Go Back PentaxForums.com > Photo Sharing and Galleries > Post your photos! > My grandson - need C&C
Posted by cardinal43, 01-17-2008, 05:38 PM cardinal43 is offline
This is Keegan, my 15 month old grandson. He was visiting me last week and I took this picture. As you can see, while the subject is beautiful (), the picture needs some big time help. I don't know if the exif is attached (not sure how to do that), but the particulars are: Av, 1/60, ev = 0, Iso 200, w/b = manual(??). I think this is a w/b issue. It was taken in my dining room under recessed lights. I am definitely open for any and all comments. My camera is the K100D with the 18-55mm kit lens.
Thanks,
01-17-2008, 06:01 PM   #2
Gallery Photos: 13
Changed white balance in Picasa, let me know what you think..Not perfect, but took me about 2 secs to adjust , hehe
Stratman is offline
01-17-2008, 06:09 PM   #3
and
Gallery Photos: 13
Yep, the main problem here is the WB, there is a very strong blue color cast.
I dont know if you want tips for future photos or to save this one.
To save this one some PP is required, I dont know what kind of software you have available. Shooting RAW is better than shooting jpeg for white balance because you can set the WB after the shot is taken. It can be corrected in jpegs too though.
Some adjustment with levels or curves will help here. Auto levels and auto curves do a deent job at it, manually reducing the blue can be an option too.
and is offline
01-17-2008, 06:17 PM   #4
Gallery Photos: 7
Thank you gentlemen. I will keep it and do some playing. I have Adobe Elements 5, Picasa, FastStone Viewer, among others. I have 4 others with the "blue" tone, so I plan to work on them.
Andreas: I have never shot in raw. I think I might dabble with that a bit. So much to learn, so little time.
01-17-2008, 06:29 PM   #5
and
Gallery Photos: 13
Adobe elements has both auto color and auto levels that you can try out. also in full edit mode you can access curves and reduce the blue curve, but thats a bit more advanced.
Also check your camera wb settings and make sure its not still stuck in manual or something else than auto.
Ill give you a general kids tip as well, imo its better if you get the lens more down to the kids eye level instead of you standing up and aiming the camera down, this catches the expression of the kid better as well.
and is offline
01-17-2008, 07:06 PM   #6
cardinal - it looks to me like you maybe had the white balance set for tungsten (regular bulb) light on the cam... i usually take a quick test shot in the room before i start shooting and then adjust the white balance on cam for the rest of the pics... when you're outdoors it usually doesn't matter and you can just leave it on auto hope that helps!!
mitchkramez is offline
01-18-2008, 07:32 AM   #7
You probably set your white balance when not using the flash. If you use the flash you need to set the white balance again.
The white balance can be changed in camera to any picture already taken by using one of the digital filters. Just go into the fn menu during playback and hit < then select color. Make the adjustment with the thumb wheel and save it as a new picture. It's not perfect but pretty close.
As Andreas said, Picasa works well too.
prof68 is offline
01-18-2008, 06:04 PM   #8
I'd also like suggest
that, if you're able, to get down to eye level with the child.
imajypsee is offline
Grandson (11 Months) at the park kev.pride Post your photos! 5 04-21-2009 08:51 AM
For Sale: [SOLD] ist DS camera &amp; Quantaray 28-90mm lens &amp; accessories, Promaster 7000m flash rockmaster1964 Sold Items 10 01-30-2009 05:57 PM
Grandson candid res3567 Photo Critique 7 12-17-2008 09:25 PM
Grandson :Teenager !!! Bramela Previous Submissions 0 10-02-2007 10:56 PM
Grandson with DFA 100 Mallee Boy Post your photos! 6 04-06-2007 07:01 PM
