Author: | | New Member Registered: July, 2013 Location: Ancona - Marche - Italy Posts: 6 | Review Date: July 19, 2023 | Recommended | Price: $425.00
| Rating: 10 |
Pros: | Perfect for my works. Beautiful color rendering and geometrically correct | Cons: | Rare and expensive | Sharpness: 10
Aberrations: 10
Bokeh: 9
Handling: 10
Value: 10
Camera Used: K-1
| | Excellent optics and easy to use even in difficult situations, such as poorly lit environments or with strong backlit light sources. I use this lens mainly for full-length portraits and fashion work. | | | | | New Member Registered: April, 2021 Posts: 16 2 users found this helpful | Review Date: April 26, 2021 | Not Recommended
| Rating: 6 |
Pros: | Sharp at f8 right across, except very tip corners | Cons: | Never sharpens up at the border, even on APS-C | Sharpness: 6
Aberrations: 6
Bokeh: 6
Handling: 6
Value: 6
Camera Used: K1 K3
| | I have had this lens since 1976 (on a K2). I used on my K3 until recently acquiring an FA 35 f2 (and a K1), which I now use instead.
I always start by checking the lens focuses correctly at infinity. When I first checked the 30 2.8 on my K3 I found it was not able to focus on infinity at the end stop. I had the same issue with my M 50 1.4. Adjusting the focus end stop is straightforward on M lenses (https://www.youtube.com/watch?v=E4Mw31I5d88) and now the infinity focus end stop is set correctly.
My review is based on taking the same landscape with buildings detail and winter trees in the distance in the corners of the frame, on an APS-C K3 from f2.8 to f11 focused at infinity. Observations were made in Photoshop at 100%.
On the K3, the 30 2.8 is sharp in the centre at F4 but softens from half-way towards the border. The sharp area increases incrementally with stopping down, being best at f8 just before diffraction sets in, but it never sharpens at the borders, 10% at the border remaining soft at f8; this is obviously worse on the K1. I don't understand how this scores an average 9.4 sharpness; I give it 6.
Colour and contrast are good and there is no obvious aberration or CA.
In conclusion this is disappointing and not ideal for landscape, which is what I acquired it for. The FA 35 f2 has significantly better performance on full frame as well as APS-C and is fully automatic, and is what I now use.
| | | | New Member Registered: August, 2020 Posts: 13 3 users found this helpful | Review Date: August 30, 2020 | Recommended
| Rating: 9 |
Pros: | Really nice rendering. Beautiful colors, smooth focusing and good build | Cons: | No | Sharpness: 8
Aberrations: 7
Bokeh: 5
Handling: 10
Value: 9
Camera Used: SONY A7R2
| | The Pentax K 2.8/30
...My opinion from experience.
This is not the sharpest lens -compared to my very sharp Zeiss lenses. But I have no troubles using it for architectural photos. The bokeh is really nothing to write home about - If I have to prioritize bokeh I use an other lens. But even if corner sharpness and bokeh sometimes is very important -it is the whole expression and balance of the pictures the lens produce, the way the lens "draws" the picture and the ability to reproduce the subtle gray and color shades that counts. And not to forget the depth also called the 3D rendering. This is what I find most important, and the K 2.8/30 has a lot of these qualities.
The 30mm focal length- just between the very versatile 25 and 35mm is just perfect, and the 45mm EQ focal length on 1.5 crop/ S35 mode is a better "normal" focal length than 50mm.
I have added two fresh picture shot with my 2.8/30mm lens. I hope they will tell more than my words
A picture of a little wooden viewing bridge just after the rain had stopped - 30 August 2020
f:5.6 1/50 ISO100 - SONY A7R2
And here is the bridge tower on Long Bridge in Copenhagen - 30 August 2020
f:5.6 1/200 ISO100 - SONY A7R2
| | | | Site Supporter Registered: July, 2020 Posts: 131 | Review Date: August 20, 2020 | Recommended | Price: $220.00
| Rating: 8 |
Pros: | good build, looks; sharp for a 30mm f/2.8 lens; little field curvature | Cons: | chromatic aberration; too pricey; lack of a good dedicated Pentax metal hood | Sharpness: 9
Aberrations: 8
Bokeh: 8
Handling: 10
Value: 7
Camera Used: K10D, K-3 II, K-1 II
| | I prefer to manual-focus, coming out of three decades in 35-mm film, medium-format film, and large-format glass plates before I got into digital, and I like the build of the older K-mount lenses. I was looking for a few fast prime lenses between my D-FA 24-mm f/2 and my FA 50-mm f/1.4 lenses, and I chose this as I was looking for something small and light for landscapes when I'm traveling, as well as to do some astrophotography, so autofocus isn't important for me there. I have numerous zooms that cover the range 12-300 mm, but there's appeal to smaller prime lenses like this that are not too expensive.
