Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » FA Zoom Lenses
SMC Pentax-FA 20-35mm F4 AL Review RSS Feed
Sharpness
 9.2
Aberrations
 8.0
Bokeh
 7.6
Autofocus
 8.9
Handling
 9.2
Value
 9.2
41 191,689 Tue March 12, 2024
100% of reviewers $387.13 9.17
Description:
The Pentax FA 20-35mm is a prosumer-quality full-frame wide-angle zoom lens with a constant aperture of F4.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Aperture Ring
Yes (A setting)
Diaphragm
Automatic, 8 blades
Optics
10 elements, 8 groups
Mount Variant
KAF
Check camera compatibility
Max. Aperture
F4
Min. Aperture
F22
Focusing
AF (screwdrive)
Quick-shift
Min. Focus
33 cm
Max. Magnification
0.16x
Filter Size
58 mm
Internal Focus
APS-C: 72-45 ° / 62-38 °
Full frame: 94-63 ° / 84-54 °
Hood
PH-RBA 58
Case
S90-100
Lens Cap
Plastic clip-on
Coating
Ghostless,SMC
Weather Sealing
Other Features
Diam x Length
68 x 70 mm (2.7 x 2.8 in.)
Weight
245 g (8.6 oz.)
Production Years
1998 to 2004
Engraved Name
smc PENTAX-FA 1:4 20- 35mm AL
Product Code
27960
Reviews
User reviews
Notes
Two aspherical elements
Features:
Screwdrive AutofocusAperture RingAutomatic ApertureFull-Frame SupportDiscontinued
Purchase: Buy the SMC Pentax-FA 20-35mm F4 AL
Sample Photos: View Sample Photos
Price History:
Add Review of SMC Pentax-FA 20-35mm F4 AL Buy the SMC Pentax-FA 20-35mm F4 AL
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-15 of 41
1 user found this helpful
Review Date: March 12, 2024 Recommended | Price: $450.00 | Rating: 9
Pros: Good zoom range, sharp, small/compact, good IQ
Cons: a little bit too light, soft corners wide open
Sharpness: 9    Aberrations: 5    Bokeh: 8    Autofocus: 10    Handling: 6    Value: 9    Camera Used: K1, K1-II
I wanted to extend my zoom range of my lenses for traveling - e.g. when using the D-FA28-105 I miss somehow some more angle of view.
I totally bought 4 versions of this lens all for a quite high price in 2018; I selected the best one and this one is really good.
The first problem was the reach of infinite - the end stop was at about 50m distance. I spend some money to get rid of this problem and now I also can use the lens wider open for landscape.
The second problem is the low weight. With both K1s I see shutter blur when using exposure times between 1/250s and 1/50s.
From my first session with the "new" selected lens:
20mm, F5.6, 1/40s, ISO 125
20mm, F5.6, 1/40s, ISO 160
20mm, F8, 1/250s, ISO 100
20mm, F4, 1/250s, ISO 100
20mm, F8, 1/125s, ISO 100
When I noticed the issue with the shutter blur, I tried to avoid the critical times
20mm, F5.6, 1/20s, ISO 640
26mm, F5.6, 1/20s, ISO 800
20mm, F5.6, 1/250s, ISO 100
20mm, F4.5, 1/15s, ISO 250 with CPL filter
32mm, F6.3, 1.3s, ISO 100
After the service with adjustment of infinite stop
23mm, F7.1, 1/200s, ISO 125
23mm, F5.6, 1/1250s, ISO 100
20mm, F4, 1/1250s, ISO 100
24mm, F16, 1/400s, ISO 100
Often heard complains about soft corners wide open may be a result of the curved sharpness range when using 20mm to 25mm and the limited maximum distance. Now after the service I can put the focus to a bit longer range and can get quite sharp corners even at F4.
