I have been using ACDSee Pro2 for several months. I like it but have no basis for comparison since I do not have other RAW handling software.
I find the software to be plenty fast. This is the case even though I have an older AMD Athlon based desktop PC.
It does batch image processing well.
It does batch setting of metadata well.
It has ability to let you customize many features to your liking.
You can browse and edit PEF RAW files without converting them to TIFF or JPG. With the RAW Processing (as in lightroom?), the changes you make to the RAW file are saved as a set of instructions and the original RAW file is kept intact. This also means there is no absolute need to save your processed images as TIFF or JPG files.
One problem is that it does not pickup the Pentax lens info to display in the EXIF. So, unless you enter the lens used in some other EXIF or IPTC field, you cannot sort or catagorize based on lens. Oh Well.
__________________
Best Regards
Greg