Having done some shooting with this 30-mm f/2.8 lens with resolution test charts, some building photos, and some garden photos, I'm happy with the resolution from f/2.8 onwards. It can be frustrating in bright sunlight because my K10D doesn't tell me the exposure levels with this lens, and I find that its auto-shooting feature (green setting) is fine in low light but poor in bright sunlight, even with 0.5-stop exposure bracketing. So this lens will be more for low-light photography for me, moving forward, and not for use in sunlight unfortunately. The sharpness is really excellent, limited only by the pixel size in my 24-megapixel K-3 II camera. But the chromatic aberration is a problem when you look closely at images (if you just do landscapes and don't look too closely, you won't have much problem with CA). But this color fringing is a known problem with these older lenses. What is excellent is the field curvature: for a 30-mm lens, curvature is only slight and hardly noticeable unless you look closely on an APS-C image; I've not yet used this on a FF camera. The aperture ring on my copy moves well and has the 360-degree ring so that you can turn the ring from the side or the bottom of the lens easily. The focusing ring is also solid and turns about 120 degrees from infinity to closest focus.
I looked at the reviews of the 28mm, 30mm, and 35mm lenses before selecting this one (I also have the FA 35mm f/2 lens to also add to this range for me, with the option for more automated photography). I rated value as "7" because I paid $220 (incl. shipping costs, from Japan, off eBay, plus the state tax levied by eBay) and there's noticeable color fringing where you have a sharp boundary (like a branch or flower and background), but the lens is in superb condition -- all parts moving perfectly and the glass pristine. It's just that, given my comments above, its value to me is nowhere near a 9 or a 10. Mine is the earlier SMC variant of this lens; I wonder if there were any optical improvements to the later smc variant? I've noticed that other reviewers of this lens here have not commented much (or at all) on CA in this lens; I wonder if the smc variant has better coatings to reduce the CA?
photo showing the lens on my camera with round, metal, non-Pentax (wide-angle Sensei Pro) lens hood: | | | | | Site Supporter Registered: February, 2017 Posts: 1,990 2 users found this helpful | Review Date: November 17, 2019 | Recommended
| Rating: 8 |
Pros: | Build quality, overall optical performance | Cons: | a bit soft wide open, cost | Sharpness: 9
Aberrations: 9
Handling: 8
Value: 7
Camera Used: K3
| | I had wanted one of these lenses for a long time for a number of reasons -
1. I like K build quality
2. I love K colour rendition
3. 27 - 30mm is my preferred focal length for general photography on APSc.
4. Previous reviews here had me slavoring for one!
5. I have a number of K mount film cameras so it serves as 2 lenses in 1.
One came up from a good dealer I have used several times before at what I consider a reasonable price (£250) for a very good copy , optically, mechanically and cosmetically. I think this is about right considering what I have to say below concerning its' IQ and reputation. Now to my review.
I find myself agreeing a great deal with what Paseo has said in an earlier review. Frankly I find the lens over rated. Although I do think his monetary valuation is rather parsimonious.
Yes it is very sharp from f4, but wide open no so much. Yes it controls aberrations very well. However the colour rendition is much colder than my other K lenses, and I usually have to tweak images to get a less cold look.
My copy also often gets the exposure wrong on my K3, tending towards a great deal of over exposure. I do not understand why. I think the biggest problem with this lens is not that it is not excellent - it is -but there are better options out there - particularly the F 28mm f2.8, which is cheaper, produces warmer colours and is as sharp as the K30. It also provides full automation for those that prefer it (although for myself I am not that bothered by this advantage), or one of the Sigma 30mm lenses. I do not have a K 28mm f3.5, maybe one will come my way at some point, but that lens is again cheaper than the K 30mm , and also has a similar reputation.
Can I recommend this lens, Well yes, but only with certain caveats, it is after all an excellently performing lens:-
Do not pay too much
Do not expect too much
Update:-
I have been shooting the 30mm on my KP recently and the above mentioned exposure issue and coolness of the images has not been in evidence on that camera. So perhaps they are a reflection of the K3 rather than of the lens itself.
Update 2:-
A K 28mm f3.5 came my way, and I have to say on the whole I prefer it over the 30mm, but only by a smidgin. And this is purely subjective The cheaper price of the K 28mm f3.5 would make me recommend it over the K 30mm, but the 28mm is even rarer so you may be out of luck trying to source one. In terms of value for money I would order the lenses as follows:-
1. K 28mm f3.5
2. F 28mm f2.8
3. K 30mm f2.8
All of them are excellent though, and I can see why one may prefer one model over another. I happily use them all!
