| Author: | | Showing Reviews 1-10 of 10 | | Pentaxian Registered: May, 2007 Location: Singapore Posts: 3,721 1 user found this helpful | | Lens Review Date: May 16, 2008 | I can recommend this lens: Yes |
Price: $40.00
| Rating: 8 |
| Pros: | Nice size, adequate quality wide range zoom | | Cons: | Average optical performance | | Got this lens from a computer repair shop! Very cheap and it was in excellent condition.
The lens is stubby and fat, made by Tamron and features a narrow rubberised focusing ring and a wide rubberised zoom ring. The focus throw is very short and the lens has a close up setting on the focusing ring. Visually the lens looks like a small mirror lens and it takes 72mm filters. Focusing in AF is fast and zoom ring is positive with no hint of zoom creep. Lens is shortest at the 28mm and there is a two part barrel that extends fully at 200mm. The lens uses a bayonet lens hood which was missing on mine. There are no DOF scales. Lens mount is metal and overall build quality is quite good.
Optically it can be a little soft at maximum aperture and at the longest focal length but when stopped down and used at the shorter focal lengths, image quality is about standard for a superzoom. Distortion is about normal for a superzoom. Best between 35 to 150mm or so.
For some strange reason I kinda like this lens and will use it for occasions like holidays when I can only use 1 lens. A convenience lens but one that has been overshadowed by newer zooms that go much wider at the wide end. | | | | | Pentaxian Registered: August, 2010 Location: Toronto Posts: 8,232 | | Lens Review Date: January 18, 2011 | I can recommend this lens: Yes |
Price: N/A
| Rating: 7 |
| Pros: | good range (particulrly on film) light fast af | | Cons: | soft at longer than 135, low contrast, not super sharp | | I've had both the Pentax and the Tamron variant on this lens (the Pentax came with my mz5, the tamron was a replacement after the dog knocked it out of my hand and it was damaged)
Like all the above I think this is probably an undervalued lens to some degree. I've traveled a lot with this on the mz5 and got some very good results from wide to say 135 or so and acceptable results beyond.
I also used it pretty extensively on my early digital (*istds) for lack of an alternative. Z
Zoom creep is an issue when shooting down from above particularly. without the hood it can be pretty soft (In bright daylight i usually shot with a CP attached)
At the price it is available at now i would think it's a pretty reasonable little travel lens and that is why i still have mine for the most part
If you are looking for an inexpensive superzoom to experiment with and aren't expecting the iq of some of the newer ones or primes you will be pleasantly surprised. if you are a little more demanding of the lens though you llikely want to look at other alternatives.
this would have been one of my early digital shots with this lense  IMGP0380-01.jpg by Eddie Smith, on Flickr
| | | | | New Member Registered: June, 2009 Location: Chattanooga, TN Posts: 5 | | Lens Review Date: December 5, 2010 | I can recommend this lens: Yes |
Price: $50.00
| Rating: 8 |
| Pros: | Size, design and construction | | Cons: | Soft at long focal lengths | | Like several of the other posters I just really like this lens. My favorite lenses are wides but for an all purpose lens this fits the bill for me. Being a lens designed for film cameras and with my using it on the K10D it ends up being a "prime" length to really long telephoto. For the price I paid it can't be beat! Yes, it tends to be soft at the longer lengths and wider apertures but that usually can be taken care of in editing the "keeper" shots. I really like the size and shape of this lens and even though it feels like a rock it gives me a level of confidence in it's durability and toughness. All in all I wouldn't sell this lens unless I was changing systems!
| | | | | Senior Member Registered: December, 2009 Location: East Yorkshire Posts: 102 | | Lens Review Date: October 10, 2010 | I can recommend this lens: Yes |
Price: $60.00
| Rating: 8 |
| Pros: | Good zoom range for film. Reasonably small when set at 28mm | | Cons: | Not brilliant for digital. Looks very plastic. | | I really like this lens, I know that I should not but I do. It may not be the sharpest lens available, but then again it is not soft. It has to be the shear convenience of it. Sometimes you do not want to walk around with a bag full of equipment either because its too cumbersome or you are in conditions were you don't want to changing lenses a lot such as on the beach. I use it when I am hill walking or in areas were I'm just being a tourist.
