Author: | | Loyal Site Supporter Registered: October, 2018 Location: Quebec City, Quebec Posts: 6,633 1 user found this helpful | Review Date: September 30, 2023 | Recommended | Price: $574.00
| Rating: 10 |
Pros: | Sharp, fast short telephoto lens. | Cons: | Expensive, heavy. | Sharpness: 10
Aberrations: 9
Bokeh: 10
Autofocus: 10
Handling: 10
Value: 9
New or Used: Used
Camera Used: K3 III, K1
| | I found a recent model of the FA* 85 mm on eBay in perfect condition. The lens is compact and quite heavy. The sunshade is made of metal and weighs almost as much as the lens itself ! I don't take portraits and the lens will be used mostly for landscapes and architecture. I took my first pictures with my K3 III, where it behaves like a 130 mm medium telephoto. I tried a series of handheld images @ f/16, @ f/8, @ f/4 and @ f/2 of the Batiscan River (one of my "benchmark sites") in sunny conditions : @ f/16
The last picture taken @ f/2 shows the separation possible between the different planes of the image. Focus was set manually on the rock in the foreground. It is rather sharp while the main subject (the wide rock outcropping) about 30 feet further away remains fuzzy. This permits "subject isolation" or selective focus if the need arises. Personally I prefer allover edge-to-edge sharpness and you get this effect magnificently @ f/8, where DoF masks focusing errors. Up to now, f/8 to f/16 seems to be the OPTIMUM APERTURE range to get perfect landscape images.
Today I mounted it on my Pentax K1. For landscape purposes, f/11 proved to be the OPTIMUM aperture opening on a Full-Frame sensor.
An expensive lens but very sharp and providing an interesting field of view, although most users will dedicate it to portraiture.
New images taken adding an old Pentax A 1.4X S converter to the FA* 85 mm :
When you start with a sharp prime, the converter does not degrade images at middle apertures (f/4 here). | | | | | Senior Member Registered: October, 2022 Location: Glyfada, a southern suburb of Athens Posts: 208 1 user found this helpful | Review Date: September 19, 2023 | Recommended | Price: $750.00
| Rating: 10 |
Pros: | superb colors, creamy bokeh, lens with character | Cons: | old fashioned screwdrive autofocus, no WR or AW sealings | Sharpness: 10
Aberrations: 10
Bokeh: 10
Autofocus: 7
Handling: 10
Value: 10
New or Used: Used
Camera Used: K1ii Limited
| | A masterpiece design of the legend, Jun Hirakawa, that prioritizes in heart loving
colors and sweet rendering over clinical sharpness and modern technicalities. A lens with an amazing character!
photo straight out of K1ii Limited, @ f/1.4, 1/50s, ISO1600 | | | | New Member Registered: July, 2022 Posts: 2 2 users found this helpful | Review Date: February 17, 2023 | Recommended
| Rating: 10 |
Pros: | Gem. I like everything with it. Fantastic lens! | Cons: | Not much to say other then focus. Size for some maybe? | Sharpness: 10
Aberrations: 9
Bokeh: 10
Autofocus: 9
Handling: 9
Value: 10
New or Used: New
Camera Used: Pentax KII
| | Ohhh.. what a lens. Its a special one thats for sure and used right its probably one of the best 85mm in history. Ive put it trough the worst situations with the worst light and conditions, and still it produces. Many times its almost like i cant belive it... Focus is old but it works good enough to get the job done for me.
The only thing i dont like is the rubber thing on top of it But it works so its just a non issue.
Is it the best in the world? I think you can say that whitout lying, but the autofocus make it a hard case to defend in 2023.
| | | | New Member Registered: August, 2021 Location: SEVA Posts: 3 2 users found this helpful | Review Date: November 23, 2022 | Recommended | Price: $725.00
| Rating: 8 |
Pros: | Beautiful images when you wrestle it into submission | Cons: | Focus is slow and hunts a lot | Sharpness: 9
Aberrations: 7
Bokeh: 8
Autofocus: 6
Handling: 10
Value: 8
New or Used: Used
Camera Used: K-1ii
| | I bought this lens to complement my D-FA* 50/1.4 because I could not justify the cost of both D-FA* lenses, but in many ways I wish I had gone with the D-FA* 85 and found some other solution for a fast modern 50. (Why is there no FA* 50? The world may never know.) As such, I'm writing this review as a sort of comparison to the D-FA* 50, which isn't fair, but I expect that I'm not the only person who is in this position.
