Author: | | Pentaxian Registered: December, 2007 Location: In the most populated state... state of denial Posts: 1,854 | Review Date: March 25, 2022 | Recommended | Price: $70.00
| Rating: 8 |
Pros: | Well built, great handling | Cons: | too soft wide open, green and red CA | Sharpness: 8
Aberrations: 9
Bokeh: 7
Handling: 10
Value: 10
Camera Used: K5IIs - K3III
| | Well built lens, and handles great
Very soft at 2.8, almost glowing, but from 5.6 onwards is excellent
Bokeh is neutral but pleasing
Color aberration (green and red) are noticeable wide open but almost gone at 5.6
At 2.8 can be useful for portraits and still life, as everything "glows" giving the soft/dreamy look
| | | | | New Member Registered: June, 2018 Posts: 2 1 user found this helpful | Review Date: October 13, 2019 | Not Recommended | Price: $130.00
| Rating: 7 |
Pros: | Handles perfectly, low chromatic aberrations, very nice for portraits. | Cons: | Lots of spherical aberration wide open (low contrast), not impressively sharp, corners don't improve much upon stopping down.. | Sharpness: 7
Aberrations: 8
Bokeh: 9
Handling: 10
Value: 6
Camera Used: MX, X-T3, A7
| | Wide open this lens isn't very impressive. It's got a lot of spherical aberration that causes low contrast, and resolution outside of the center isn't very good. Thankfully the image improves upon stopping down - contrast improves to good levels and so does sharpness but not by as much as one would hope. By f/8 the entire image is very sharp and contrasty but I noticed that the center always has more contrast than the rest of the frame. There's a tiny bit of focus shift that's only noticeable on digital, it goes away at f/8. Overall I never found the sharpness or contrast of this lens very impressive. Chromatic aberrations seem to be on the low side - something this lens does well. Bokeh is smooth if you consider your background, difficult backgrounds can appear busy. Flare control is only good and isn't in the league of Pentax's best (50mm 1.7M, 28mm 3.5K). Overall this lens has a character that's more suited for soft portraits, and unfortunately due to its rarity it's at a price that I would consider too high. The m42 SMC version is identical and isn't as rare or expensive, you should only consider this lens if you absolutely need the K-mount version.
Compared to the M 100mm 2.8, the M has more contrast overall (especially wide open) and sharpens up quicker in the edges. Neither lens show impressive performance in the corners, but the 100mm M is rather impressive in the center and mid-frame when stopped down a bit. Both lenses always have high central sharpness but the M always has higher central resolution due to overall higher contrast. The only areas I think the 105mm outperforms the newer 100mm is chromatic aberration correction and bokeh. Overall I personally prefer the 100mm M.
| | | | Senior Member Registered: July, 2018 Location: Stockholm Posts: 226 1 user found this helpful | Review Date: August 28, 2018 | Recommended | Price: $150.00
| Rating: 10 |
Pros: | build, balance, sharpness, rendering | Cons: | Weight, availability | Sharpness: 10
Aberrations: 10
Bokeh: 10
Handling: 9
Value: 7
Camera Used: Ricoh XR-1
| | A very well built lens like most Asahi Pentax lenses, balances lovely on a medium size camera or a Pentax ME/MX with winder.
Renders beautiful, crisp and sharp images and handles flare relatively well compared to other lenses from the period.
One lens that I will try and get my hands on again.
It is difficult to find and they command a relatively high price which is very understandable, one the best of its focal length and creates great images. Perfect portrait lens!
| | | | New Member Registered: January, 2016 Location: between Toulouse and Pyrenees Mountains Posts: 2 2 users found this helpful | Review Date: February 20, 2016 | Recommended
| Rating: 10 |
Pros: | Nice Portrait lens | Cons: | A bit soft wide open | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 9
Camera Used: K-3
| | A surprising lens, a little bit soft wide open. But sharp after f4.when in comparison with the 135f2.5 the 105 f2.8 is not far in results.
Diffraction is visible at more than f16
Very compact lens.
I d love to test it on the k-1 it can be fun ;-)
| | | | | Senior Member Registered: April, 2015 Location: Lower Saxony Posts: 181 2 users found this helpful | Review Date: November 29, 2015 | Recommended | Price: $160.00
| Rating: 10 |
Pros: | focusing is an enjoyment; long focus screw; sharp from f/4.0, as was said before | Cons: | not yet | Sharpness: 10
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
Camera Used: Pentax K-5 IIs
| | I got my copy 6 days ago, but had only 3 days with some light and less time to test so far...
and i am surprised and satisfied!