This lens has converted me to the cause of the 'superzoom', something that I was against since owning a Vivitar 35-200 in the mid 80s which was probably the worst lens ever made.
| | | | | Pentaxian Registered: January, 2008 Location: Brampton, ON, Canada Posts: 642 | | Lens Review Date: September 21, 2010 | I can recommend this lens: Yes |
Price: $200.00
| Rating: 7 |
| Pros: | Very fast AF on Film, useful range and aperture | | Cons: | soft at each end, creep, strong pincushion distortion when zoomed | | I owned this lens for several years, and used it on an MZ-5n, and a *IST DS.
All review comments are pretty accurate.
Really good as a single lens travel solution - size and aperture at the zoomed end were seldom a problem. Creep was annoying at times, but with a compact crumpler bag, I was able to sling it like a gun and avoid the issue.
It *can* be sharp - in good light and with a better hood (a collapsable rubber one worked quite well) - it is very prone to contrast loss (due to the large front element I guess). Colour also OK with respect to this.
Pin cushioning of horizons is pretty bad at full zoom, best at around 135mm. A bit narrow at wideangle FOV on an APS circle.
*Very* snappy AF on a film slr due to the short focusing ring throw.
| | | | | Site Supporter Registered: June, 2010 Posts: 45 | | Lens Review Date: June 6, 2010 | I can recommend this lens: Yes |
Price: $100.00
| Rating: 6 |
| Pros: | wide zoom range, some close focus ability | | Cons: | soft images | | This lens produces images that look nice as 4x6 prints. The closeup focus is fairly useful as well.
However, look any closer and softness is easily noticeable.
When shooting closeups of objects with small lettering, the lens does not produce sharp edges until f/9. From f/3.8 to f/7, the lettering is significantly softer than the DAL 18-55, almost to the point of illegibility. This lens also performs worse than a Kodak Z740 camera in this situation. There is also significant softness at image edges.
I measured the minimum focus distance and field of view (on a K-x) at the various focal lengths:
28mm: 48cm min, approx 40x25cm (larger than my cm grid)
35mm: 53cm min, approx 40x25cm (larger than my cm grid)
50mm: 52cm min, 27x18cm
70mm: 41cm min, 18x12cm
100mm: 31cm min, 11x8cm
135mm: 29cm min, 10x7cm
200mm: 62cm min, 14x10cm
As the numbers show, magnification peaks at 135mm.
Due to the weight of the lens, there is zoom creep. However, this only occurs when the lens is already extended past 70mm or so; the lens just slides out to the full focal length if pointed down.
Overall, this is an ok lens if it's available for a low price.
Edit: I came to realize that the slight looseness in the front element is not normal. It's reverse threaded (looking at the lens from the front), so I put a suction cup on it and tightened it up. After cleaning the glass, I did another informal resolution test. Still not super sharp, but sharper than before. Rating and recommendation has been revised.
| | | | | Site Supporter Registered: August, 2009 Location: Elko, Nevada Posts: 272 | | Lens Review Date: October 30, 2009 | I can recommend this lens: Yes |
Price: $200.00
| Rating: 9 |
| Pros: | Excellent range, decent IQ | | Cons: | Weight, some lens creep in manual focus | | I have owned this lens since 2001 and it has been one of my favorite lenses since the day I got it. This is not because it provides drop dead image quality, although my copy actually does pretty decent, but because it is so versatile. Although I do have the DA 18-55mm for my K200D I could sell it and not miss it at all since this lens is really my true "kit lens".
I travel a lot for my job and this is the one lens that goes with me on every trip and I never feel undergunned. If needed I can go from telephoto to normal and all the way down to a usable macro. Don't get me wrong, its' not the perfect lens at any of those focal ranges, but it handles them pretty well. When I go to one of my grandkids activities, sports or otherwise, this is the lens that gets grabbed and the autofocus is quick enough to capture pretty quick movement. I rarely miss a shot because I couldn't get focused. The aperture range can sometimes be a bit challenging at night but, with ISO 1600, it brings back very decent photographs. And I almost always switch to manual focus for my macro shots. In fact, this is the only area where I have any complaints at all. First, the manual focus adjustment is very short with this lens so it can be challenging to macro photos properly focused. Second, while it is in manual focus the zoom can creep if you aren't careful.
