Login Register
Forgot your login?
Pentax Exclusives
Lens Review Database
Complete with all Pentax Lenses ever made, photos, technical data and THOUSANDS of reviews
Read More Find your perfect Lens
Pentax Marketplace
The largest & safest Pentax-dedicated classifieds on the web - buy rare gear or sell an item today!
Read More Visit the Marketplace
Pentax Deals
Pentax 50mm Prime Lens Shootout
Review Navigation:
Design and Handling
Now, let us take a look at the build quality and handling of each lens.
Pentax DA 50mm F1.8
The Pentax DA 50mm F1.8 lens was introduced in 2012. It is designed for digital cameras, and as such not meant be used on film cameras because it does not cover the full-frame image circle. The DA 50mm field of view is like a 75mm on a film camera, because the APC-S sensor is 1.5x times smaller than a 35mm image. The DA 50mm is constructed with a plastic composite shell and mount.
Pentax DA 50mm F1.8Pentax DA 50mm F1.8
The focus ring is located at the front of the lens and it requires 1/2 of a turn from the minimum focus distance of 18.9 inches to infinity. The focus ring is a little over 1/4 of an inch wide and does turn when you utilize the cameras slotted screw drive. The lens, unlike most DA lenses, does not allow Quick-Shift Focusing. The focus ring, when utilized manually, is a little noisy and not very smooth.
The lens is very light weight, and is quick and responsive when used with the K-5’s autofocus. The filter diameter is 52mm, which is different from the other two 50mm in this review.
Pentax DA 50mm F1.8 at minimum focus
Pentax DA 50mm F1.8
Pentax DA 50mm F1.8 focused at infinity
Pentax DA 50mm F1.8
Pentax FA 50mm F1.4
The Pentax FA 50mm F1.4 lens was introduced in 1991. It can be used on both digital cameras and full frame cameras. When used with an APC-S sensor, the field of view will be like a 75mm on a film camera. The field of view will increase to 47 degrees diagonally or 50mm when used on a full frame camera. The Pentax FA 50mm is constructed with a plastic composite shell and a metal mount. The lens is almost twice as heavy as the DA 50mm F1.8.
The focus ring is located at the front of the lens and it requires a little less than 1/2 of a turn from the minimum focus distance of 18 inches to infinity. The focus ring is 3/16 of an inch wide and covered with soft rubber and does turn when you utilize the cameras slotted screw drive. At the back of the lens is a manual aperture ring. Once the ring has been moved off the “A” setting, it is possible to turn the aperture ring. The lens does not have Quick-Shift Focusing.
Pentax FA 50mm F1.4 at minimum focus
Pentax FA 50mm F1.4
Pentax FA 50mm F1.4 focused at infinity
Pentax FA 50mm F1.4
The lens has a small sealed window in the middle of the lens that displays the distance in feet and meters. Above is a picture of the sealed window. The lens takes 49mm filters. The front of the lens protrudes a little more than ½ inch when focusing at the minimum focus distance as you can see from the pictures above.
Pentax D FA 50mm F2.8 Macro
The Pentax D FA 50mm F2.8 Macro lens was introduced in 2009. It is designed for both digital cameras and full frame cameras. When used with an APS-C sensor, the field of view will be like a 75mm on a film camera. The field of view will increase to 47 degrees diagonally or 50mm when used on a full frame camera. The Pentax D FA 50mm F2.8 Macro is constructed with a plastic composite shell and a metal mount. The lens is the heaviest of the three lenses reviewed, at 9.3 oz.
The focus ring is located at the front of the lens and it requires a more than ¾ of a turn from the minimum focus distance of 7.7 inches (20 cm) to infinity. The focus ring is 3/4 of an inch wide and covered with soft rubber and does not turn when you utilize the cameras slotted screw drive. At the back of the lens is a manual aperture ring. Once the ring has been moved off the “A” setting, it is possible to turn the aperture ring. The lens has Quick-Shift Focusing, which permits you to manually focus the lens at any time.
Pentax D FA 50mm F2.8 Macro at minimum focus
At minimum focus distance the magnification is 1:1 (life size) hence the long extension compared to the other two lenses.
Pentax D FA 50mm F2.8 Macro focused at infinity
The lens has a small sealed window at the middle of the lens that displays the distance in feet and meters and the magnification of the lens. Above is a picture of the sealed window. The lens takes 49mm filters. The front of the lens protrudes a little more than 1 ¾ inch when focusing at the minimum focus distance as you can see from the pictures above. On the side of the lens is a clamp switch that allows you to lock the manual focus position.  Since the lens is designed as a macro you can use the Pentax AF160 ring light kit in conjunction with the lens.
Pentax D FA 50mm F2.8 Macro clampPentax D FA 50mm F2.8 Macro with ringlight
Below is the lens with the lens hood installed.
Pentax D FA 50mm F2.8 Macro with hood
Buy the DA