Review Date: September 14, 2022 Recommended | Price: $380.00 | Rating: 9
Pros: Versatile focal range, light, great IQ
Cons: Distortion, edge softness
Sharpness: 9    Aberrations: 6    Bokeh: 9    Autofocus: 8    Handling: 8    Value: 8    Camera Used: K-1
My overall score for this lens is 9, but please note that this is highly subjective. If I couldn't live with some of the shortcomings of this lens, I would probably rate it between 5 and 7.
This lens resolves plenty of detail. If you've shot the 28-105mm on the K-1, that's about as sharp as it gets, except that this lens will be plenty sharp wide-open unlike the other lens. Edges and corners will be soft at any usable setting, however, so please keep this in mind. As someone else mentioned, I don't recommend this as a landscape lens. Having said that, I don't really notice it that much for other scenarios.
Other than the edge softness, I love the images I get from this lens overall. Especially the funky distorted look typical of UWAs combined with it's ability to readily 3D pop.
At the widest setting the lens suffers from wavy distortion that cannot be fully corrected. Nor would I, even if it could. Part of the charm of this lens is the distortion, and I very much love it the way it is. Having said that, I wouldn't use it for pictures like this one:
The build is a bit better than the 28-105mm. That is to say, there's no excessive movement when force is applied to the barrel. It's still a plastic lens, though. On the plus side, it's very light. I was very surprised by the lightness when I first received it.
Handling is ok. The zoom ring has no resistance at all, and it's very easy to knock it about by accident. Zooming and focusing is not internal, but for most intents and purposes it is as good as internal zooming. There is very little movement of the front element, and there's virtually none with the lens hood attached. When zooming or focusing, the filter thread does not rotate, so this little lens is polarizer-friendly. The zoom range is rather versatile, but not more so than similar lenses. I would like it a lot better if it went a bit longer on the long end (e.g., 40~45mm) and/or a smidge wider. But if it's between that and light weight, I prefer the light weight...
Autofocus is... well, typical of screwdrive lenses on Pentax bodies: nothing to write home about. It's reasonably accurate but slow. It's not that big of a deal on a UWA zoom though.
This is overall a very enjoyable lens to use. It's currently the most used lens in my collection.
Review Date: August 21, 2021 Recommended | Price: $300.00 | Rating: 10
Pros: Sharp, nicely built, great focal range, wonderful colours, well controlled distortion, a go anywhere lens
Cons: I sold it too cheaply, I miss it, f4 is a bit slow even then.
Sharpness: 10    Aberrations: 9    Bokeh: 6    Autofocus: 10    Handling: 10    Value: 10    Camera Used: MZ5n
I used this lens with film NOT digital.
This was my most favourite lens in my time with Pentax and the excellent MZ5n.
I used it at all focal lengths usually in the f8-f11 aperture range for people at 35mm and landscape and environmental at 28/24/20mm.
This was the best zoom I have ever used. I have a much vaunted Nikkor 25-50mm AIS which has a wonderful look and is manual focus. But this little Pentax was as good as and tiny in comparison. I got rich colours, very well controlled distortion and great detail plus little or no colour aberration. Like the 25-50, this little Pentax also laughed in the face of highlights and the sun. I still have the slides to prove it.
BTW, despite the wonderful 24-50mm A zoom that I once lent, the 20-35 FA was the best Pentax 24mm I've used.
If you were in a tight spot, you could get it all in. I became addicted to this lens and it never really left the MZ5n. I only let my Pentax stuff go from 2008 because of the financial crash hurt my income through no fault of my own and I had to make cuts to expenditure etc. (like I suspect many other people around the world) It was done so reluctantly. If I am honest I still miss this lens - an equal to anything produced by Nikon and definitely anything by Canon - I've seen published shots from the EOS 20-35mm 2.8 and the Canon is not as sharp or pleasing to look at as this little Pentax (the Canon looks degraded by diffraction).
I've no idea how it performs on digital but all I can say is give it a go if you get a decent copy. You might find that it is worth it.
