Author: | | Senior Member Registered: June, 2020 Location: Guangdong Posts: 173 | Review Date: August 28, 2023 | Recommended | Price: $30.00
| Rating: 9 |
Pros: | fantastic handling as other K lenses, easy to focus, bokeh | Cons: | warm yellow tint | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 9
Camera Used: ME F
| | I bought this to replace my A 50mm/1.7 because it has a stiffy aperture ring and can't be used on my ME F.
Just as I expected, the K 55mm/1.8 feels superb! Fantatstic handling and nice bokeh.
Compared to 50mm, the 55mm is a bit easier to focus.
One con I concerned is my copy tends to present a warm yellow tint to the image. Below is a comparison between A 50mm/1.7 and this lens (shot with K-50, AWB).
A 50 >>
K 55 >>
some shots of K 55mm/1.8 with my ME F, Ilford Pan 100 | | | | | New Member Registered: September, 2020 Location: Derbyshire Posts: 3 | Review Date: August 23, 2021 | Recommended | Price: $30.00
| Rating: 10 |
Pros: | Easy to handle, minimum distortion, very well built, sharper than the M 50mm 1.7 | Cons: | None that I can think off TBH. | Sharpness: 10
Aberrations: 9
Bokeh: 7
Handling: 9
Value: 9
Camera Used: KX
| | I had one of these on my first KX, using film of course and not digital.
It was more than big enough to fit on that beast. It cost me 30 quid in the early 2000s.
Focussing on my copy was lovely - smooth and damped and easy. Very well built.
The light gathering potential of the glass certainly helped on the KX focusing screen.
Bokeh - as ever with the Pentax lenses, they weren't big on aperture leaves , so bokeh could be wiry.
But even wide open, this 1.8 lens was sharper than the follow-on M50mm 1.7, and also gave great colour with out filters. In mixed lighting, exposure was also very balanced - you can see this to extremes in other lenses, but not this one. The contrast is very controlled and can render subtle changes in light reflectance and colour gradation very evenly. I cannot remember seeing any evidence of distortion.
This lens had a good way of seeing what the human eye saw in my view. And there was a 'crispness' to the image too that was rather special.
It is a pity that if they are suffering the balsam separation problems discussed below.
If you can get a nice one without that problem, go for it I say.
Recommended.
| | | | Pentaxian Registered: February, 2011 Location: Southern Finland Posts: 681 1 user found this helpful | Review Date: April 18, 2021 | Recommended | Price: $25.00
| Rating: 9 |
Pros: | Sharp, focus throw good for manual use, focal length good for portraits in APS-C | Cons: | a bit soft wide open | Sharpness: 10
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
Camera Used: K-5, K-1
| | I got my copy of 1,8/55 a few years ago 2nd hand at a very low price. Not in mint condition (e.g. the focus scale indicator is loose, rotating almost freely, but luckily the focusing itself works ok) but optically without visible problems. I did not use this much with APS-C bodies, as I am not very keen on manual focusing. But interestingly, with K-1 this seems to be a lot more fun. The optics of this lens is good and the lens renders a film era kind of nostalgy in the photos. Focus throw is long enough to make manual focusing rather easy, compared to e.g. M and A 50 mm lenses.
| | | | New Member Registered: October, 2020 Location: Leiden Posts: 8 | Review Date: November 1, 2020 | Recommended
| Rating: 10 |
Pros: | image/build quality | Cons: | nothing i can think of | Sharpness: 9
Handling: 10
Camera Used: K5
| | The Pentax engineers did a great job making those old lenses work on a modern dslr. The only thing that's a pity is that the aperture value is not written to the exif info, but i can imagine that would be a little bit difficult without any electronic contacts on the lens.
If you have a pentax dslr and you can get this lens, take it, it will be worth your while.
See also all the comments from the other reviewers in this section. | | | | | Forum Member Registered: December, 2009 Posts: 94 3 users found this helpful | Review Date: October 23, 2020 | Recommended | Price: $45.00
| Rating: 10 |
Pros: | something special | Cons: | | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
Camera Used: K-1
| | This lens is special to me, something in the rendering, or contrast, i can't really pinpoint it.
