Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » FA Prime Lenses
SMC Pentax-FA 100mm F2.8 Macro Review RSS Feed
Sharpness
 9.6
Aberrations
 9.2
Bokeh
 9.5
Autofocus
 8.7
Handling
 8.7
Value
 9.7
29 196,931 Thu September 22, 2022
97% of reviewers $334.80 9.52
Description:
The SMC Pentax-FA 100mm F2.8 Macro is a high-quality macro lens designed to be well above the SMC Pentax-FA 100mm F3.5 macro in image quality. It features a clamp and a focus limiter. The optics are seated that far from the front that no separate lens hood is required.
Optically this lens is identical to its F-series predecessor and the D FA-series successors.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Aperture Ring
Yes (A setting)
Diaphragm
Automatic, 8 blades
Optics
9 elements, 8 groups
Mount Variant
KAF
Check camera compatibility
Max. Aperture
F2.8
Min. Aperture
F32
Focusing
AF (screwdrive)
Quick-shift
Min. Focus
31 cm
Max. Magnification
1x
Filter Size
58 mm
Internal Focus
APS-C: 16 ° / 14 °
Full frame: 24 ° / 20 °
Hood
Not needed
Case
S80-160
Lens Cap
Plastic clip-on
Coating
SMC
Weather Sealing
Other Features
Focus Clamp,Focus Range Limiter
Diam x Length
74 x 104 mm (2.9 x 4.1 in.)
Weight
600 g (21.1 oz.)
Production Years
1991 to 2004
Engraved Name
smc PENTAX-FA 1:2.8 100mm MACRO
Product Code
28930
Reviews
User reviews
Features:
Screwdrive AutofocusAperture RingAutomatic ApertureFull-Frame SupportDiscontinued
Sample Photos: View Sample Photos
Price History:
Add Review of SMC Pentax-FA 100mm F2.8 Macro
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-15 of 29
Review Date: September 22, 2022 Recommended | Price: $120.00 | Rating: 10
Pros: Excellent IQ at any setting, focus range limiter, build quality
Cons: Bit on the heavy side, external focusing
Sharpness: 10    Aberrations: 9    Bokeh: 9    Autofocus: 8    Handling: 9    Value: 10    New or Used: Used    Camera Used: K-1
I have been very happy with the Pentax-FA 50mm f2.8 macro, and I'm even happier with this lens. In addition to giving my thoughts on this lens, I will also briefly compare it to the 50mm.
First of all, as far as macro photography goes, you cannot go wrong with this lens. If you're considering it, go for it and you will be happy. It's attractively priced, readily available, and produces gorgeous images.
I won't talk too much about image quality. It's excellent at all settings. Period. I'll just add that I love the colors.
In terms of build quality, it's a typical metal FA lens: solid, smooth, arguably ugly (although I personally love this look). It's a bit on the heavy side, but not prohibitively so. I can still shoot one-handed with my K-1. Due to weather conditions, I haven't been able to do longer shoots outdoors, but I'm convinced it will work just fine. The only thing that stands out is the limiter switch, which feels cheap compared to the rest of the lens' exterior.
AF is typical of Pentax screwdrive lenses I've used thus far: on the slow side, accurate, hunts a lot at close range, and loud. The presence of the limiter switch helps when doing macro. At normal distances, there is no need to use the limiter. Speaking of the limiter switch, it can be a bit stiff and it has empty slots between two positions which makes operating it by feel a bit weird. Otherwise, it's not a big problem as I usually don't have to change the setting more than once or twice during a shoot.
It has no lens hood mount and you don't need one because the front element is deeply recessed. The front of the lens extends considerably when focusing closely, but unlike the FA 50mm macro, it has a decent working distance so it is not much of a concern.
Compared to the FA 50mm macro, it's larger and heavier. The difference is not as dramatic as I thought, though. It has the limiter switch that the 50mm lacks, and the clamp function works better on the 100mm. 50mm can double as a normal lens for general purpose photography, while 100mm can be used as a portrait lens. To my eyes, the image quality appears to be about the same between the two, so it's down to the field of view and convenience of having a limiter.
