Author: | | Pentaxian Registered: January, 2012 Location: Tokyo Posts: 2,821 3 users found this helpful | Review Date: July 16, 2023 | Recommended | Price: $400.00
| Rating: 7 |
Pros: | Build quality, built-in hood, generally good image quality, close focusing ability | Cons: | Screw-on lens cap, soft image quality at the edges | Sharpness: 6
Aberrations: 8
Bokeh: 7
Autofocus: 8
Handling: 8
Value: 9
New or Used: New
Camera Used: K-5 IIs, K-01, K-3 III
| | I think of all the Limited lenses I own, this is the one I get along with least. A lot of that is subjective, because I'm just not skilled at making good compositions with ultra wide angles, but I think there are some objective reasons as well.
As with all of the Limited lenses, this one has a nice compact design. I don't hesitate to bring out with me in case I see the opportunity to take a wide shot. The integrated slide-out lens hood is convenient, but then all that convenience is tossed aside by the fiddly nature of the screw-in lens cap. This takes so much more time and hand coordination than a pull-off or pinch lens cap that it actually dissuades me from using the lens sometimes.
One other thing that stops me from using this lens is that I have a GR III and a DA10-17 FE, so there is some competition that I often find more practical or fun to use.
I also find that this lens has a bit of a magenta tint to the images. This is not difficult to fix, but I just have to treat images taken with it a bit differently to other Pentax lenses, both newer and older. I wish I'd got the SMC version to keep a consistent look with the other SMC limiteds. I wonder if this is a characteristic of the earliest "HD" lenses, because I have newer HD lenses that don't seem to do the same thing.
However, there are a lot of good things about this lens too. The close-up ability is impressive. I have taken some images I really like (mainly landscape) when I can get the composition right. Also, it takes me out of my comfort zone, looking for reflections and foreground items to create interest. | | | | | Senior Member Registered: February, 2021 Posts: 119 3 users found this helpful | Review Date: December 10, 2022 | Recommended | Price: $250.00
| Rating: 8 |
Pros: | Compact, center sharpness, close focusing | Cons: | Built in Hood Dings easily, soft corners wide open | Sharpness: 8
Aberrations: 10
Bokeh: 7
Autofocus: 8
Handling: 8
Value: 9
New or Used: Used
Camera Used: KP
| | An awesome 21mm FF equivalent on APS-C, I paired mine with the KP, and it was the first Pentax Da Limited piece of glass I ever bought. Personally it made for a great compact landscape lens in a small package with a small front element that's typically not found in wider aperture lenses of the same focal length. My only complaint is the built in hood, is very susceptible to being dented and scratched when I was hiking with it, and typically the corners were very soft at wide open at F5.6 & below. I was able to throw this in my flight bag as a traveling A/C mechanic at my old job, with the 55-300PLM, 18-135, and 40 Limited to make an awesome compact all around travel kit. | | | | Site Supporter Registered: June, 2017 Location: 3City agglomeration Posts: 2,056 6 users found this helpful | Review Date: December 27, 2021 | Recommended | Price: $760.00
| Rating: 10 |
Pros: | Size, build quality, unique IQ | Cons: | I cannot think of any :D | | This is a little gem. It very clear, with great dynamic range and contrast. It has also very nice field curvature and aberrations that add to image "soul" and cannot be treated as lens faults.
It may be used as walk around lens if you put some though into photos. I use it mainly for city photography - old buildings and such and as UWA it works more then perfectly giving great detail and clearness of what is important.
It just needs attention when using in city or tighter environments.
With minimal focusing distance being as short as it is it makes also nice lens for flower photography when you need to capture larger scene.
The only issue I can think about is screw on lens cap (I already lost mine), but still find it better then push on like on 20-40.