Very exact to focus, focus screws around ~ 250°; better than M 100mm 2.8 and M 85mm 2.0.
Some examples, all out of camera jpgs, Pentax K-5 IIs,with a long and tight (APS-C) 52mm in screwed rubber lens hood,
picture style monochrom + digital filter high contrast or picture style color natural.
f/2.8:
f/4.0:
f/5.6:
f/2.8 - f/4.0 - f/? | | | | Forum Member Registered: December, 2012 Location: Warsaw Posts: 83 2 users found this helpful | Review Date: April 15, 2015 | Recommended
| Rating: 9 |
Pros: | Compact, sharp, color rendering. | Cons: | "Soft focus filter over the sharp image" at f/2,8. | Sharpness: 9
Aberrations: 9
Bokeh: 10
Handling: 10
Value: 10
Camera Used: K5
| | Sample - please click an view the original picture to see how this lens can perform. IMGP7332
Great lens!!! I agree with Yoshihiko Takinami, that it has all good feeling and the charm of the SMC-K 85mm f/1,8.
Actually those two lenses are very close at f/4, then the 85mm gets an edge up to f/8, but the 105mm equals again at f/11, and gets a visible superiority over the 85mm at f/16 - f/32.
This lens is compact, not much bigger than SMC-K 28mm f/3,5.
Lens has a dreamy effect on f/2,8 but it still has very good resolution. I could compare it to an effect created by Nikon Soft Focus #2 Filter on an analogue camera. The effect is minimal at f/3,5 and gone by f/4 as seen on the picture above. Up from f/4 the lens has a tear squeezing sharpness although keep in mind that up to f/5,6 you need to be precise with focusing as missing the focus is easy.
Overall: 9/10. I do admit here that my ratings on PForums are all subjective. I rather compare the lens to my expectations I had and the original purpose - the lens was designer for + usability/cost ratio.
| | | | New Member Registered: May, 2013 Location: Jakarta Posts: 2 | Review Date: May 2, 2014 | Recommended | Price: $200.00
| Rating: 7 |
Pros: | sharpness, fast, bokeh, colours render | Cons: | price, very rare | Sharpness: 10
Aberrations: 10
Bokeh: 10
Handling: 10
Value: 4
Camera Used: K5, ME Super
| | excellent beautifull lens, unfortunately it's to pricey (related to very rare on market)
here are the sample shoots: https://www.flickr.com/photos/roe_groho/sets/72157643389371735/ | | | | Junior Member Registered: March, 2014 Posts: 27 2 users found this helpful | Review Date: April 3, 2014 | Recommended
| Rating: 10 |
Pros: | Sharp, very precise focussing, size | Cons: | rare | Sharpness: 9
Aberrations: 9
Bokeh: 10
Handling: 10
Value: 8
Camera Used: KX, GH3
| | Got this lens (mint) in combination with a black KX for 10 dollars on a second hand street market. Actually my mother bought it for me, not knowing if it would be of any use, since she doesn't know about photography that much... I guess the person that sold the camera & lens didn't know either. Thanks, mum!
I was amazed by the precise and smooth focussing. The focus throw is loooooooong; you find yourself turning that ring forever. I don't mind, it gives the feeling of a precision instrument which it in fact is. I think this lens is pretty 'exotic'. Compared to the K135mm 3.5 (which I got last week) it's much shorter, and it balances very well with the heavy KX body. On this site you can optically compare it to the M100mm 2.8; http://www.takinami.com/yoshihiko/photo/lens_test/pentax_tele.html
The 105mm at f2.8 has better sharpness than the 100mm at f5.6! Sharpness is not the most important but it shows that the 105mm is in a different class... if you can get it for a reasonable price go for it!
