Author: | | New Member Registered: August, 2012 Posts: 26 1 user found this helpful | Review Date: February 24, 2024 | Recommended | Price: $20.00
| Rating: 10 |
Pros: | Sharp with excellent three dimensional rendering | Cons: | Colour cast in AWB, easily corrected in post processing | Sharpness: 10
Aberrations: 10
Bokeh: 7
Handling: 9
Value: 10
Camera Used: K3
| | I absolutely love this lens. I was looking for a 28mm prime and the local camera shop had one going cheap. I use it mainly for landscapes. Images have a wonderful 3 dimensional quality to them. | | | | | Site Supporter Registered: July, 2020 Posts: 131 1 user found this helpful | Review Date: December 4, 2023 | Recommended | Price: $25.00
| Rating: 9 |
Pros: | Low CA, M series rendering | Cons: | Sometimes strong colour cast when using auto WB | Sharpness: 8
Aberrations: 9
Bokeh: 6
Handling: 8
Value: 9
Camera Used: K-S2, K200D
| | There's a lot of choice for vintage 28mm primes even if you stick to Pentax.
I found samples on this forum to my taste and for the cost thought this was worth a whirl.
Build quality is typcial M series and it is a pleasure to use.
I really like the rendering, output is quite recognisable.and gives a fine sense of depth or dimension.
I think somebody else mentioned that they like it for B&W, I concur.
I find it usable wide-open, that cannot be said for some of the 2.8s it competes with and I do not find the slightly slower aperture a hindrance to focussing.
CA is largely absent but I have found using it in evening light can throw a camera's auto WB (I've seen the similar with the M 100mm), obviously correctable in PP.
If I didn't have the Pentacon 30mm I'd probably use this far more. I wouldn't pack them in the same camera bag but feel that this lens offers something different enough to keep and use when the mood take me. Again I really like this type of focal length for APS-C as a wideish normal.
| | | | New Member Registered: August, 2019 Posts: 1 1 user found this helpful | Review Date: June 14, 2023 | Recommended
| Rating: 10 |
Pros: | sharpness, handing, colours | Cons: | | Sharpness: 10
Aberrations: 9
Bokeh: 8
Handling: 10
Value: 10
Camera Used: K1
enjoy my work: https://radesky.photo/portfolio/ | | | | New Member Registered: April, 2022 Posts: 9 2 users found this helpful | Review Date: April 19, 2022 | Recommended | Price: $60.00
| Rating: 9 |
Pros: | Sharp, compact | Cons: | Vignetting | Sharpness: 10
Aberrations: 7
Bokeh: 7
Handling: 10
Value: 10
Camera Used: K1, K3 iii
| | First, the biggest drawback of the lens: vignetting. In less than ideally lit situations (ie, most natural light shots I take), the lens vignettes noticeably until F8. That's fine, since one of the benefits of this lens is depth of field. Relative lack of bokeh could be considered a downside, but it is a wide-angle lens, so that cannot count as a weakness to me. Aberrations are also noticeable, but it is an M series lens, so it is expected.
The lens works very well with both the K1 and K3 iii. With FF, it is a nice perspective lens for landscapes, and distortion is acceptable for my purposes. With APS, the lens does a creditable job of being a quasi-macro lens, and an excellent job when reverse mounted.
Given price, age, and design, this lens works at least as well as one might expect.
Sample photos below. I will note that post-processing is used in three of the four linked images, but sharpness adjustments are minimal. (Contrast and saturation are often more in need of boosting.) The reverse mounted shot is unaltered.
K1: https://www.flickr.com/photos/119228821@N02/51708128981/in/album-72177720297460470/ https://www.flickr.com/photos/119228821@N02/51713563814/in/album-72177720297460470/
K3 iii: https://www.flickr.com/photos/119228821@N02/51597528408/in/album-72177720297460470/ https://www.flickr.com/photos/119228821@N02/51498172238/in/album-72177720297460470/ | | | | | Site Supporter Registered: February, 2017 Posts: 2,034 2 users found this helpful | Review Date: April 20, 2021 | Recommended
| Rating: 9 |
Pros: | Price, size, weight | Cons: | Manual exposure only (unless you have a K3 iii | Sharpness: 9
Aberrations: 7
Bokeh: 8
Handling: 7
Value: 9
Camera Used: K3, KP
| | Being something of a fan of the 40-45mm FOV on film/FF, I have a thing for 28mm lenses on my KP and K3 cameras, and I will be reviewing this lens with that in mind.
