences for your computer, that might be set to startup LR2 if a card is detected.
Damn Brit is online now
08-16-2009, 02:22 AM   #5
Location: The shores of Loch Ness, Highlands of Scotland
I'm with Gary on this one, in Vista a pop up appears asking want you wanna do when it detects new stuff pluged in, you should be able to change the preferences there.
If always do this option, has been previously selected maybe the box don't pop up, so you will have to dig a bit deeper to change the settings.
kerrowdown is offline
08-16-2009, 02:39 AM   #6
I think that you have also to delete the link in windows (Choose of the program when you enter the card : click : nothing)
Labuzan is offline
08-16-2009, 04:02 AM   #7
Gallery Photos: 49
Thanks everybody for the suggestions.
Deleting the preference file did not fix this.
LR2 was not set as the automatic option.
I finally disabled all Autoplay options and that did it.
The contrary would have been amazing .
Still seems like an overly enthusiastic bug in LR2 to me but the work around has been found and all is well.
Bart is offline
08-16-2009, 10:25 AM   #8
Good to hear, I know how annoying these can be.
I've got a back up programme that opens on the toolbar on boot up, think I can kill it, well not so far, it just sits there 'till I right click and close it.
08-16-2009, 12:56 PM   #9
Gallery Photos: 49
If you feel 'daring', you could have a look at 'system management' \ System configuration. There is a tab there showing all Startup functions. Normally, you should find it there and you could disable it.
If you're on a PC, that is.
Do be carefull, though.
Bart is offline
08-16-2009, 07:21 PM   #10
Yeah I have this problem, it's quite annoying because my LR database is on my external drive, so when I pop in my SD card before connecting the external, LR says it cannot find the LR database. When it is plugged in, windows just starts up the dialog box asking me what I want to do - it doesn't automatically open up LR. Show Import Dialog is definitely not checked.
Under startup I do see Adobe CS4 Service Manager - but if I disable this, what else, if anything, will I lose?
I don't want to uncheck "Use Autoplay for all media and devices" as that will effect everything.
Eruditass is offline
08-17-2009, 01:43 AM   #11
bart it is likely that Explorer (assume you are using some flavour of Windows) has the file type registered to lightroom or the card reader's start option to LR.
photog is offline
08-17-2009, 02:19 AM   #12
This is a bug for LR2.4 and should be fixed in the next release.
wlachan is offline
08-17-2009, 03:03 AM   #13
Gallery Photos: 49
Good to know. One less mystery on the pc .
Bart is offline
LR2 vs Bibble 5 Ben Hunt Post Processing, Printing, Software, and Darkroom 16 09-23-2009 07:52 PM
Question Inserted images not showing up geauxpez Site Suggestions and Forum Help 3 07-26-2009 12:55 PM
noise ninja and LR2 weatherwise2 Post Processing, Printing, Software, and Darkroom 1 08-29-2008 11:40 AM
New K20D and file name starts at 4XXX? nah Pentax DSLR Discussion 3 08-12-2008 10:51 AM
DPreview launches lens review section - starts with Pentax (and some other misc brand mattdm Pentax News and Rumors 14 01-30-2008 04:48 AM