We bang on in photography don't we about sharpness but there is a lot more going on with some lenses and this is one of them. There's the artistic side of pictorial rendition to consider too, and there is a depth to the pictures this lens produces that other wide angles zooms just don't have. You feel that you could step into the picture; the picture has gone beyond being a picture if you see what I mean. The 25-50 Nikkor does that and so does this little Pentax.
I 'd recommend this lens to you and hope that you find what I found.
3 users found this helpful
Review Date: May 3, 2021 Recommended | Price: $494.00 | Rating: 8
Pros: small, lightweight, APS-C senzor size performance
Cons: soft extreme corners on fullframe, plasticky, aberrations
Sharpness: 8    Aberrations: 6    Bokeh: 7    Autofocus: 7    Handling: 8    Value: 8    Camera Used: Pentax K-1
This lens is very good on APS-C cameras, but on full-frame it has some major drawbacks. The image is very sharp from the centre to the edges, but the corners are totally blurry, regardless of the used focal length or aperture. Checked on 2 samples.
For some applications, it doesn't matter but do not use it for landscapes where you need sharpness corner to corner.
Fullres image here: https://i.postimg.cc/SsryJWMf/IMG3040.jpg
EDIT 08/2021: I have to raise the rating, because the corners are acceptable most of the time and it is good walkaround lens if you do not want to carry 3 primes.
Review Date: December 12, 2020 Recommended | Price: $450.00 | Rating: 9
Pros: Bonne optique, rendu, léger , plage 20-35 avec k1
Cons: Construction en plastique mais propre et assez robuste
Sharpness: 9    Aberrations: 8    Bokeh: 8    Autofocus: 8    Handling: 10    Value: 10    Camera Used: K1
This is really a nice and versatile lens with k1.
Very good optics, so light and handy.
My most used lens for landscape (I have 12-24 da, dfa 24-70. 2.8, k17 F4. , dfa 28-105., F17-28mm , hd fa 35mmf2 ’etc)
The zoom range is perfect , with my zoom F 70-210mm I have a good easy to carry allround kit for bright days. Shooting almost always between F5,6 to f11
The COLOR rendering is nice (ghostless coat as limited lens) and special. It’s maybe the only lens I don’t use post processing colors because I feel to lost a kind of special native rendering I like. Warm and a kind of small 3D pop ( nothing to compare with the 3D blue rendering of my fa77mm but really noticeable special rendering)
So remember, maybe not a pro star lens but a very good lens is a lens you use and always bring with you. And k1 is heavy...
I bought the new dfa 15-30.....maybe better but it mostly stays at home and will end by resale this heavy tank...
Really a nice little zoom. A prosumer zoom as Pentax used to say about it
Review Date: January 7, 2020 Recommended | Price: $400.00 | Rating: 8
Pros: Light and compact, nice range on FF, fast enough
Cons: PF, not as good as Limited lenses
I got this as a landscape-cityscape equivalent to the DA21 on full frame. It's a good lens, but a mixed bag.
It's capable of very good sharpness. Distortion is low. It creates superb starbursts when used properly (not as good as the DA21).
However, it suffers from some PF, and most of all it does not have the magical pop of the images created by other Limited lenses. I have a hard time warming up to it. No real flaws, but no magic either.
Review Date: March 25, 2019 Recommended | Price: $300.00 | Rating: 8
Pros: Light, IQ, Cheap(ish)
Cons: Plasticky, F4, if that bothers you as wide open
Sharpness: 9    Aberrations: 8    Bokeh: 6    Autofocus: 8    Handling: 8    Value: 9    Camera Used: K1
Picked this up along with an Fa 50mm Macro for a very reasonable price, here in Australia. It's showing its age a little, both in terms of slow aperture and rather cheap, plastic body. However, it performs well and punches well above it's weight. I'm sure the 15-30mm beats it on every aspect, but it's 3 times as big and probably 3 times the price.
