Go Back   PentaxForums.com > Off-Topic Forums > Post Processing and Software
Post Processing and Software Discuss photo editing and photo-improvement methods here.
Old 08-06-2008, 01:14 PM   #16
Originally Posted by davemdsn View Post
Uhh, well I quit using Lightroom about 6 months ago. The problem with presets is that every image is different and needs different things. Lightroom does have an auto tone setting that you can use on import. Try it to see if you like it. Sometimes it is too strong, but it is better than the flat tone default.
so which software do you usually use now? Any recommendations? Thanks!
airsniper is offline   Reply With Quote
Old 08-07-2008, 10:41 AM   #17
Originally Posted by airsniper View Post
Thank Godness! They finally made it. I am always thinking that shooting in DNG is a special advantage that only pentax can bring us. Now it becomes more powerful, though DNG is a little bit larger (roughly 16MB per file)
Thank you, too for bringing me such a fantastic news! The only problem: Do I need to purchase again to get 2.0, or I can just download and upgrade? Thank you very much!
You should be able to install the upgrade. It looks like it's compatible with ACR4.5, so if you get that, it should work fine for you.
__________________
Aloha Photographer Photoblog
http://alohaphotog.blogspot.com/
alohadave is offline   Reply With Quote
Old 08-07-2008, 03:56 PM   #18
Originally Posted by alohadave View Post
Try using the new DNG profiles. It may help with your color problems.
Jao's photo blog: Lightroom 2.0
I've read a lot today, it turned out that they only support Canon and Nikon right now... Sad truth...
Old 08-07-2008, 08:42 PM   #19
SpecialK's Avatar
2. Drawbacks of PLL: The Preview window can not be enlarged, thus it is extremely difficult to use it as a processing software, any ideas to improve this?
I can resize it up to full screen by dragging the corner.
3. There seems to be no difference between Landscape and Picture (Landscape), but why are they two different image-tone as listed in PLL?
I have only used "natural".
4. PLL tends to generate a EXIF item called Component Config, and the value is YCbcr, what does this mean?
I've never seen that. I save the Exif list generated in PPB. To me, only a few exif values have any meaning once the image is processed.
__________________
Pentax K100D/10-17/12-24/50-200/55-300, AF540
Sigma 18-50 2.8 & Canon S3 IS
http://s133.photobucket.com/albums/q78/KylePix/
SpecialK is offline   Reply With Quote