Finally an image from the K 30mm:- | | | | Site Supporter Registered: July, 2019 Posts: 21 3 users found this helpful | Review Date: August 23, 2019 | Recommended | Price: $206.00
| Rating: 10 |
Pros: | Sharp, great focal length, good colours | Cons: | Nothing really | Sharpness: 10
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 9
Camera Used: Pentax MV
| | I love this lens. Thanks to this forum for putting me onto it! I'm getting into wide angle portraits and you really need something sharp if you're going 35mm. Have a look at this picture and you'll see how good it is. Shot on Kodak Ektar 100 with my MV and flash AF 200S. Actually slightly over exposed because I misread the flash settings and had the aperture too open. Have corrected for it in Lightroom but if I had exposed correctly there would have been even more detail.
I've also attached a 1:1 crop. | | | | New Member Registered: October, 2013 Location: Naples Posts: 10 3 users found this helpful | Review Date: December 21, 2017 | Recommended | Price: $30.00
| Rating: 7 |
Pros: | Colors, contarst, field of view, 3d pop up, color to color transition, sharpness, k built | Cons: | Some ca in high contrast border until f4, Price/performance ratio. | Sharpness: 6
Aberrations: 6
Bokeh: 6
Handling: 8
Value: 7
Camera Used: k5 Lx Mx
| | I found this little lens in a penny market, in a great condition, attached on an perfect woring MX... and I got both for 30€ with a bit of small talk. A lucky shot, once in a while. Otherwise I'd have never hbought that lens for more than 50/70 euros. There are so many 28mm and 35mm around that price.
It's a good lens, ok, and it can produce pictures near or in pair to many limited for colours and for its typical effect of the early K series, but I totally disagree with all the hype and the overstimating rating it has here in PentaxForums and all around. It's a very uncommon piece, and only this reason can make the price rise up so much, as for the K 28mm 3.5 and so on.
It has yhe typical "K" rendition, with some of the "zeiss like" colours and tones of the limited pentax primes, plus the early SMC K series personality and a bit of the typical warm japan rendition. Nothing so uncommon. I found the same on all the best or mid level pentax K prime (24 2.8, 28 3.5, 50 1.4, 55 1.8, 85, 105, 250...ecc. ecc.) and on some FA limited (31, 49, 77). But, as many pentax K, M and A lenses, it lacks of sharpness on the edge until f 5.6, as a zoom and not as a prime, and, to be a 30mm, it has a bit too much colour aberration. It's a film wideangle, so the bokhe effect is not the best. There are so many better modern primes on APSC now around 35mm so that it is a mess to spend more than 50€ in this 30mml ens with so many compromises. SMC is great on K series, gives a Zeiss like but warmer pictures and that's why I rate this lens 7 even if CA, bokeh, sharpness and manual controls are such a limit of this lens. As the most of pentax optics, build quality is very high, but you have to use it with an adeguate hood, for APSC, or you will get soft border even at f8. The global rendition, for a non sharp-needy hobbist, anyways, is good, with a great cinematic effect and a real limited like taste, and I love it, but nowdays it can't fill the gap with other vintage primes and modern zooms, and it's impossibke to justify such a high price, if not for a collection purpouse or the use of 30mm angle on film/k1 in a manual style of photography, 60-70€ is enought.
| | | | Senior Member Registered: April, 2012 Posts: 107 4 users found this helpful | Review Date: November 8, 2016 | Recommended
| Rating: 9 |
Pros: | Size, Sharpness, Usefulness | Cons: | | Sharpness: 9
Bokeh: 9
Handling: 10
Value: 9
Camera Used: Pentax LX
| | Whenever I travel, I tend to carry with me a film SLR along with my Pentax digital gear. To make it fun and fresh, I might sometimes look for a new lens to carry along with me too. A 30mm came up in our local buy & sell a few months ago, and after looking at what is said here, I decided to get one.
No regrets with it. I had just acquired a 28mm 3.5 not too long prior and was about to bring it with me on a trip to Iceland. So there was some hesitation about getting something with just a 2mm difference in FL. Nonetheless, I decided to go ahead anyway given its rarity. I chose the 30mm for my Iceland trip primarily because it was more compact than the 28mm and saved space in my bag.
In terms of usability, it turned out to be a handy FL for me as I was taking mostly landscape shots with the occasional environmental portraits.
I was impressed with this lens on film for its sharpness and contrast. It stood out there. Here's a pic from the trip.
Shot with a Pentax LX and on Ektar 100 film
| | | | Junior Member Registered: March, 2016 Posts: 41 | Review Date: March 19, 2016 | Recommended | Price: $200.00
| Rating: 10 |
Pros: | Form function & colour rendition | Cons: | | | Between buying and selling many camera systems I found two of these rare
Pentax lenses, I sold both years ago but wish I'd kept one !