For a casual photographer like me, it does the job. Very nicely
These shots were taken handheld, with a CPL filter, but I suspect that it would perform better on a tripod, with some ND filters. Certainly, for landscape.
Shots taken at Sunshine Coast, Queensland, on a K1, F8-F11
Addit- Had a go with some ND filters for the first time and reasonably pleased with the results. I'll definitely keeps this lens.
Review Date: March 3, 2019 Recommended | Price: $150.00 | Rating: 9
Pros: Excellent lens on APSC, just O.K. on Full-Frame. Can be found used for peanuts but an excellent value overall.
Cons: Corners a little soft @ 20 mm on FF.
Sharpness: 9    Aberrations: 8    Bokeh: 7    Autofocus: 10    Handling: 10    Value: 10    Camera Used: Pentax K5, K3, K1
Picture taken on a K5 @ 20 mm.
Picture taken on a K3 @ 35 mm.
Picture taken @ 35 mm on a K1 with a CPL.
Picture taken @ 24 mm on a K3.
20 mm FL on K3
24 mm FL on K3
28 mm FL on K3
35 mm FL on K3
24 mm FL on K5
20 mm FL on K5
20 mm FL on K5
Review Date: August 28, 2018 Recommended | Price: $250.00 | Rating: 10
Pros: lightweight, platic wonder but very good quality.
Cons: nothing !
Sharpness: 10    Aberrations: 10    Bokeh: 9    Autofocus: 10    Handling: 10    Value: 10    Camera Used: K-x
My main lense, alway on my camera. Very goog, no probleme with digital camera... My favorite.
Review Date: January 3, 2018 Recommended | Price: $700.00 | Rating: 10
Pros: sharp, colors rending, light
Cons: none
Sharpness: 10    Aberrations: 9    Bokeh: 9    Autofocus: 10    Handling: 10    Value: 10    Camera Used: K3
A terrific standard zoom lens for landscape photography!
I sold my very loved FA 20mm 2.8 to get this lens.
It was a good choice, for sure !
Review Date: December 28, 2017 Recommended | Price: $200.00 | Rating: 8
Pros: Sharp from f/8, lightweight, price, fast AF.
Cons: "Plastic" build, CA.
Sharpness: 8    Aberrations: 7    Bokeh: 7    Autofocus: 9    Handling: 8    Value: 10    Camera Used: K-1
Good wide angle lens for K-1, except heavily CA at 20mm, but you can easily remove in LR.
Her sample:
2 users found this helpful
Review Date: August 31, 2017 Recommended | Price: $460.00 | Rating: 9
Pros: Sharpness, Focal length on FF, lightweight, color, micro contrast
Cons: build quality, feels "plastic", flare, No WR
Sharpness: 8    Aberrations: 7    Bokeh: 6    Autofocus: 7    Handling: 8    Value: 8    Camera Used: K1-K3
The main quality of this lens for Pentax FF camera is the focal length, great for landscapes, cityscapes and architecture.
This was the reason I bought this one used, in great conditions, instead of the more expensive Pentax 15-40mm /F2.8
I was nicely surprised by the sharpness of the lens, where is shines from F5.6 to F13, sweet spot is /F9 to /F11 on my copy.
I've been using this lens at F22 from time to time, useful for some nice "STAR" type bokeh on sun of nightlights, and it's perfectly usable despite the loss of sharpness.
The flare is sometimes very prominent and disgraceful, so you have to think about it when shooting toward sun or on some nightlight cityscape for example.
One point to be of interrest is that this lens is pretty compact and lightweight, a perfect companion to the Pentax K1 when hiking for example. The missing WR is to be noted if you wanna use this lens for landscapes shooting.
Some example shots, mainly taken at this lens sweet spot of F8 to F13 :
"Star" effect on the sun :
I would definitly recommend this lens for landscape shooting, especially on the Pentax FF K1 Camera. The ability to add a ND or Polarised filter is also worth noting.