I paid £45 for my copy, though optically perfect has a slight focusing error - it seems to randomly skip when approaching infinity, something my 20mm f4 also does, so it may be a design flaw with the M series. This fault does not effect image quality, but can be disconcerting if not used to it. I would cheerfully pay a few quid more for the fault not to be present.
Handling is something of a mixed bag. If you do not mind using MF and manual exposure (I don't), it makes a nice compact companion for you smaller Pentax bodies (compared to say the K 28mm f3.5 which makes them nose heavy), and needless to say work just as well on the larger ones. Some might miss the lack of AF or automated exposure, though I believe the K3 iii will offer the latter to those lucky enough to obtain one. All 2 of the controls, focusing (apart from the aforementioned fault in my copy) and aperture work just fine. Care must be taken when using the viewfinder for focusing as it is easy to miss on standard screens. I have a microprism collar screen installed in my K3 and it makes the task so much more reliable. Any softness of images I believe are largely due to focus errors and flare. This lens is design for 35mm film and as a wide angle and as such much more susceptible to flare than a lens designed for crop. I recommend the use of a standard len lens hood to mitigate against flare. I prefer this slower f3.5 model on my unmodified KP over my A 2.8 model as it is easier to get precise exposure with the slower lens.
Once the focus and flare issues are sorted out I find the image quality to be very good indeed. Perfectly usable wide open and soon sharpens up once stopped down a little. It is not quite as good as my K 28mm f3.5 but not far off and on the smaller bodied cameras much nicer to carry around. The one noticeable flaw is CA's. Well I say noticeable, but that depends on how you view your pictures. CA's are there at every aperture, worse wide open still noticeable when stopped down. BUT only if you are pixel peeping. When images are viewed in their entirety at normal viewing distances there is no issue at any aperture. Basically you have to look for CA's to find them, but find them you will if you look. Bokeh? Who cares for what this lens is designed or likely to be used as. Images are typically Pentax in terms of colour rendering and vibrance. No cause for any complaints at all. B&W images seem particularly pleasing with this lens and I would say marginally better than those taken with my K f3.5.
I was lucky to find a copy this cheaply at the present time. They seem to be quite rare on the Evil Bay at the moment and the few copies available are relatively pricey. I think this is due to lack of trading activity caused by the pandemic response so hopefully once things return to normal prices and availability will improve. I think highly enough of this lens to want to track a mechanically better copy down. I especially rate it for B&W.
As the owner of the following Pentax 28 and 30mm lenses I would rate them in the following order, but please bear in mind some of this is based on my subjective opinion and others may prefer the convenience of AF and auto exposure when considering which lens to chose:-
K 28mm f3.5
F 28mm f2.8
K 30mm f2.8
A 28mm f2.8
M 28mm f3.5
M 38mm f2.8
I would point out in terms of IQ, the differences between the lenses can be quite marginal. Optically this little lens is no slouch. Find one in decent condition at a reasonable price and I would recommend you pick one up. I think it worth having just for B&W images as it has such a unique look my other lenses lack.
| | | | Pentaxian Registered: February, 2011 Location: Southern Finland Posts: 681 | Review Date: April 18, 2021 | Recommended
| Rating: 9 |
Pros: | Sharpness, compactness, M-series build | Cons: | F3,5 only | Sharpness: 9
Aberrations: 8
Bokeh: 8
Handling: 10
Value: 10
Camera Used: K200D, K-5, K-1
| | A very sharp and compact all-round wide angle which I used to like very much back in the film era. With APS-C format bodies I did not use this much, but lately I found out that the optics is still quite okay for digital full format use (K-1). Lack of digital era coatings decreases the value a bit, though. Very capable for macro work also, especially with a reverse ring or attaching this reversed to another (e.g. 50 mm, 100 mm or 135 mm) manual lens.
| | | | New Member Registered: February, 2019 Posts: 15 1 user found this helpful | Review Date: October 25, 2020 | Recommended
| Rating: N/A |
Pros: | Pretty much the same as the 2.8 version | Cons: | Over-rated and over-priced | Sharpness: 8
Aberrations: 7
Bokeh: 7
Handling: 8
Value: 6
| | I don't sharpen and edit images in software and then conveniently forget that when writing reviews of a lens.
