I will be going to the "SuperMoto" races later this afternoon, and am looking for advice on settings. Somewhat fast action, and from the looks outside, it will be a very bright sunny day, went out a few mins ago and there was not a cloud in the sky. So what i am asking here is, to get the sharpest photos for SOMEWHAT fast action, what f stop, shutter speed, and ISO combinations would you photo gurus recommend? I know there is no ONE answer to this question, but i am sure there are general rules to go by for these kinds of shots. More than likely i'll be using the kit lens, and maybe a 28-80 zoom my pop has.
Any help will be greatly appreciated
__________________ http://www.flickr.com/photos/77145824@N00/
K10D, K110D, Kit Lens, SMC-M 50 mm f1.4, RMC Tokina 28 mm f2.8, Tamron 70-300 mm LD DI, Chinar 135 mm f2.8, Vivitar 400 mm f5.6, Super Takumar 55 mm f1.8, Super Takumar 28mm f3.5, Super Multi Coated Takumar 200 mm f4, Super Takumar 35mm f3.5
I shot some power boat races recently, so I stuck my camera in SHutter priority and played around with the speeds. I found that to get a sharp enough panning shot with the background "speed blurred", 1/90 was about right. If I wanted a super sharp shot, but not indicating much speed as the backgound was also frozen, I used a faster shutter. The speed of the bikes will differ for you than the boats for me, so I suggest some experimentation at the start to see what you can do. Then you can decide whether or not you want a blurred backgorund or not. The relative speed of the bikes is also determined by how close you are to them. I kept it on ISO 200 (my lowest) as it was a nice day.
Other things are pre-focussing on where you know the bike is going to be you probably realise.
If you are going to get a lot of sky in the shots, when the bikes are jumping for instance, you may want to dial in some + compensation, or fix your metering elsewhere.
I know its a bit late now, but like Arpe said, if you want to show motion then keep it in shutter priority anywhere between 1/50 and 1/125 and make sure you have your lowest iso setting selected. It is probably best to use AF-C if you plan on panning as well.
The following shot was taken at 1/60th, f8 and iso100 in shutter priority mode and AI-servo (constant autofocus)
__________________
K10D.K100D.MZ-50.Ricoh XR-P
Some Pentax lenses, some sigma lenses, some manual lenses and a set of extension tubes and a battery grip. flickr redbubble
Thanks for the replies !! i should have posted this friday, lol, although i did manage a few good shots !!