Review Date: August 29, 2015 Recommended | Price: $500.00 | Rating: 9
Pros: Painterly rendering, beautiful color
Cons: A little on the soft side of sharp
Sharpness: 8    Aberrations: 9    Bokeh: 9    Autofocus: 9    Handling: 9    Value: 9    Camera Used: K3
I purchased this in anticipation of wanting a short zoom in advance of the FF and because I find that I like the rendering of some of the FA lenses. Plus I tend to shoot landscapes and water scapes, so this is a pretty good width for me.
I haven't used this a lot but I took it out the other evening. It was a great sky, and I thought this lens did it more than justice.
Here's one of the resulting photos....
Review Date: February 16, 2015 Recommended | Price: $300.00 | Rating: 10
Pros: A full-frame lens that is compact, light, sharp, beautiful colors and superb microcontrast.
Cons: A bit of lateral chromatic aberration (easy to correct)
Sharpness: 9    Aberrations: 8    Bokeh: 9    Autofocus: 10    Handling: 10    Value: 10    Camera Used: Pentax K-X, Sony A7, Pentax Z1-P
I have never used this lens a lot on APS-C because of the unappealing focus range and also because I have crop format lenses that cover a broader range with good image quality (like the DA 16-45/4).
It’s on full-frame that this lens really shines: it offers a very useful range, from super-wide to normal-wide, in a compact package with superb image quality. There is no other compact full-frame wide-zoom with constant aperture that can rival the FA 20-35 when it comes to consistently delivering gorgeous pictures with great micro-contrast and fantastic colors.
The FA 20-35/4 AL is really a small lens that takes very little space in the bag and is quite light (245g), yet it is very useful by replacing both a 20mm super-wide and a 35mm normal-wide, as well as all the focal lengths in between. It is really usable throughout the zoom range at any aperture.
At the 20mm end, the corners are a bit soft wide open, but the whole frame sharpens up nicely at F/8-F/11 –of course, people usually don't shoot landscape wide open anyway. For interior scenes or night shots where the corners are not really important, the lens is perfectly usable at F/4. I have made some comparisons with my Pentax FA 20/2.8 on full-frame and I consistently prefer the results from the FA 20-35: pure resolution is equivalent (maybe a tad better on the 20/2.8 when stopped down) but micro-contrast and colors are so much better on the zoom. Surprisingly, the zoom is also much more resistant to flare. This might be caused by the zoom having the superior "ghostless" coatings.
At the 35mm end, image quality is already very good over the whole frame at F/4 and it rivals prime lenses at F/8.
Some people seem to regret this lens’ F/4 max aperture. To me, it’s not really a limitation given the high ISO capability of modern cameras and I would even say this is rather a big advantage because it allows the lens to be very compact. As a bonus, the lens extends only a tiny bit when zoomed in and focused close. With the lens shade on, you will not even notice the length variation.
Lateral chromatic aberration is a bit strong at 20mm, especially wide open, but it cleans up easily without leaving any residue. There is no visible LCA at 35mm.
Distortion at 20mm is noticeable on straight lines running next to the edges (though not bad at all for a wide-zoom) and vignetting is visible wide open, but both are quite easy to correct if necessary (distortion is the common spherical type). Distorsion and vignetting are negligible at 35mm.
I give this lens a rating of 10 not because it is perfect but because it has many unique qualities that largely overcome its few drawbacks. It has been my most used lens for the last year on a full-frame Sony A7, constantly delivering outstanding results. Together with a Voigtländer Nokton 58/1.4 and a C/Y Sonnar 100/3.5, it makes a very light and portable full-frame kit that I carry everywhere. I guess the FA 20-35 will also perform superbly on the forthcoming Pentax full-frame DSLR.
Cheers!
