| The high ISO NR is only for JPEG. The slow shutter NR works for both JPEG and RAW, but only for truly long exposures - measured in seconds, not fractions of seconds. You'll know it has kicked in because it will take as long for the camera to be ready to take another picture as the exposure itself - a 10 second exposure takes an additional 10 seconds for the slow shutter NR to occur (because it works by taking a second image with the same shutter speed but shutter closed and comparing).
I find with my K200D - same sensor as your K2000 - that there is quite a bit of "chroma" noise (colored specks), but luckily, this is very easily removed in PP without having much effect on IQ at all. On my high ISO images, I turn the chroma NR up all the way and the colored specks pretty much disappear with almost no loss of detail. Then I apply just a *touch* of luminance NR, since that is what kills detail. I have this saved as a preset, so in seconds, I can clean up as many images as I want without leaving the RAW domain. I'd only resort to a program like Noise Ninja in an extreme emergency, since as far as I know it requires you to leave the RAW domain in order to work, thus breaking up the workflow far too much for me to want to go there.
BTW, since high ISO NR does not affect RAW, it doesn't matter how you set it. but if you are doing long exposures, then you really do want that slow shutter NR, because the method it uses ("dark frame subtraction" - taking that secnd picture with the shutter closed) can't be emulated by Noise Ninja. |