The SMC 30mm K 2.8 is said to render deep blues in a very special way,
I'm on the lookout for another one.
| | | | Inactive Account Registered: December, 2015 Posts: 1 | Review Date: February 2, 2016 | Recommended | Price: $90.00
| Rating: 10 |
Pros: | handling, sharpness, perspective, bokeh, distortion | Cons: | none, maybe they could have made it 2.0 ;) | Sharpness: 10
Aberrations: 10
Bokeh: 10
Handling: 10
Value: 10
| | i was lucky to find this lens at a camera dealers place who is specialized in repairing and CLA-ing old film SLR's. this guy has hundreds of cam's, is specialized in Nikon and Leica and knows a lot about lenses. obviously he didn't know what rare gem he had with this 30/2.8 so he proposed to sell this cutie to me for 90USD (the price for a 28/2.8). I knew about the lens from various reviews and thankfully agreed to the price.
i tested this lens with my LX in various conditions on various filmtypes and it is wonderfull in every aspect. i normally love wideopen lenses but the f2.8 still gives a nice bright finder image. the rendering of literally everything is impressive. i've shot architecture, landscape some objects and everything looks gorgeous. the detail and microcontrast ist good but not looking odd... it's natural and precise which is underlined by the very good IQ (distortion and aberrations are almost inexisting with my copy). the bokeh (in fore- and background) is soft but with this certain grit. the transition from sharp to soft has this hard to describe something which makes the image pop. i definitely have no negatives here and would recommend this lens before any of the available PK mount 28mm and also before any 35mm if you can deal with the additional 5mm width. it's not easy to find this lens but whenever you see one.. get it!
crop
crop | | | | Site Supporter Registered: May, 2015 Posts: 82 1 user found this helpful | Review Date: June 2, 2015 | Recommended
| Rating: 10 |
Pros: | Absolutely great images! Sharpness, Boke, it's all great! | Cons: | Odd focal length to get used to. | Sharpness: 10
Aberrations: 9
Bokeh: 10
Handling: 9
Value: 10
Camera Used: K-50
| | I've only done some light testing of the lens, but I'm already finding it to be one of my favorites. I am not entirely good, nor familiar with prime lenses, as this is one of only two I own. The sharpness was stunning for me. I can't get even close with my other lenses. The fact that I found this at a thrift store for only $10 means I probably got the absolute bargain of the century, on what can be one of the best prime lenses out there. | | | | New Member Registered: January, 2012 Location: France Posts: 9 | | | | New Member Registered: December, 2012 Location: Saskatchewan Posts: 10 | Review Date: November 1, 2014 | Recommended | Price: $250.00
| Rating: 9 |
Pros: | Built like a tank. Great bokken. | Cons: | MF, built like a tank | Sharpness: 10
Aberrations: 9
Bokeh: 10
Handling: 9
Value: 10
Camera Used: K5
| | I After reading PF, I couldn't pass up this lens when I found it in Cheng's camera shop in Saskatoon. The focal length is superb. I have abused this lens dropping it on ashphalt and he repaired it, which if it were plastic, it would be no more! When focused spot on, the shots are photorgasmic.
| | | | New Member Registered: October, 2014 Posts: 5 | Review Date: October 31, 2014 | Recommended | Price: $350.00
| Rating: 10 |
Pros: | Sharp/ Great Walk Around/ Has its own personality | Cons: | None | Sharpness: 10
Aberrations: 9
Bokeh: 8
Handling: 10
Value: 10
Camera Used: K-50
| | I really love this lens. It is the first prime I ever bought and I feel that I have really grown as a photographer with it.
I really like the focal length on my cropped sensor (it's a perfect walk around). It has great color rendition and although it can be easy to get lens flare without a hood that isn't always a bad thing. It is sharp wide open and easy to focus and very simple to hyper focus in f/8 due to convenient orange markings you can align on the focusing ring and aperture ring.
Bokeh can be busy but usually only with complicated backgrounds due to the 5 aperture blades but that just forces me consider my compositions a little more carefully. Also, there can be a fair amount of CA but Lightroom can easily deal with those. The K series 30mm f/2.8 has a personal magic batters down any shortcomings.
It's rarity also gives it a special allure as well. If you can find one in good condition it is a real treat to use.
| | | | New Member Registered: September, 2014 Posts: 1 | Review Date: September 30, 2014 | Recommended | Price: $300.00
| Rating: 10 |
Pros: | sharpness, bokeh, colour rendition | Cons: | none | Sharpness: 10
Aberrations: 10
Bokeh: 10
Handling: 10
Value: 9
Camera Used: K30, Super A
| | Superb lens. | | |