For such an old lens, $30-40 would seem to be a fair 2020 price for a neat and tidy mini lens that gives good central sharpness at f5.6 to f16. Not so impressive at infinity, but not horrible at all; just a little bit like many other 1970/80's wide angle lenses. Overall performance is pretty much exactly the same as a Pentax M f2.8 28mm. The hyperfocal range of focus printed on the lens barrel is way off as it does not focus across what it states in print. It can be difficult to get to focus every time.
The lens is always a little bit too blurry at the edges, but many 28mm and 35mm lenses of it's age are like this from many manufacturers. People using this lens on a crop sensor may not see this, but I do when using film and full frame gear. So maybe this lens form Pentax is no worse than lots of others?
As with all wide angle tiny glass lenses of the 1980's and 1990's this is dreadful to open up and clean out if you buy an old poorly kept version. Check it with whoever you buy from and make sure they have shone an LED torch through the glass to pick up any haze or dust or fungal strands; especially if you are going to pay daft money for what will be a very old lens.
Overall? Good, often very good, rarely excellent. But tends to be reliable. If you only take photos up to 20 yards away and you need a wide angle, this could be the one for you. If you like landscape or townscapes then this may be all right and even good.
| | | | Unoriginal Poster Registered: November, 2016 Location: Espoo Posts: 3,182 1 user found this helpful | Review Date: September 1, 2020 | Recommended
| Rating: N/A |
Pros: | | Cons: | | Sharpness: 8
Aberrations: 8
Bokeh: 7
Handling: 9
Value: 8
| | Overall this is pretty similar lens as 28/2.8 and both are equally cheap. Many rank this one better, but I honestly can’t find any sigficant advantage over f2.8. This small and well build wide angle that is pleasure to use. Short hyperfocal distance and weak bokeh make this optimal to use when you want all sharp. Lens is sharp enough, but not quite in the level of the fifties.
Good value for the money, but I prefer the faster 28, thought its advantages are visible only in special cases. Most of the time these give equal results.
APSC SIC album: https://www.flickr.com/photos/154414256@N06/albums/72157693911019240
FF SIC album: https://www.flickr.com/photos/154414256@N06/albums/72157710643768551 | | | | Junior Member Registered: June, 2013 Posts: 37 2 users found this helpful | Review Date: February 14, 2020 | Recommended | Price: $50.00
| Rating: 9 |
Pros: | Sharpness, price | Cons: | None | Sharpness: 9
Aberrations: 8
Bokeh: 8
Handling: 10
Value: 10
Camera Used: K-1ii
| | For a $50 lens, this is a smooth operator. Recommended to me by my local camera store as shaper than the f2.8 version, I choose it over the 35mm-FAf2.8 version which had very plasticky aperture clicks.