Some images with this lens: | | | | Site Supporter Registered: April, 2021 Location: Arlon, Belgium Posts: 100 | Review Date: May 16, 2021 | Recommended | Price: $300.00
| Rating: 8 |
Pros: | very sharp | Cons: | auto-focus bug | Sharpness: 9
Aberrations: 8
Bokeh: 6
Autofocus: 6
Handling: 9
Value: 6
New or Used: Used
Camera Used: K3II
| | I love this lens, but i bought it too late because i didn't have it yet when i was in New Zealand , and i really needed it for those fabulous landscapes and montains , i regret it so much !!!
| | | | | Pentaxian Registered: May, 2015 Posts: 3,306 2 users found this helpful | Review Date: June 2, 2020 | Recommended | Price: $619.00
| Rating: 7 |
Pros: | size, rendering, flare resistance | Cons: | unsharp edges regardless of stopping down | Sharpness: 6
Aberrations: 8
Bokeh: 8
Autofocus: 8
Handling: 10
Value: 7
New or Used: New
Camera Used: K-5 and K-3 II
| | A really great compact lens for reportage and environmental portraits. It's incredible contrasty and delivers punchy images. The tiny size makes it effortless to bring along. Close up photographs of objects render really well with great depth.
The lens works best when the subject is in the central part of the frame and the edges are there for context only. For many this will be the primary use case for a wide angle lens.
The main weakness of the lens is the soft mushy edges that stay mushy as you stop down. This makes the lens less suitable for descriptive architecture shots and landscape images where there is detail and interest across the frame.
I have given an average sharpness score because it is razor sharp in the center but soft at the edges.
| | | | Senior Member Registered: February, 2015 Posts: 175 7 users found this helpful | Review Date: November 18, 2019 | Recommended | Price: $450.00
| Rating: 10 |
Pros: | outstanding contrast and rendering, small size, useful focal length | Cons: | field curvature | Sharpness: 8
Aberrations: 10
Bokeh: 8
Autofocus: 8
Handling: 10
Value: 10
New or Used: New
Camera Used: K3
| | This lens has an outstanding contrast, colour rendition and dynamic range.
It delivers very pleasant pictures, which need very little post processing, even in high contrast scenes or difficult light.
It is very resistant to flare and shows very little distorsion fo such a wide field of view (15mm is 22.5mm FF equivalent).
Due to field curvature, it is not a lens for those looking for corner to corner sharpness: the focused target will be tack sharp, even at f4 and close to a corner, but keep in mind that if your target is a distant landscape, the focus will be further away in the center and closer to the photographer in the corners.The only way to mitigate this is to close the aperture around f8.
Yet, in real life, this may not matter because your subject may often include a closer foreground near the border of the frame, or you will appreciate the main target on which you have focused to pop out in kind of a 3D effect.
It is my favorite landscape lens.
Here is a lanscape in Arequipa, Peru: IMGP6272.jpg by Denis Bousquet, sur Flickr
Another sample in Angkor area, Cambodia: Le grand bassin du Neak Pean by Denis Bousquet, sur Flickr
This one was in Corsica, at sunset: IMGP4754.jpg by Denis Bousquet, sur Flickr
| | | | Senior Member Registered: March, 2010 Location: Svealand Posts: 172 | Review Date: May 18, 2019 | Recommended | Price: $417.00
| Rating: 10 |
Pros: | rendering, small, build quality, built in hood, short focussing distance, quick-shift, | Cons: | No starbursts | Sharpness: 9
Bokeh: 7
Autofocus: 10
Handling: 10
Value: 10
New or Used: New
Camera Used: Pentax K-5
| | I earlier owned a DA 15mm Limited but I sold it. Missed it a lot but could not find one to by so I went for the HD Pentax-DA 15mm instead. It's a great lens that I strongly recommend but I do miss the starburst that the old 15mm had.