What I did get from this lens is wonderful, but I'll start with the frustrating stuff. Focusing
This lens uses the old screw drive focusing system. It is loud, slow, and it hunts a lot. You won't be using this lens to shoot any fast-moving nearby objects.
We're primarily using DSLRs, so I'm focusing and recomposing. I find that in difficult lighting scenarios (strong sunlight, back light), the camera gets confused. It will focus on the bright spots (usually the model's hair), or sometimes just nothing at all. If there is a lot of 3D-pop in your photo, it will also be unsure of where you're trying to look and will focus on things in your intended foreground or background. Sometimes, being just barely out of focus on your model.
I find that in these scenarios, it is best to just pop it into manual and leave it there.
Where the autofocus works best is in a studio setting. Put the camera on a tripod, the autofocus will get you within 95% of where you want it. I will disagree with what the camera wants to focus on, but snapping the lens into manual focus and taking over is easy enough. It also works well for shooting groups where everything is farther away, but that's just putting less strain on the system. Sharpness and Aberrations
It's frustrating that the focusing system is so lackluster because you can get some really tack sharp images out of it when you nail that focus. I use this lens primarily for portraits and I find that it is almost too sharp and I need to do a lot of post on skin texture to reel it back in a bit.... at a few stops down.
The optics on this lens occupy that strange place at the top end of film lenses without quite getting to the technical perfection of digital era lenses. Stopped down, you won't notice a difference between this and modern top-of-the-line fast 85s, but wide open it has problems. (And that's sad because it's a 1.4! Why wouldn't you use it wide open?) Wide open, you'll get pretty unpleasant CA, some ghosting, and a general lack of sharpness, especially in strong light. Bokeh and DoF
The out of focus areas wide open are very nice, but there is nothing special. No unusual effects, not much flare. Generally, the bokeh is unobtrusive and functional. The lens doesn't easily produce unusual artifacts stopped down. Wide open, things are pleasant with some slight cats eyes at the edges of the frame. Generally, it is professional and unflappable in this department.
The DoF is interesting. Even stopped down, the in focus areas are noticably sharper than just ahead and behind. Falloff is very quick. You do not have any luxury of getting in the 'in focus' range and calling it good enough. You will notice things slightly out of focus at f4. Of course, this adds to the challenge because of focusing difficulties.
But, this adds to the 3D pop effect. Good shadows and even a few things passing through the focus distance will make your photos feel hyper real in this way. It's a real joy! Handling
The lens handles beautifully. Snapping into and out of manual focus is quick, easy, and intuitive. The lens picks up where you leave off right away. Focus throw is short and responsive. It feels a bit plastic-y, but this might just be comparison to the Takumars and Pentax-K lenses I'm used to.
The aperture ring is badly placed, but I almost never take it out of automatic mode anyway. It is nice to have there at all. Theoretically, you could use this lens on a dumb camera, with no electrical connections.
My one complaint is that the stock lens cover can't be removed while the lens hood is in place. Also, the lens hood is solid when mounted, but it is flimsy when in the 'storage' position (backwards). Mine was broken in shipping. Just be careful with it and don't ship it assembled. just a very basic portrait with one light plus some fill, closed down slightly. I did miss focus just behind her eye, by about 1/2" this is unedited (except crop) to show CA wide open in demanding circumstances. Also, it is soft. But, decent bokeh, even for a full-body portrait. we had fun on this beach photoshoot. Don't even bother with autofocus here. Just be in manual and be happy. | | | | | New Member Registered: September, 2016 Posts: 2 | Review Date: August 25, 2021 | Recommended | Price: $725.00
| Rating: 10 |
Pros: | legendary item, sharpness, bokeh, colors, f1.4 | Cons: | cannot remove lens cap with hood on | Sharpness: 10
Aberrations: 8
Bokeh: 10
Autofocus: 8
Handling: 8
Value: 10
New or Used: Used
Camera Used: Pentax K-1
| | Lens made to be loved. Absolutely sharp and lovely images straight from wide-open. The separation of the background at f/1.4 is awesome. Very reliable AF even in PDAF, in live-view the results are almost 100% in focus.