My copy is mint and flawless. Handling is incredible. | | | | New Member Registered: February, 2019 Posts: 15 | Review Date: February 9, 2020 | Not Recommended
| Rating: 8 |
Pros: | Fells nice, looks superb | Cons: | Images no better than M series 50mm f1.7 | Sharpness: 8
Aberrations: 8
Bokeh: 8
Handling: 9
Value: 8
Camera Used: Various
| | Getting old now - by 2020 - so you may find distortion and haze in that connected rear element. The K series lenses often have glued-together rear glass elements. These gradually break down and apart over the years. It's called "balsam separation" and some people confuse it with "fungus" in these lenses. Sadly, it cannot be cleaned up and it will soft focus your images. Better to get an M Series 50mm f1.7 and - if you like plastic lenses - the A Series equivalent.
Because my previously owned two f1.8 lenses had this rear element separation issue, I will never touch one of these again. Glue has an age-mechanic limitation that means if the same glue is used in all lenses, it'll all start to go to a cloudy mess in all of these lenses.
Otherwise a really nice lens with real and accurate looking sharpish quality pictures. Who cares if you don't get a "digital age" sharpness at f1.8? Do you take that many photos at f1.8? What most people who say such things never explain is if their lens has filth and muck around the edges of the glass. Strip, clean that off, and the wide-open f1.8 image is not that bad at all.
| | | | New Member Registered: June, 2018 Posts: 2 | Review Date: September 26, 2019 | Recommended | Price: $40.00
| Rating: 10 |
Pros: | Well built, sharp, good contrast, good bokeh | Cons: | Some aberrations at bright apertures | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
Camera Used: MX, X-T3
| | I liked this lens when I had it. Wide open sharpness is only OK, contrast is low, and there's spherical aberration. This makes for a vintage look that some really like and it even draws some vintage-looking bokeh. Once it's stopped down to f/4 it's very sharp across the frame, rather impressive. The contrast and center sharpness don't ever match that of the Pentax-M 50mm f/1.7 though. Build quality and handling is excellent as it usually is with the 1st gen K lenses. All in all an excellent lens.
| | | | Loyal Site Supporter Registered: June, 2013 Location: Utrecht Posts: 250 5 users found this helpful | Review Date: August 8, 2019 | Recommended | Price: $20.00
| Rating: 10 |
Pros: | Build quality, equal sharp over the frame, no aberations | Cons: | Bit less micro contrast compared with M1.7 & M1.4 | Sharpness: 9
Aberrations: 10
Bokeh: 9
Handling: 10
Value: 10
Camera Used: K2 to K1ii
| | Very good performer from corner to corner. Wide open it is a bit soft. You only need to boost levels/contrast a bit in post for brilliant pictures. Long throw for focusing, it goes very precise. Build to last forever.
I got this as kit lens together with my 2nd hand K2 20 years ago. For both I paid € 75,-.
See also https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/390869-som...-compared.html
Original test report 1975 | | | | New Member Registered: April, 2019 Location: Dublin Posts: 4 2 users found this helpful | Review Date: April 19, 2019 | Recommended | Price: $35.00
| Rating: 10 |
Pros: | Very impressive quality for portraits, easy to focus, relatively cheap. | Cons: | n/a | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
| | Have got it just couple of months ago specifically for my new Fuji X-E3. Main purpose was to shoot portraits as I had previous experience with other ~50mm Pentax lenses and love them a lot. Can't really choose which ones I love more: Helios 44-2, Konica AR 50mm f/1.7 or my Pentax lenses (Pentax-M and Pentax-A 50mm f/1.7 and the latest one, Pentax SMC 55mm f/1.8). They all are great, easy to disassemble and clean, and unique in their own way.
Never tried any scientific tests as don't care about 'razor sharpness' - it is not important for my shooting requirements or preferences. I do care more about how easy to focus, handling and of course - my personal impression regarding imaging quality.
Here I have one photo as an example. May be someone will find it useful in the same way I found many reviews on this website. Thanks everyone for sharing their experience!
Day light, wide opened - f/1.8, camera Fuji X-E3, ACROS film simulation. No further postprocessing. | | | | Site Supporter Registered: February, 2017 Posts: 1,990 1 user found this helpful | Review Date: January 17, 2019 | Recommended
| Rating: 9 |
Pros: | Overall general performance. K build quality and colour | Cons: | None unless you want more automation | Sharpness: 9
Aberrations: 9
Bokeh: 8
Handling: 8
Value: 8
Camera Used: K3, several film bodies
| | This is my first K lens. It came packaged with a KX film camera. On film cameras it behaves as all standard lenses should - sharp, good contrast. light and good for many uses. I also prefer the slightly longer FL on film over the more normal 50mm.