| | | | Veteran Member Registered: December, 2013 Posts: 796 5 users found this helpful | Review Date: June 15, 2018 | Recommended | Price: $430.00
| Rating: 9 |
Pros: | Small, sharp | Cons: | No starbursts, filter thread behind retracted hood | Sharpness: 9
Aberrations: 9
Bokeh: 7
Autofocus: 9
Handling: 7
Value: 8
New or Used: Used
Camera Used: KP, K-30
| | This is an excelent wide angle lens, sharp and well corrected. The main advantage is it always fits in my bag. Perfectly complements the FA31, FA43, FA77 set or the DA18-135. I have only two problems with the lens. The first is the filter thread which is behind the retracted hood, so I can't use step up rings or a conventional lens cap. The other is the speed of the lens. F4 is slower than F2.8 on the DA*16-50 or F3.5 on the DA16-85. Altough the distorsion of the DA*16-50 is much worse than the distorsion of DA15 Ltd. I think the sharpness is good from corner to corner, but I think I never used the lens wide open after the testshots (there is the Da*16-50 for dark situations).
Sometimes I miss the sturbursts, which I see with the older not HD version.
Here are some examples: IMG171104_0007 by Benjámin Czétényi, on Flickr IMG171229_0002 by Benjámin Czétényi, on Flickr IMG171229_0004 by Benjámin Czétényi, on Flickr IMG180331_0065 by Benjámin Czétényi, on Flickr
| | | | New Member Registered: January, 2018 Posts: 1 3 users found this helpful | Review Date: June 6, 2018 | Recommended
| Rating: 10 |
Pros: | colors, distortion | Cons: | difficult to mount a cokin filter(vigneting | Handling: 10
New or Used: Used
Camera Used: k5iis
| | Sorry for my bad englisch. I've got the Sigma 10-20 and I find it good, but it takes a lot of space and I found a HD 15 limited for sale. It's always on my camera and I have much less post production work to do. It's amazing. The only problem was when I tried to mount a Cokin filter to shoot landscape: The adaptor is impossible to fix because of the lens hood. So I had to screw another neutral filter and I got dark extrem corners. This lens is as good as written in the other reviews, but be aware of the problem of fixation system for filters.
| | | | Junior Member Registered: July, 2016 Location: Alps Posts: 35 1 user found this helpful | Review Date: April 29, 2018 | Recommended | Price: $465.00
| Rating: 8 |
Pros: | limited handling, rendition | Cons: | corners/borders not sharp, screw cap | Sharpness: 7
Aberrations: 7
Bokeh: 8
Autofocus: 9
Handling: 10
Value: 8
New or Used: Used
Camera Used: K-3 II
| | Awesome handling and great overall rendition, colors and contrast.
IQ is great in the center, not that much in corners/borders - understandable for a small and lightweight ultra wide.
Screw cap use is not that great - not a major issue.
Good lens that does not control my mind as some others | | | | Senior Member Registered: February, 2018 Location: Hérouville Saint Clair, Normandy, France Posts: 143 1 user found this helpful | Review Date: February 15, 2018 | Recommended | Price: $549.00
| Rating: 9 |
Pros: | Compact, sharp, light, well built | Cons: | Not WR | Sharpness: 10
Aberrations: 9
Bokeh: 7
Autofocus: 10
Handling: 10
Value: 9
New or Used: New
Camera Used: KP
| | Almost perfect.
| | | | Veteran Member Registered: November, 2014 Location: Newfoundland Posts: 501 1 user found this helpful | Review Date: December 30, 2017 | Recommended | Price: $550.00
| Rating: 10 |
Pros: | Size, Weight, Build Quality, Smooth Manual Focus, Rendering, Perspective, Razor Sharp when stopped down. | Cons: | None | Sharpness: 10
Aberrations: 10
Bokeh: 7
Autofocus: 10
Handling: 10
Value: 10
New or Used: New
Camera Used: K-5II
A beautiful piece of finely crafted glass, the HD DA 15 completed my set of Limited's. It's priced very well compared to the DA 14 which is huge and heavy. I'm still learning to employ this lens for optimum effect but can say it is an absolute joy to shoot with. The HD DA 15 handy for large group photos too!
| | | | Veteran Member Registered: April, 2014 Location: Cambridge, MA Posts: 935 10 users found this helpful | Review Date: November 2, 2016 | Recommended | Price: $550.00
| Rating: 10 |
Pros: | Sharpness, flare resistance, small size | Cons: | Maximum aperture f/4 | Sharpness: 9
Aberrations: 10
Bokeh: 9
Autofocus: 10
Handling: 10
Value: 10
New or Used: New
Camera Used: K-3
| | What they say in the lens club is true-- the 15mm Limited CONTROLS MY MIND!!! Seriously. I've checked the stats on my photos, and half of the keepers, and half of my best-ever shots, were taken with the 15mm Limited.