Focus ring is impressively smooth, and the sharpness on first try outdoors in very diffuse light was above par. | | | | Site Supporter Registered: November, 2017 Posts: 756 1 user found this helpful | Review Date: October 13, 2019 | Recommended | Price: $15.00
| Rating: 9 |
Pros: | Color reproduction, weight, size | Cons: | Not many... | Sharpness: 8
Aberrations: 9
Bokeh: 9
Handling: 9
Value: 10
Camera Used: K-3
| | I decided to try this out with a 20mm Spiratone extension tube today, as well as taking some general shots. With extremely mild editing, both macro and non-macro photos turned out beautifully. I am especially impressed with the color reproduction of this lens, requiring very little adjustment (if at all) out of camera to equal what I observed with the naked eye. Highly recommend, especially since you can get it relatively inexpensively. | | | | New Member Registered: July, 2019 Posts: 8 2 users found this helpful | Review Date: August 21, 2019 | Recommended | Price: $61.00
| Rating: 10 |
Pros: | like all of the M series small size. | Cons: | None really when factoring size & cost to performance | Sharpness: 7
Aberrations: 7
Bokeh: 7
Handling: 10
Value: 10
Camera Used: Nikon Z6 & Pentax Me Super
| | You can't go wrong with this lens. Its stupidly cheap, small and gives you results far in excess of what you have a right to expect from such a price point. Is it up to today's super sharp behemoths? Of course not, but, if you want a super small lens that you can throw in your bag and have on hand in the off chance you need wide - this is it. The colour 'pop' is awesome. This is a seriously good lens. Its not sharp at all in the corners, but that is part of its allure I think, the general 'feel' of the photos made by this lens are very pleasing to my eye. | | | | New Member Registered: July, 2016 Location: Toronto Posts: 3 | Review Date: March 22, 2019 | Recommended | Price: $60.00
| Rating: 9 |
Pros: | build quality, handling, size, weight, sharp | Cons: | none | Sharpness: 9
Aberrations: 8
Bokeh: 7
Handling: 10
Value: 10
| | It's a awesome lens. very tiny and the image quality you can pull out from is amazing. I have used this tiny beauty on APS-C format and the equivalent field of view is 42.5 mm in 35mm format. It's sharper than its 2.8 sister and the overall image quality is superior compare to the 2.8 one. Keeping your eye on ebay you can find a mint condition for a little money. Highly recommended.
| | | | Pentaxian Registered: April, 2007 Location: Toronto/Victoria Posts: 460 | Review Date: February 6, 2019 | Recommended | Price: $30.00
| Rating: 9 |
Pros: | Compact and reasonably good IQ | Cons: | Manual lens | Sharpness: 8
Aberrations: 9
Bokeh: 8
Handling: 8
Value: 9
Camera Used: K-1, K100D
| | This is a very good normal lens on APS-C - it is as good or better than the A28/2.8 and A28/2.0 other than functionality and maximum aperture.
On the K-1, it is also better than those two lenses which suffer from softer corners and quite a bit of green/magenta CA. It's not as good as the K28/3.5, but it gets fairly close; it also has the same less obtrusive red/blue CA. It's also a very small lens.
I use it for video on my K-1, and it does a very good job.
| | | | New Member Registered: September, 2018 Location: Nottingham Posts: 10 1 user found this helpful | Review Date: January 29, 2019 | Recommended | Price: $30.00
| Rating: 8 |
Pros: | Light, lovely retro look and feel | Cons: | noticed noise in poor light | Sharpness: 10
Aberrations: 8
Bokeh: 6
Handling: 10
Value: 10
Camera Used: Sony A6000
| | I bought the lens as part of a bundle at a charity shop, so the $30 (20GBP) is an estimate
The lens has been used on a Sony A6000, all images shot in RAW and edited in Rawtherapee and GIMP.
I think I have a mint copy, well cared for (came with a little leather pouch lens holder) and was complete with skylight filters.
The lens is light and looks beautiful, looks fabulous on my camera, very retro.
The aperture clicks feel good and the focus ring is smooth.
I've shot landscapes, street shots and even some portraits and I am very pleased with the results.
In good light the lens has created some superb crisp, vibrant, colourful and sharp images.
In poor light I have noticed noise at ISO's where I would not expect noise with my Sony.
I would have given a 9/10 , but for the noise at low light (maybe I am too picky)
It's a keeper for sure Council House Autumn Colours by Phil Howcroft, on Flickr The old sweet shop by Phil Howcroft, on Flickr Arnold Town's Number 1 Fan by Phil Howcroft, on Flickr
| | | | Veteran Member Registered: March, 2013 Location: Yukon Posts: 516 | Review Date: November 9, 2018 | Recommended | Price: $75.00
| Rating: 9 |
Pros: | Sharpness, size, weight | Cons: | None that come to mind | Sharpness: 9
Aberrations: 8
Bokeh: 7
Handling: 9
Value: 9
Camera Used: K-5II, K-1
| | Surprisingly, now that I have a K-1 I am using this lens often. Surprisingly because I also have the K28/3.5. But the full frame body is so much heavier that I decided to take this one out a little more often. Fully satisfied with the results. Build and handling is typical M, which is to say excellent.