Even though the crop factor has changed this lens from a 28-200mm on my 35mm SF1n to a 42-300mm on my K200D, it has made that transition very gracefully. It is a bit heavier then some of my other lenses but it always felt perfectly balanced on my SF1n and is almost as nice on my K200D. In fact, since it is a bit front heavy on the K200D, I find I am pretty successful with handheld shots at all the focal ranges.
This is not the lens I grab if I am feeling artistic, but it is my first choice if I am out to record those fleeting memories.
Here is an example from a recent trip to Sidney. | | | | | Veteran Member Registered: August, 2009 Location: Perth, Western Australia Posts: 415 | | Lens Review Date: September 7, 2009 | I can recommend this lens: Yes |
Price: $350.00
| Rating: 7 |
| Pros: | compact, light, wide range, surprisingly good optically; front element doesn't rotate when focussing | | Cons: | not wide enough on digital SLRs | | The FA28-200 (which is in my opinion is actually more like a 28-190) is quite an underrated lens. I owned this lens between 1997 and 2002. I found it to be quite sharp and contrasty with well controlled distortion and little light fall-off.
It is quite good by any measure between 28-135 but is soft at the 200 setting.
In fact, to my surprise, I found that in the 28-135 range it was as sharp wide open, as my A50 f1.4 was wide open. (Of course the 50mm was much sharper when the two lenses were compared at the same f-stops - and had much less edge distortion.)
Otherwise, a little slow at the long end and in the digital age, and not wide enough at the short end.
In summary, a great lens if you need the range but want to travel light or dislike changing lenses. However like most superzooms, it doesn't quite match up to the image quality you would get using two zooms to cover the same range (having said that, it wouldn't be far off though).
| | | | | Veteran Member Registered: June, 2009 Location: Mid North Coast,Australia Posts: 825 | | Lens Review Date: July 1, 2009 | I can recommend this lens: Yes |
Price: $70.00
| Rating: 7 |
| Pros: | Compact size with good focal length range | | Cons: | Soft,soft,soft!!! | | If your limited with carrying space in your bag,then this lens would be the answer.The only down side to it,is it isn't the sharpest tool in the shed,so to speak.My copy came of a MZm,and have been using it on a K100D.But for a all round general purpose,this lens isn't that bad.If you find one going cheap,why not buy it.
| | | | | New Member Registered: June, 2008 Location: New Plymouth, ID Posts: 5 | | Lens Review Date: January 11, 2009 | I can recommend this lens: Yes |
Price: $270.00
| Rating: 7 |
| Pros: | Versatile range of focal lengths | | Cons: | somewhat soft at longest focal length, zoom creep | | As the previous reviewer stated, this lens is a bit soft at the longest focal length and all focal lengths at maximum aperture. Best used around f8 (for sharpness) and good when used as a wide angle lens (that's where I've given it the most use). Varifocal, so refocusing is needed when changing focal length but usually taken care of by auto-focus camera function. Maximum aperture changes from f3.8 to f5.6 over the zoom range. Non-rotating front filter mount (internal focusing) - originally sold with a petal shaped lens shade that attaches bayonet style to the front of the lens. When installed, the lens shade makes changing filters difficult. I rarely use the shade and haven't noticed much flare except when shooting with the sun within about 45 degrees of lens axis or less. I've used mine for well over 15 years now (purchased new with my camera) and it has held up well with the exception of increased zoom creep when carrying the camera with the lens pointing downward. Used it in dusty environments and no internal dust visible indicating reasonable seals. The primary thing I like about this lens is its flexibility to cover a fairly wide range of focal lengths (wide to telephoto) in a compact size and light weight body. Closest focusing is at 135mm f.l. (12 inches from front of lens). It was advertised as having "macro" capability but it doesn't really replace a true macro lens. Overall, good performance as a non-critical lens and great versatility given sufficient light, replacing a number of prime focal lengths commonly used.