2 users found this helpful
Review Date: August 21, 2018 Recommended | Price: $200.00 | Rating: 10
Pros: Sharp,fast, limitswitch,build,AF
Cons: Heavy
Sharpness: 10    Aberrations: 10    Bokeh: 10    Autofocus: 9    Handling: 9    Value: 10    New or Used: Used    Camera Used: K70
The limit switch on this lens is very usefull , you can limit the focusrange in 2 very different ways : *1 Limited from 70 cm to infinite with a short run so the AFis pretty snappy for normal use as a telelens *2 Limited from 30cm to 70cm for macro use.
I really like the way this lens renders colours and it's very sharp , even wide open, and it only gets better stopped down .
If your looking for a excellent macrolens that's also very useable for other stuff this snap this one up.
As a bonus it's also very affordable. It is very heavy tough.
5 users found this helpful
Review Date: June 9, 2018 Recommended | Price: $255.76 | Rating: 10
Pros: Sharpness - Built like a tank - Bokeh - Aperture Ring
Cons: None that I am aware of
Sharpness: 10    Aberrations: 9    Bokeh: 9    Autofocus: 9    Handling: 10    Value: 10    New or Used: Used    Camera Used: Pentax K1
I plan on using bellows and this lens has a dedicated aperture ring which is a huge plus. The housing is also metal and is quite heavy which if anything is a bonus because it's easier to steady your shot if you are shooting with the aid of a tripod.
I was hoping it would make my K1 shine and it most certainly does. Photos look amazing both wide open and stopped down. It's evident this lens is perfectly suited for the 36MP sensor.
The focus is not the quickest, but they never are on a macro lens. Anyone who is a serious macro shooter doesn't use auto-focus anyways.
I am very happy I purchased this over the latest WR lens which would have been double the price and as far as I can tell does not take superior photos.
Review Date: January 26, 2018 Recommended | Price: $140.00 | Rating: 10
Pros: Focus limiter, 1:1, 2.8, METAL!
Cons: weight
Sharpness: 9    Aberrations: 8    Bokeh: 9    Autofocus: 9    Handling: 8    Value: 10    New or Used: Used    Camera Used: k3II
An amazing lens, sharp at 2.8 and super sharp at 3.2 where the bokeh is still totally round.
It is heavy but with the k3II it is pleasant to handle.
Macro, portrait eeven landscape with NO , nothing, cero, distorsion.
EDIT: There are some cromatic aberrations
The bridge between
the silly lenses of incredible construction
and
the smart ones of plastic and poor quality.
Review Date: December 27, 2017 Recommended | Price: $220.00 | Rating: 9
Pros: very sharp, excellent build quality, fast focusing
Cons: heavy, front element 35mm inside, 35mm less from lighting subject
Sharpness: 9    Aberrations: 10    Bokeh: 9    Autofocus: 9    Handling: 7    Value: 9    New or Used: Used    Camera Used: Kp, K5, K-01
It's a wonderfull piece of glass BUT...
- 600g are too many for free hand macrophoto.
- The recessed front element steals important space to illuminate well the subject with the flash.
1 user found this helpful
Review Date: October 1, 2017 Recommended | Price: $150.00 | Rating: 8
Pros: Sharp, ideal macro, f2.8
Cons: None
Sharpness: 8    Aberrations: 7    Bokeh: 9    Autofocus: 6    Handling: 7    Value: 9    New or Used: Used    Camera Used: K5iis K3 K1
I purchased a bundle of lenses and this is the pick of them.
Its a macro lens, so AF can hunt if your giving it confusing subjects to focus on and let's be real, its a macro lens therefore it's often going to be used as manual focus.
Solid, well built and although a film era lens it is pretty darn good.
Considering the cost, it's a no brainer and one iv'e been hoping to add for a long time.
Little bit of haze on the inner elements I think but doesnt affect quality.
In the world of new and expensive FF glass ....... it's an absolute peach.
Review Date: September 11, 2017 Not Recommended | Price: $200.00 | Rating: 9
Pros: Beautiful bokeh, good sharpness of the lens. Beautifully takes pictures of the macro. Beautifully photographs portraits. Durable, iron casing. Deeply is the front lens (not so much soiled).
Cons: Heavy weight. Loud buzzes when auto focus. Narrow and uncomfortable ring on the lens housing, which is intended for manual focusing. This lens does not take pictures of objects that are far away, but it takes very good pictures of portraits and close-ups.