Crop at f/2.0 | | | | Moderator Registered: July, 2011 Location: Melbourne Posts: 1,773 4 users found this helpful | Review Date: June 30, 2019 | Recommended | Price: $1,500.00
| Rating: 10 |
Pros: | Portrait pop | Cons: | none optically just that fragile silver paint | | I have enjoyed this lens, a large hunk of glass with a delicate silver painted finish. The SMC FA* 85mm 1:1.4 IF really delivers a wow factor in portrait photos, the transition from in focus to out of focus is lovely and smooth and the bokeh is buttery smooth. I calibrated the lens using a focusing tool and it does exhibit purple and green fringing on the edge of high contrast transitions in out of focus areas. After doing the test I assumed it was going to be a month of post processing to remove the fringing in all my photos. In real world use I didn't have to do any post processing, maybe it was just the subjects and lighting I used over the month, but I never noticed any until the last day when I saw the reflections of 100 led lights on my wife's glasses frame with some fringing in the out of focus areas. Not a normal lighting setup and only seen when pixel peeping. While the lens is screw drive I never noticed any hunting when mounted on the K1 and the focus was quick to lock on. One thing that all fast lenses have a need for is accurate focusing as when used wide open the area being in focus can be down to just 1cm. I found using the single point focus and repositioning gave me good accuracy for focusing where I wanted. The minimum focus is not close , but not unworkable at all, I tried it with extension tubes and it worked fine.I used the lens to produce several pleasing photos using lightroom to stitch several photos together, this helped me when a wider view was required in landscapes and also to try the brenizer effect which I enjoyed. This lens sat in my cupboard all through the APS C years as I just didn't feel it compared to the 35mm feel on film, with the K1 it feels just right again. Used for landscape, the slight telephoto helps isolate the details in the photo. I have found my love for this lens all over again. 85 lenscal by Gary Wakeling, on Flickr arthur by Gary Wakeling, on Flickr loose nut by Gary Wakeling, on Flickr taxi55 by Gary Wakeling, on Flickr dry boat by Gary Wakeling, on Flickr security by Gary Wakeling, on Flickr hair today by Gary Wakeling, on Flickr those eyes bw by Gary Wakeling, on Flickr
The favourite photo from the month came near the end of the month and I am aiming to have it enlarged and printed for my wall, thanks to this wonderful lens. early prom by Gary Wakeling, on Flickr[COLOR="Silver"]
| | | | Forum Member Registered: August, 2018 Posts: 72 1 user found this helpful | Review Date: August 28, 2018 | Recommended | Price: $900.00
| Rating: 10 |
Pros: | The legend. Incredible build quality. | Cons: | Nothing ! | Sharpness: 10
Aberrations: 8
Bokeh: 10
Autofocus: 8
Handling: 10
Value: 10
New or Used: Used
Camera Used: K-x
| | My K-x camera has found its limits with this lens. A lot of difficulty for the focus.
But when it works, it's incredible. | | | | Junior Member Registered: March, 2015 Posts: 41 2 users found this helpful | Review Date: April 18, 2018 | Recommended
| Rating: N/A |
Pros: | it is a razor! | Cons: | price | Sharpness: 10
Aberrations: 10
Bokeh: 10
Autofocus: 10
Handling: 10
Value: 8
New or Used: Used
Camera Used: k30
| | I've bought this lens a couple of years ago and when I have a look to the pictures I have done I always dazzle!
I got at the same time the M82 f2, the A*85 1.4 and the FA*85 1.4. I have to say the difference between the three is so small that you cannot notice it if you print to A4 size.
Raccomenaded.
| | | | Site Supporter Registered: November, 2010 Location: New Berlin, WI Posts: 528 3 users found this helpful | Review Date: March 23, 2015 | Recommended | Price: $1,000.00
| Rating: 10 |
Pros: | Fantastic IQ (dreamy bokeh, sharp, rich colors) | Cons: | Big, heavy, loud focus, CA (from film era) | Sharpness: 10
Aberrations: 7
Bokeh: 10
Autofocus: 9
Handling: 9
Value: 9
New or Used: Used
Camera Used: K-3
| | The FA*85 F1.4 is a heavy lens with a very large hood and a fragile silver finish, definitely not the most practical lens for field photography. It's also prone to chromatic aberration, especially from F1.4 to F2.2. However this is a very special portrait lens. It delivers very sharp images, like other premium lenses, but that bokeh... is a thing of beauty, the best I've ever seen. Very dreamy.
It renders very rich and warm colors too.
