Go Back   PentaxForums.com > Off-Topic Forums > Post Processing and Software
Post Processing and Software Discuss photo editing and photo-improvement methods here.
Old 07-24-2008, 09:22 AM   #16
sajmmiller's Avatar
Originally Posted by Entropy View Post
I can confirm that the digikam 0.94 series works with the K20D - I use it for culling out really bad shots before going through stuff with ufraw.
GQView 2.1.5 is fast also works well for viewing and culling raw files before processing. I'm not sure if it would work with K20D raw files though.
__________________
--Scott
Pentax Lenses: DA 18-55mm F/3.5-5.6, DA 50-200mm F/4-5.6 ED
Tamron Lenses: SP AF90mm F/2.8 Macro 1:1, AF70-300mm LD Di Macro 1:2
My Zenfolio Gallery | PPG Accepted Photos
sajmmiller is offline   Reply With Quote
Old 07-24-2008, 11:06 AM   #17
sajmmiller's Avatar
UFRaw Setup -- One more important piece.
The other key piece of info is that the gamma in UFRaw much be set correctly for whatever camera profile you are using. There's some info about that on the UFRaw website in the color profiling section. For the Bibble Pentax1 and Pentax3 profiles, the gamma needs to be set to 1.0.
__________________
--Scott
Old 07-24-2008, 12:12 PM   #18
Venturi's Avatar
PM sent and thanks!
__________________
Resident Pain in the Aperture
My Gear
Venturi is offline   Reply With Quote
Old 07-28-2008, 03:40 AM   #19
Originally Posted by Venturi View Post
PM sent and thanks!
Once you have the profiles and curves set up in UFRaw, also have a look at ufrb-kde ufrb-kde KDE-Apps.org
It will allow you to batch-convert a whole directory (of even multiple directories) at a time, once you have converted a representative image from the batch in the UFRaw GUI and made a *.ufraw ID file.
ufrb-kde was specifically written with the UFRaw CVS version of 0.14 in mind.
__________________
http://www.pbase.com/newmikey
All images: UFRaw-Assist on PCLinuxOS
newmikey is offline   Reply With Quote
Old 08-03-2008, 01:48 PM   #20
Originally Posted by sajmmiller View Post
Like you, I was frustrated with UFRaw at first, but now I much prefer it over the other raw converters.
That's typical of many open source programs. A developer had an itch, so instead of designing it like every other app, they decided to do something different that they wanted.
E.g., I actually adopted StarOffice in the mid-'90s because of various issues I had with MS Office (lack of long-term document sustainment, as well as the availability of select importers -- like Ami Pro -- drove my consideration). So unlike most people new to OpenOffice.org (based on StarOffice), I know "Page Format/Layout" is under the "Format" menu (with "Paragraph" and other format options) and not "File." But I could see how things like that could frustrate people coming from MS Office, among other things.
__________________
Bryan J Smith, Engineering Consultant, Photography Novice Striving for Amateur Abilities
Pentax K20D, AF-360 FGZ, DA 10-17 f/3.5-4.5 FE, DA* 16-50 f/2.8, DA* 50-135 f/2.8, DA 50-200 f/4-5.6, FA 80-320 f/4.5-5.6
Taken with: Pentax K100D, DA 16-45mm f/4
bjsmith is offline   Reply With Quote
Old 08-28-2008, 04:51 AM   #21
marlon's Avatar
Just keep in mind, UFRaw is update released next week, which will support the k20D.
I have confirmation from Udi himself via email.
Patience for one more week! Im trying my best myself.
marlon is offline   Reply With Quote