It's sharp. It's not as sharp as my 14mm Rokinon, but that thing is giant and heavy, with a delicate front element, and doesn't have autofocus to boot. But don't get me wrong, the 15mm Limited is definitely still awesome sharp. I generally use it between f/7 and f/11.
The 15mm Limited is ridiculously flare-resistant. When it comes to lens flare, the 15mm is the Honey Badger. Shooting a wide-angle shot directly into the sun? The 15mm don't care. It doesn't give a . The 14mm Rokinon on the other hand, will give you all this blobby green lens flare, so you have to be super careful with it.
The 15mm Limited itself is tiny-- just a wee bit too big to be called a pancake-- and the lens cap screws on. This is brilliant. It is the perfect lens for scrambling around on rocks because its small size and low weight don't cause the camera to jerk around, and you KNOW the lens cap isn't going to fall off. With my 14mm Rokinon, I have to secure the camera to my back with multiple caribiners to keep it from flopping around, and even then, I'm nervous.
Why would you buy the 14mm Rokinon instead? If you want to do astrophotography (maximum aperture f/2.8 instead of f/4), if you value sharpness above all else, if you want a lens you'll definitely be able to use on full-frame, and if you really don't mind going through multiple copies to find one that isn't decentered. Otherwise, get the 15mm Limited. You won't be disappointed.
And here's another.
And another.
And another.
Did I ever mention that this lens controls my mind? | | | | Junior Member Registered: May, 2013 Posts: 47 2 users found this helpful | Review Date: September 13, 2016 | Recommended | Price: $399.00
| Rating: 10 |
Pros: | Beautiful colours, contrast, sharpness also lightweight | Cons: | none I can think of | Sharpness: 9
Aberrations: 9
Bokeh: 9
Autofocus: 9
Handling: 10
Value: 10
New or Used: New
Camera Used: k 30
| | First of all, its a beautiful piece of equipment. Well made, lightweight aluminium material. Very small size so light weight to carry when on trails. The filter size is small as well, so filters are cheap.
Optically, lens is sharp. The contrast is better than DA 12-24 out of camera. Colours are true and bright.
The only drawback if any is that its a prime. So you have to take steps backward or forward while shooting landscapes, which may not be always possible. Plus you will not get to change the perspective.
But overall its a great lens if you want lightweight well made lens capable of producing best quality images, and you can play within the constraints of a prime lens. | | | | Pentaxian Registered: May, 2016 Posts: 3,724 2 users found this helpful | Review Date: May 31, 2016 | Recommended | Price: $400.00
| Rating: 10 |
Pros: | image quality, small, build quality, built-in lens hood | Cons: | coma, screw-in cap | Sharpness: 9
Aberrations: 7
Bokeh: 9
Autofocus: 10
Handling: 10
Value: 10
New or Used: New
Camera Used: K-3 II
| | With such a wide angle, it can be used for street photo without the viewfinder, at most you'll need to crop the result a little. As with other limited primes, the build quality, colors and contrast are great! I find sharpness to be perfectly fine, but I guess the edges are a little softer than the center wide open. I don't know what to think about the cap... it feels nice and I use it, but I wish it was push-in like on the 70mm.
edit: updated the aberrations rating to account for the coma it shows at max aperture. Does it matter? No, not really, I only noticed after starting to use it indoors and at night. Anything less than f/4 reduces the issue almost entirely so I am not changing the overall rating.