Pentax definitely prioritized the IQ for portrait work with this lens, and it's a film era (discontinued) lens so I forgive the chromatic aberration, silver finish and bulkiness and only judge in terms of IQ for portrait: FANTASTIC! | | | | Site Supporter Registered: March, 2013 Location: Bletchley, Buckinghamshire, UK Posts: 340 1 user found this helpful | Review Date: March 23, 2015 | Recommended | Price: $900.00
| Rating: 10 |
Pros: | Unmatched IQ and sharpness, focus speed, bokeh to die for | Cons: | Cost, rarity, weight, hood marks easily | Sharpness: 10
Aberrations: 9
Bokeh: 10
Autofocus: 10
Handling: 10
Value: 10
New or Used: Used
Camera Used: K-3
| | I can only echo what others have said about this magnificent lens. The FA*85mm is simply the finest piece of Pentax glass I have ever owned.
Rendering and colour are simply superb. I also own the FA 77mm Ltd (i've had three copies in fact). Although a great lens in it's own right, the 77mm doesn't compare to this lens for sharpness and quality of bokeh. It is simply the king of Pentax lenses for portraiture in my eyes. The transition from in focus to bokeh is just creamy smooth. Stopped down just a little it is absolutely razor sharp.
The only downsides to the FA*85mm that I can see are rarity/cost and weight.
As a result I tend to take the 77mm Ltd out more often for family trips etc. It is far smaller and lighter. Easier to replace too, if anything unfortunate happened. The FA*85mm is just a very special lens and I count myself very lucky to own a good copy.
| | | | New Member Registered: March, 2015 Location: Paris Posts: 2 2 users found this helpful | Review Date: March 22, 2015 | Recommended | Price: $1,000.00
| Rating: 10 |
Pros: | The better one | Cons: | no SDM | Sharpness: 10
Aberrations: 10
Bokeh: 10
Autofocus: 10
Handling: 10
Value: 10
New or Used: Used
Camera Used: K20D
| | For me the best Lens pentax have made
| | | | Veteran Member Registered: July, 2010 Location: singapore Posts: 467 | Review Date: October 17, 2014 | Recommended
| Rating: 10 |
Pros: | sharp , excellent subject isolation, great colours | Cons: | large size | Sharpness: 10
Aberrations: 10
Bokeh: 10
Autofocus: 10
Handling: 10
Value: 10
New or Used: New
Camera Used: Pentax K5
| | IMGP9829 by maverick_h, on Flickr
Excellent lens for protraits. Great subject isolation, and i simply love the bokeh.
Let the picture speaks for this excellent lens.
| | | | New Member Registered: May, 2013 Posts: 2 1 user found this helpful | | | | Senior Member Registered: February, 2011 Posts: 274 2 users found this helpful | Review Date: March 1, 2013 | Recommended | Price: $1,400.00
| Rating: 10 |
Pros: | excellent portrait lens, short focus distance, sharp, nice bokeh | Cons: | hard to focus at long distance | Sharpness: 10
Aberrations: 9
Bokeh: 10
Autofocus: 9
Handling: 10
Value: 9
New or Used: Used
Camera Used: K5
| | Many reviews in this section have discussed many aspects that I wished to tell. I would say the lens performs very well in term of sharpness, bokeh, and "clean" image. The focus is good for short distance; however it is always struggling for long distance objects. Here is some pictures that I took in Oct. 2012 on my K-5
@f/2.8 HIEP5578 copy by ngnhuhiep, on Flickr
@f/1.8 HIEP5580 copy by ngnhuhiep, on Flickr
@f/2.2 HIEP5588 copy by ngnhuhiep, on Flickr
And more recently, at a garden in PA, NJ HIEP7372 by ngnhuhiep, on Flickr HIEP7337 by ngnhuhiep, on Flickr
f/1.4 HIEP7389_edited-1 by ngnhuhiep, on Flickr
| | | | Veteran Member Registered: January, 2007 Location: Warsaw Posts: 338 3 users found this helpful | Review Date: November 30, 2012 | Recommended | Price: $1,400.00
| Rating: 10 |
Pros: | bokeh, sharpness | Cons: | quite big with hood | Sharpness: 10
Aberrations: 10
Bokeh: 10
Autofocus: 10
Handling: 9
Value: 10
New or Used: Used
Camera Used: K20D, K5
| | Best portrait lens I had. My Leica 90/2 is a little similar in nature. Fantastic sharpness, great color reproduction, amazing bokeh.
Hood is great but very well fitted and durable.
These two shots are at f1.4. Few more shots | | |
