Go Back   PentaxForums.com > Our Pentax Forum > Site Suggestions, Errors, and Help
Site Suggestions, Errors, and Help Ask for forum help here, or post any suggestions or error reports that you may have.
Old 06-25-2008, 11:39 PM   #16
Igilligan's Avatar
Thanks séamuis ... Mine is working fine right now... but at least 3 times this week it has slowed to a crawl while the rest of the internet has been fine. I am at a loss as to what is going on. I was interested when I saw the op and Tom had been experiencing similar random slow downs...
__________________
gus
Get what makes you happy...
Anything less, makes you less happy!
Igilligan is offline   Reply With Quote
Old 06-25-2008, 11:40 PM   #17
Damn Brit's Avatar
Gallery Photos: 5
It's a conspiracy, run for the hills, wear metal pots on your heads to keep out the evil rays.
I'm like Albert, this kind of thing happens but it's on everything. I have AT&T and most evenings between 6.30 and 7, the server stops responding for a few minutes.
Gary
__________________
Gary is my name.
Canadian by adoption eh.
Damn Brit is offline   Reply With Quote
Old 06-25-2008, 11:49 PM   #18
Igilligan's Avatar
You know more than you think you know....
Gary
You may think that is funny Gary, but I just looked up and saw that the tinfoil that covers my windows has a slight rip in it.... That could be it!
__________________
gus
Old 06-26-2008, 12:43 AM   #19
séamuis's Avatar
Gallery Photos: 6
could it be IE? has anyone using IE tried firefox?
__________________
'Photography is not about the thing photographed. It is about how that thing looks photographed.' -Garry Winogrand
Asahi Pentax MX | smc-M 28mm 2,0 | smc-M 35mm 2,8 | smc-M 50mm 1,7 | smc-M 85mm 2,0 | Ilford & Kodak
aperturefoundation | Street Photography & Winogrand | J.E.Moore Photography
'Get Born' -Bob Dylan
séamuis is offline   Reply With Quote
Old 06-26-2008, 03:34 AM   #20
Originally Posted by Igilligan View Post
I run window xp and IE on two different comps and for a few hours a day this thing takes sometimes two minutes to load the main page and then forget clicking on a thread. Really frustrating since all the other forums and internet functions are working fine. In fact it did it for a few hours this afternoon.
I use comcast as a IP.... anyone else have comcast in this scenario? Maybe they are not talking nice.
PS it will be like that for a while and then an hour later everything will be fine. Definately not a comp issue since it is happening with two different ones at my house.
Comcast here as well
whitedogone is offline   Reply With Quote
Old 06-26-2008, 05:48 AM   #21
Tom S.'s Avatar
Gus,
I use Comcast too, but like you, the only affected site was this one. I have between 7 and 10 tabs open all the time, and non of them ran slow.
Cable can slow down when a lot of users get on line, but it doesn't slow for just one site, it slows for all of them, so that's not the issue. Also, IE will time out and give you the 'Page Not Found' message if it's not receiving info back from the site you are connected to, which wasn't happening for me.
So what was the issue? Here's what I suspect. When you connect from your house (Point A) to this site (Point B), you are actually going through many different servers (Points C, D, E, F, G, etc.) along the way. If one of those screws up due to mechanical, software, or usage issues, you get slowed down. Since there was no reported issues with this sites server(s), and since we were able to go to other sites with no problems, I suspect we were experiencing an issue with another relay point along the way.
As a side note, when I spell checked this message, I misspelled Comcast (COmcast). The spell checker asked if I meant compost! Maybe....
__________________
*ist-Ds, K20D
DA 10-17mm Fisheye, DA 12-24mm, DA 18-55mm, DA 35mm F2.9 Macro Limited, D-FA 50mm F2.8 Macro, DA 18-250mm, DA* F4 300mm
FA 1.4 50mm, FA 28-80mm, FA 28-200mm, FA 80-320mm , FA 100mm Macro, F 1.7 AF Adapter
Tamron XR LD 28-300mm, Sigma 600mm Mirror
Tom S. is offline   Reply With Quote
Old 06-26-2008, 08:16 AM   #22
daacon's Avatar
Gallery Photos: 7
Seems strange indeed - well the usual maintenance - clear temp files, scan disk and defrag - keep temp IE files to around 100mb (instead of the default 5% ) constant sized swap file.
I find with IE7 the tabs are nice but if I run more than 5 or 6 I start to get into issues. The issues are site dependant.
The next time it is slow try this at the DOS/Command prompt.
tracert www<dot>pentaxforums<dot>com (replace the <dot> with . )
that should indicate if there is a bottle neck somewhere along the way. Gnerally anything over 100ms is 'slow' but slow is all relative
Edit: I just did that command 12 hops to get there from here 1 was 229ms all others were < 100 - response is good for me now. I am on a 3mb/1mb down/up DSL connection
__________________
<=== Dave ===>
istD, K10D, PENTAX AF-540FGZ, F-Remote, BG-2 Battery Grip
Pentax DA 10-17 f3.5-4.5, DA 12-24 f4, DA* 16-50 f2.8, DA* 50-135 f2.8, SMC-F 50mm f1.7, DA 55-300 f4-5.8
Tamron 28-75 f2.8, 18-250 f3.5-6.3
Sigma 50-500 f4-6.3 "BIGMA", 105mm f2.8 EX DG MACRO
daacon is online now   Reply With Quote
Old 06-26-2008, 08:55 AM   #23
séamuis's Avatar
Gallery Photos: 6
I had 17, all were 66ms and under.
__________________
Old 06-26-2008, 09:30 AM   #24
Igilligan's Avatar
Tom and Dave
Thanks guys...
Tom, that helps me understand why only this site was slow.
Dave I am computer challenged. Can you explain what this means and how to actually do it?
What is the DOS/command Prompt?
Thanks for the help
__________________
gus
Old 06-26-2008, 10:11 AM   #25
séamuis's Avatar
Gallery Photos: 6
start button>Run>type: command prompt
when the command prompt box opens type: tracert www<dot>pentaxforums<dot>com (replace the <dot> with . )
it will do a trace on the IP and every 'hop' it makes will show up as a sequential number and you will see a number in milliseconds (ms) any number of 100 or above is deemed as 'slow' any out of place high number will be a 'bottleneck' in traffic thus slowing or even timing out your connection to the site. the less hops and smaller number in milliseconds per hop the better the connection.
__________________