Abbazz
Review Date: February 6, 2015 Recommended | Price: $398.00 | Rating: 8
Pros: Great focal range on film. Good optics.
Cons: Plastic, too slow and poor handling. Expensive.
Camera Used: Pentax film bodies
The FA20-35/4 zoom is a relatively new lens and could be considered an update to the 1980’s Pentax M24-35/3.5 zoom. The FA20-35/4 was released in 1998 and remained in production until a couple years ago.
Optics:
For a zoom lens the FA20-35/4 has good optics, however it’s not better than a prime lens with a focal length in its zoom range. My K20/4, K24/2.8, K24/3.5, K28/2, K28/3.5, K30/2.8, K35/2 & K35/3.5 all have better optics and less distortion. Used on a FF film body the FA20-35/4 does have noticeable corner distortion, a cropped DSLR will hide some of these issues.
Focal Range:
The best thing about the FA20-35/4 is its focal range on film, as it covers the end of the ultra wide range and the entire regular wide angle range. This makes the FA20-35/4 a great traveling option for me if I only want to take one wide angle lens on a trip. On APS-C this lens looses some of it usefulness and is just another wide to normal zoom.
Build:
While it’s nice that the FA20-35/4 only weighs 245 grams and is camera bag friendly, there is a resulting trade-off. Everything on this lens is made of plastic except the metal lens mount. At least the finish is not that easily scratched silver one that was used on many FA zooms and it should hold up over the years.
Usage/Handling:
Manually focusing the FA20-35/4 is a bit awkward, as the focusing ring is smooth, narrow and is right under the filter thread. Your fingers naturally gravitate towards the zoom ring which is much wider and has a more bumpy texture. I don’t have a camera body that supports auto focusing, so I can’t comment on that feature. I prefer a push/pull zoom design, which would have made things much simpler than using this two touch lens. The FA20-35/4 has a 58mm filter thread,
One weird thing about the FA20-35/4 is that there is no half stop aperture (F/13.5) between F/11 and F/16. This is the first Pentax lens that I have seen where you only have F11, F16 then F22, strange and annoying!
The FA20-35/4 has a modern tulip style bayonet lens hood (PH-RBA 58mm), which fits around the end of the lens and does not touch the filter thread. The hood also has a removable window so you can turn a mounted polarizer filter. The FA20-35/4 comes with the S90-100 soft lens case, which has enough room to also hold the hood.
Speed:
F4 is too slow for me and the FA20-35 should have been at least an F3.5, like the M24-35. Pentax really should have turned this into an F* 20-35/2.8 zoom, with better optics and build. Then we might have a classic zoom lens on our hands. At least the FA20-35 is a constant aperture zoom, which I like much better than the variable ones.
The FA20-35/4 vs the M24-35/3.5:
I also own the older M24-35/3.5 zoom and this is how I rate the winner in various categories:
- Optics: Tie
- Focal Range: FA20-35/4
- Build: M24-35/3.5
- Usage/Handling: Tie
- Speed: M24-35/3.5
I’m a bit disappointed with the FA20-35/4, as I though it would be much better than the older M24-35/3.5. In reality the FA20-35/4 is only better in the focal range and I prefer the M24-35/3.5 overall.
Summary:
As a film only shooter, I’ll use this zoom as my wide angle lens when I want to travel light. It’s not as good optically as my K series primes in this focal range, but good enough when you want the convenience of only one lens. I would have given the FA20-35 a 9 if its handling was better and it was faster.
Overall I rate the FA20-35/4 an 8.5, the same as what I gave my M24-35/3.5
Sample shots taken with the FA20-35/4. Photos are medium resolution scans from original slides or negatives
Camera: K2 Film: Fuji Sensia 100 ISO: 100
Camera: KM Film: Adox Silvermax ISO: 100
Camera: MZ-S Film: Kodak Pro Image ISO: 100
All times are GMT -7. The time now is 06:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