Sharpness: 9    Aberrations: 8    Bokeh: 10    Autofocus: 9    Handling: 8    Value: 9    New or Used: Used    Camera Used: К-5
This lens is very strong and sturdy, in an iron casing. But because of this he has a rather heavy weight. If you take pictures with this lens for a long time, then the weight is not particularly noticeable. Conversely, it helps to avoid camera shake when photographing. But, if you take pictures for a long time, then the weight of the lens begins to be felt in the form of discomfort.
This lens perfectly removes portraits, subject photos, macro photos.
But the landscape and objects are in the distance, he shoots badly. There is not enough contrast and detail. Although, it's possible that I just got such a copy ..
If you consider the low cost, then I consider the lens to be good and advise it to be acquired by those who intend to shoot beautiful portraits and subject photos and macro photos using the same lens.
P.S. I advise this lens to purchase! But when I save this message on the site, it automatically appears "no" instead of "yes." I do not know why this is happening. I just can't fix it.
Untitled by Vitaliy Potapchikov, on Flickr
IMGP7909 by Vitaliy Potapchikov, on Flickr
IMGP6744 by Vitaliy Potapchikov, on Flickr
IMGP9789 by Vitaliy Potapchikov, on Flickr
Review Date: January 5, 2017 Recommended | Price: $120.00 | Rating: 9
Pros: Solid, sharp, good focus limiter
Cons: Heavy, haze issue, CA
Sharpness: 10    Aberrations: 7    Bokeh: 9    Autofocus: 9    Handling: 8    Value: 9    New or Used: Used    Camera Used: K-S2, MZ-6
I got mine cheaply used with the common haze problem on the inner elements. This actually affects the image quality very little, with a little halo wide open that disappears by f4. Sharp enough at f4, excellent by f5.6 with a real 3D pop. Still very sharp for macro from f11-f22, and capable of great bokeh once you get close.
Focusing is noisy with the screwdrive, but pretty fast for a macro lens. The limiter is useful and the clamp on my copy doesn't work. AF is accurate on both the K-S2 and the film MZ-6.
This lens really suffers with fringing on high contrast edges, especially at wider apertures, but these are easy to remove in post-processing so it's not too bad.
What is worth pointing out is that this is a properly heavy and fairly long lens - it feels unbalanced on the K-S2. It is nearly twice the weight of the modern DFA100WR, so if you want to walk about with this lens or take it travelling you may want to consider that. But as long as you can get one for a good price, the FA still represents great value.
A quick non-macro sample to give you an idea of this lens' rendering (K-S2, f8, ISO100)
Review Date: November 24, 2016 Recommended | Price: $330.00 | Rating: 10
Pros: Build, sharpness, fast focus, very solid feel.
Cons: None so far
Sharpness: 10    Aberrations: 9    Bokeh: 10    Autofocus: 9    Handling: 9    Value: 10    New or Used: New    Camera Used: K3 & K1 II
Bought on EBay at a verry good price. This lens coupled to a Raynox 250 produces beautyfull macro photo in a range of 2.5:1, It is very sharp from F:2.8 with a sweet spot at F:5.6, for general photography and extremely sharp at F:11 to F:22 for macro work. The focus limiter is very practical in auto-focus mode and the clamp is very usefull. I had the Vivitar Serie 1 105mm macro but this lens is much better and versatile. Auto-focus a bit noisy while doing macro work in the field. In studio work I usually use the manual focus with a rail and a Raynox DCR 250 ( 2.5X).
Review Date: November 26, 2015 Recommended | Price: $175.00 | Rating: 9
Pros: Sharp, solid
Cons: AF isn't good enough to do justice to the thin DoF
Sharpness: 10    Aberrations: 9    Bokeh: 8    Autofocus: 6    Handling: 9    Value: 10    New or Used: Used    Camera Used: K-3ii
I bought this for using at work for forensic investigation work. It's extremely sharp and easy to use. Please note that the focus clamp doesn't work and isn't actually required anyway. The AF is pretty average, but the DoF is so thin you can hardly blame the lens. I use live view and manual focus and it gives excellent results. Some have criticized or noted that it is bulky and heavy, but I find it's an advantage as the length of the barrel helps maintain a steady grip.
When photographing bright objects there are some CA's to deal with but overall, nothing that bothers me.
