P-TTL Test Images
Flash Modes
Below we compare the following flash modes:
- Slow sync (row 1)
- High speed sync (rows 2 to 6) (The A-lens test was done with another scene than F/FA)
- Standard sync in M exposure mode (row 7)
- Standard sync in P exposure mode (row 8)
- Trailing curtain sync in P exposure mode (row 9)
Setup:
- Pentax K-3
- Unprocessed JPGs (except for scaling)
- Autofocus with center focus point
- smc Pentax-A, -F, and -FA 50mm F1.4 lenses
- AF 360 FGZ II flash mounted on camera
- Direct flash, zoom head at 48 mm matching the lenses
Click any thumbnail to start browsing larger images.
| FA50 | F50 | A50 |
1 | FA50-Av=slow=dir=ctr=vf 0.7sec F5.6 ISO 200 | F50-Av=slow=dir=ctr=vf 1/6sec F2.8 ISO 200 | A50-Av=slow=dir=ctr=vf 1/180sec F2.8 ISO 200 |
2 | FA50-M=hss=dir=ctr=vf=F028=s0250 1/250sec F2.8 ISO 400 | F50-M=hss=dir=ctr=vf=F028=s0250 1/250sec F2.8 ISO 400 | |
3 | FA50-M=hss=dir=ctr=vf=F028=s0500 1/500sec F2.8 ISO 400 | F50-M=hss=dir=ctr=vf=F028=s0500 1/500sec F2.8 ISO 400 | |
4 | FA50-M=hss=dir=ctr=vf=F028=s1000 1/1000sec F2.8 ISO 400 | F50-M=hss=dir=ctr=vf=F028=s1000 1/1000sec F2.8 ISO 400 | |
5 | FA50-M=hss=dir=ctr=vf=F028=s2000 1/2000sec F2.8 ISO 400 | F50-M=hss=dir=ctr=vf=F028=s2000 1/2000sec F2.8 ISO 400 | |
6 | | | A50-M=hss=dir=ctr=vf=F056=s1500 1/1500sec F5.6 ISO 100 |
7 | FA50-M=std=dir=ctr=vf=F028=s0180 1/180sec F2.8 ISO 400 | F50-M=std=dir=ctr=vf=F028=s0180 1/180sec F2.8 ISO 400 | A50-M=std=dir=ctr=vf=F028=s0180 1/180sec F2.8 ISO 400 |
8 | FA50-P=std=dir=ctr=vf 1/90sec F5.6 ISO 200 | F50-P=std=dir=ctr=vf 1/90sec F6.7 ISO 200 | A50-P=std=dir=ctr=vf 1/125sec F2.8 ISO 200 |
9 | FA50-P=trail=dir=ctr=vf 1sec F6.7 ISO 200 | F50-P=trail=dir=ctr=vf 1sec F6.7 ISO 200 | A50-P=trail=dir=ctr=vf 1/6sec F2.8 ISO 200 |
Observations:
- F and FA lenses perform virtually identical
- F and FA images slightly underexposed
- The A lens tends towards overexposure with a (very) few blown highlights
- Flash zoom must be set manually with A-series lenses
- HSS provides darker results as the shutter speed increases