| | | | Veteran Member Registered: June, 2010 Posts: 753 | Review Date: May 25, 2011 | Recommended | Price: $395.00
| Rating: 7 |
Pros: | build, size, focus throw, resolution, compact, f 32 | Cons: | focus throw, metering on K20d, expensive and rare | Sharpness: 8
Aberrations: 7
Bokeh: 8
Handling: 8
Value: 5
| | This is a very nice and compact lens, attached to k20d it feels right and balanced, even more with the grip. It's quite sharp, with nice rendering of details, although FA77 is a bit more contrasty. K105 renders colours better than 77ltd IMHO. Throw of focusing ring is very long which provides very delicate and exact focusing. It's an advantage if you have time but not really a great thing for snapshots. Huge minus for this lens is metering discrepancies with k20d - stop down metering doesn't provide equal results and you'll have to figure out exposure compensation for getting even exposures. In direct comparison to A100 2.8 i think this is optically better lens however A100 is more convenient to use on dslr.
edit: with K20/4 and FA31 this lens completes the trio of best balanced lenses on k20d for me.
| | | | Veteran Member Registered: November, 2006 Location: former Arsenal football stadium Posts: 431 | Review Date: November 15, 2009 | Recommended
| Rating: 9 |
Pros: | small, light, very sharp stopped down | Cons: | bokeh can be a bit agitated, bit iffy at f2.8 | | As per above reviews. f2.8 is very soft, stopped down to f4 much tighter. Specular highlights can look a bit fierce in OOF areas. The wide aperture makes it nice and bright for focussing. You don't see many around and they're not cheap but I'm glad I got mine - a worthy alternative to the FA135 2.8 for my purposes. More enjoyable to use as a piece of engineering.
Beautifully built, albeit without the built-in hood of the M135.
| | | | Site Supporter Registered: October, 2008 Location: Vancouver, Canada Posts: 8,093 8 users found this helpful | Review Date: August 15, 2009 | Recommended | Price: $280.00
| Rating: 9 |
Pros: | Build, speed, sharpness and size. | Cons: | Lots of competition in the portrait/telephoto focal length. | Camera Used: K Series film bodies (K1000, KM, KX, K2, K2DMD)
| | The K105/2.8 is the middle of three portrait/telephoto lenses that Pentax released in 1975. (The other two are the K85/1.8 and the K120/2.8)
The K105/2.8 is the shortest & lightest of the three and shares a 52mm diameter lens hood with the K85/1.8 and the K100/4 Macro & Bellows lenses.
The K105/2.8 is fast & very sharp for a telephoto lens and gives the K85/1.8 a run for the money in this field. It’s also rated much sharper than its M series replacement, the 100/2.8.
The 105mm focal length makes for a good short to medium telephoto/portrait lens on a film camera, but it’s also very close to an 85mm, 120mm or 135mm in angle of view. Most people will find that having both the 85 & 105mm is overkill and choose only one. The same scenario exists with the 120mm and 135mm focal lengths.
The K105/2.8 is a better telephoto lens than the K85/1.8, but the 85mm is faster and has the soft focus feature, so it’s a better portrait lens. The K105/2.8 however can be picked up for half the price, so it may be a better option for those on a budget.
If you do decide on getting the K105/2.8 you won’t be disappointed and like all K series lenses the quality and build are superb. One year update August 15, 2010:
I’ve been using the K105/2.8 a lot lately for a course I’m taking on natural portraiture. The K105/2.8 has impressed me as how good it is as a street and studio portrait lens. Its sharpness is outstanding and is perfect for head shots. It’s the equal of the K85/1.8 in all areas except speed; the 1 1/3 stop difference prevents the K105/2.8 from getting a perfect 10 like the K85. I’ve elevated my score for the K105/2.8 to 9.5!
Sample shots taken with the K105/2.8. Photos are medium resolution scans from original negatives. Camera: KX Film: Ilford HP5 Plus ISO: 400 Camera: K2 Film: Ilford HP5 Plus ISO: 400 | | | | Senior Member Registered: July, 2008 Location: France Posts: 128 1 user found this helpful | Review Date: July 19, 2009 | Recommended
| Rating: 9 |
Pros: | Fast, easy to focus, great sharpness | Cons: | No f/stop control with the camera | | Bought used from a forum user, it was in really great conditions. Its excellent contrast and sharpness make it really easy to focus, and well suited for portraits.
Nice "poor-man" macro lens when used with extension tubes.
The only "issue", of course, is that its diaphragm cannot be controlled by the camera ...
| | | | Inactive Account Registered: January, 2007 Location: Sweden Posts: 13 | Review Date: April 14, 2007 | Recommended
| Rating: 9 |
Pros: | Build quality | Cons: | Manual | | Benefits- Sharp, fast and accurate, and great build quality.
Downsides- Manual.