4 users found this helpful
Review Date: June 24, 2014 Recommended | Price: $625.00 | Rating: 10
Pros: Sharp, IQ, colour rendition, compact, bokeh, well built
Cons: None
Sharpness: 10    Aberrations: 10    Bokeh: 10    Autofocus: 9    Handling: 10    Value: 10    New or Used: Used    Camera Used: Pentax K-5
Great macrolens but be aware that it's a rather heavy lens.
[IMG]Chevy Chase - SMC Pentax-FA 100mm F2.8 Macro by siamthai3, on Flickr[/IMG]
Review Date: September 23, 2013 Recommended | Price: $500.00 | Rating: 10
Pros: Excellent build quality, great bokeh
Cons: None
Sharpness: 10    Aberrations: 10    Bokeh: 10    Autofocus: 9    Handling: 10    Value: 10    New or Used: New    Camera Used: K5
Photos with this lens here.
Review Date: March 9, 2012 Recommended | Price: $330.00 | Rating: 10
Pros: Very sharp, focus limiter, nice feel to it, good bokeh
Cons: Spoils the others lenses.
Sharpness: 10    Aberrations: 10    Bokeh: 10    Autofocus: 10    Handling: 10    Value: 10    New or Used: Used    Camera Used: k-x
I was worried about the purchase at the time (you can never be sure of what you are going to get with online auctions) but now I realise I got a bit of a bargain.
The focus limiter is a very useful feature and I now would not like to be without it (pity DFA macros don't have one). Sharpness is impressive. Even at f2.8 it pretty sharp and at the other end f16 is very useful (and surprisingly sharp still) for macro work.
The only lens I have that comes even close in sharpness in my S.M.C 55 f1.8 (which is sharper than my A50f1.7 and Super Tak 50 f1.4) and even then the FA100 is sharper wide open than the 55 is wide open.
I find it quite hard to write negatives on this lens. Its a lovely piece of glass in a solid package and a useful feature set.
I don't mind the size / weight because, for me, its quite easy to steady it (I find weight can help) and not so heavy that you tire.
If I was going to fussy I would say that it would be nice if it was a bit faster for portrait work but given that it is a macro lens then f2.8 is respectable.
One thing for sure is that it spoils my other lenses because it makes their peformance look average in comparison!
This lens stays on my camera a lot
Samples:
Sunset over a damaged city - f11
Lone Tree - f5.6
Tim Beach - f9.5
Icicles - f3.5
6 users found this helpful
Review Date: November 7, 2011 Recommended | Price: $525.00 | Rating: 10
Pros: tact sharp, contrasty, bokeh, 1:1 macro, excellent build-quality
Cons: none
Older pentax 100mm f2.8 macro lenses generally have better optical reputation than DFA versions.
This lens certainly didn't disappoint.
Tact sharp at f2.8, gets even sharper stopped down. Bokeh is amazingly good.
I like to use my 50/2.8 macro for product shots, and this for field shots when working distance is needed.
Best to be mounted on a mini-tripod, get down and dirty on the ground.
Compared to my F100/2.8, I don't see much difference between. They both have the same spec's, so it may have been sample variation that caused other owners to prefer one over the other. There should be more FA 100/2.8's in circulation than F100s, due to its popularity.
For the money and excellent performance, this lens can't be beat. At some point I had all four 100 macro's (F, FA, DFA, DFA WR), but I eventually sold both DFA lenses to keep the better optical F and FA.
Get DFA WR if you absolutely need the WR capability. I would not recommend DFA non-WR version because it is of a plastic barrell similar to DAL lenses, not exactly what you would want to use in the field but perhaps in a studio.
Both F and FA 100's are made of metal barrell , built like tanks , great for field work. Love the feel in my hands.
Review Date: October 10, 2011 Recommended | Rating: 10
Pros: IQ, Sharp, Focus limiter
Cons: ¿A little heavy?
Sharpness: 10    Aberrations: 10    Bokeh: 10    Autofocus: 9    Handling: 8    Value: 10    New or Used: Used
This is a great lens. It has a fast focus (K10D Tested) due to the focus limiter and the IQ is amazing. The weight is not a problem for me, I prefer a heavy one that remember me I'm handling a hole metal body lens. Sometimes it's a bit difficult to switch the focus limiter, but I suppose I will do it better in the future.
This is an example of mi first walkabout with this lens...
http://http://imageshack.us/photo/my-images/7/imgp2900editar.jpg/
All times are GMT -7. The time now is 06:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
