Login Register
Forgot your login?
Pentax Exclusives
Are you a Camera Enthusiast?
Or do you shoot with more than just Pentax? We've opened a new site for you!
Read More Visit Camera Enthusiast!
Donate to PentaxForums
Hundreds of hours are spent on site improvements and maintenance every month. Did you know that PentaxForums.com is kept online thanks to user donations?
Read More Learn More
Pentax Deals
Pentax K-01 Camera Review
Review Navigation:
New Features
The K-01 comes with a refined version of the same firmware that's found in the Pentax K-r DSLR: the menus look very similar and the button layout remains largely unchanged, but many options have been added or improved, and the design has been modernized.  Some options from the K-5 have also been carried over, but others have been excluded.  A few settings have been added specifically to accommodate the K-01's mirrorless design. There are also a few similarities between it and the Q, namely in the way information is displayed in live view, and in the AF system. On this page, we present what's new compared to current Pentax DSLRs. Overall, the K-01's interface resembles that of the K-r very closely.
somemenu
External Features
Two key button additions are the red button, which by default starts video recording regardless of shooting mode (but can be customized to alternatively control file formatting, image preview, focus peaking, custom image, or digital filters), and an HDR setting on the mode dial.  The in-camera HDR has been improved since the K-5 and can now be used hand-held, to an extent.
trafficlight
In order to save power, the screen automatically dims itself after 10 seconds.  This is new to the K-01 as well.
Another welcome addition is a built-in stereo microphone (naturally with support for external microphones as well).  Both the K-5 and K-r only have mono microphones.
mics
Performance
The K-01 has a new and improved processor called PRIME M.  It greatly improves overall camera performance: images are shown faster and can be cycled through faster in playback mode, the instant preview comes up after a shorter delay, and in-camera processing seems to have sped up as well compared to the K-5 and K-r.  Most importantly, however, the new processor delivers a much smoother live view experience than in Pentax DSLRs: there is practically no latency at all unless you're shooting in low light.
The K-01's contrast detect AF system has also been improved over that found in Pentax DSLR live view modes.  We elaborate on this later in the review.
Pentax Prime M Processor
Record Menu
Pentax added the focus peaking feature, which we discuss in more detail on our autofocus page. Another addition is a "radiant" preset to the custom image (JPEG profile) system.
recmenu1
Settings Menu
A few settings have been added to this menu due to the fact that this is a mirrorless camera. The "flicker reduction" setting, which can be set to 50 or 60Hz, allows you to minimize flickering electrical light sources on the screen based on where you live. You can now also control the hue and color balance of the live view image, rather than just screen brightness. A third new setting here is a power-saving option, which essentially auto-dims the LCD after 10 seconds of inactivity.
Two utility options have also been added: you can now check the firmware version and update firmware straight from the menu (as on the Q), and choose to perform dust removal at shutdown rather than only at startup. The shutdown option might come in handy if you're concerned about the noise the system makes.
firmware
Movie Mode
Movie mode has perhaps seen the most significant changes. You can now control shutter speed, aperture, and sensitivity before and while recording (see screenshot at top of page). New framerates have been added, and a movie-specific info screen has been added. The K-01 also boasts a stereo microphone.
Custom Functions
A power-saving SR option has been added, allowing you to choose full-time shake reduction, or to only have the system activate just before shooting. There is also a new AF mode setting, which essentially lets you fire the shutter before focus is locked, similar to how AF.C works on a DSLR. Pentax calls this "release priority", though this term is somewhat misleading, as on DSLRs it actually changes the behavior of continuous shooting. The K-01 doesn't have continuous shooting as such.
Info Screen
The info screen now let's you control aspect ratio, even if the resulting resolutions aren't among the standard presets. An interesting new feature is automatic shadow/highlight correction, meaning that the K-01 can adjust very bright/dark areas should it detect that it's become necessary. Interestingly, an option to turn off the LCD entirely has also been added (press the info button twice).
infoscreen2
Image Playback
Playback mode now features faster image loading and practically instantaneous scrolling. There is a new 81-thumbnail display option, as well as a 36- and 4-thumbnail display.
81 thumbnails
Missing or Removed Features
Even though the K-01 isn't meant to be as advanced as the K-5, we expected to see a few features which turned out to be left out. The K-01 has no electronic level, and thus also no horizon correction feature, which we think would otherwise come in handy in auto pict mode. Bracketing is limited to just 3 frames and cannot be invoked via the remote or self-timer.  The remote can also not be used in bulb mode. The shutter only features a top speed of 1/4000s, which is a little bit behind that of the K-r. Also, while the K-01 does have TAv mode, Sv mode has been left out. Finally, only DNG RAW is supported: you cannot choose to shoot in the PEF format. This isn't really a problem as PEF files for a typical scene are about 50% larger than the losslessly compressed DNG files.  Regarding RAW files, it should be noted that the K-01's bit depth is 12 bits, whereas the K-5's was 14.  The K-01 only has an IR remote sensor in the front (not on both sides), and it doesn't support tethering at the moment.
Finally, the O-GPS1 unit's astrotracer feature is not yet fully supported.  Pentax says that an upcoming firmware update will address this.
Buy the Pentax K-01