Where I find this lens excels though is on my K3. Provided you nail focus (not so easy as the viewfinder screen is not as good as on an old film body), you will get all the sharpness and contrast you need...... but the colours! Ooooh they are gorgeous! The build quality and handling is second to none, provided you do not mind the lack of automation.
This lens has ended up costing me quite a bit of money as it has encouraged me to acquire more K glass - 50mm f4 macro, 135mm f2.5 - and the construction and handling (and those colours) across the K range is there on these lenses too. I am thinking about the K 30mm f2.8 now for my collection!
Highly recommended for both film and digital
| | | | New Member Registered: August, 2018 Posts: 13 1 user found this helpful | Review Date: November 23, 2018 | Recommended | Price: $30.00
| Rating: 10 |
Pros: | Color rendition, flare resistance, quite fast, pleasant bokeh when fully open, sharp, little chromatic aberration, mechanica quality | Cons: | requires stop-down metering, or fully open on automatic | Sharpness: 9
Aberrations: 10
Bokeh: 10
Handling: 8
Value: 10
Camera Used: Pentax KP
| | I have been using this lens for many years now, first on my LX, now on digital. It is quite heavy, but I love the look and feel of old glass. The colors are beautiful to me, and even fully open I am very fond of the rendition. I do not mind it is not tack sharp fully open, I am not expecting this. But when stopped down it gets very sharp, sharp enough for my needs at least . The bokeh is old school, so not really blurry, the number of diafragm blades is only six after all and they are straight.
The lens is built like a tank and has an unusually long focus throw, which can be advantageous for accurate close focusing. Or annoying when you want to go from close focus to infinity or vice versa . But focusing is still smooth after all these years.
I don't know current prices, but at the time it was an absolute bargain.
Picture taken fully open against the sunlight. | | | | New Member Registered: June, 2017 Posts: 2 1 user found this helpful | Review Date: November 24, 2017 | Recommended
| Rating: 10 |
Pros: | | Cons: | | Sharpness: 10
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
Camera Used: PENTAX K-3 II
| | ND16
Exposure Time 1/60
ISO Equivalent 800 https://flic.kr/p/2h4YrjN
ND16
Exposure Time 1/160
ISO Equivalent 400 https://flic.kr/p/2h4XExN
Exposure Time 1/5000s (0.0002)
ISO Equivalent 100
White Balance Auto
| | | | New Member Registered: January, 2014 Posts: 15 2 users found this helpful | Review Date: September 12, 2017 | Recommended
| Rating: 7 |
Pros: | | Cons: | | Sharpness: 7
Aberrations: 5
Bokeh: 5
Handling: 8
Value: 8
Camera Used: K-5
| | Nice build and pretty sharp too when you nail the focus. | | | | Junior Member Registered: December, 2009 Posts: 25 3 users found this helpful | Review Date: June 2, 2017 | Recommended
| Rating: 10 |
Pros: | excellent colors, fast, looks, built | Cons: | none | Sharpness: 9
Aberrations: 9
Bokeh: 8
Handling: 9
Value: 10
| | Just received one today. Portraits at f1.8-f2.8 are awesome. Colors of sky and flowers are superb. This lens is a bargain.
On K-50
f1.8
f 1.8 - 1/160 - ISO100 +2EV
SOOC JPG NO PP
© foivosloxias June 2017
f 2.8 - 1/250 - ISO100
SOOC JPG NO PP
f 1.8 - 1/200 - ISO1000
SOOC JPG NO PP
© foivosloxias August 2017
[f 1.8 - 1/60 - ISO1000]
[f 1.8 - 1/50 - ISO1000]
[f 2.8 - 1/80 - ISO400]
© foivosloxias August 2017 | | | | Senior Member Registered: September, 2013 Posts: 283 2 users found this helpful | Review Date: November 17, 2016 | Recommended | Price: $75.00
| Rating: 9 |
Pros: | colors are beautiful, well built, lovely bokeh | Cons: | I haven't had good luck with skin tones in portraits, could be my editing | Sharpness: 9
Aberrations: 8
Bokeh: 9
Handling: 10
Value: 8
Camera Used: K-3
| | My favorite lens for flowers or colorful still lifes. Love the rendering. Smooth focusing and sturdy build. As of now I prefer it over the A 50 1.4, but I've spent more time with the K 55 1.8. IMGP0622 by Brady Burmeister, on Flickr IMGP1936 by Brady Burmeister, on Flickr IMGP2070 by Brady Burmeister, on Flickr
