Login Register
Forgot your login?
Pentax Exclusives
Are you a Camera Enthusiast?
Or do you shoot with more than just Pentax? We've opened a new site for you!
Read More Visit Camera Enthusiast!
Donate to PentaxForums
Hundreds of hours are spent on site improvements and maintenance every month. Did you know that PentaxForums.com is kept online thanks to user donations?
Read More Learn More
Pentax Deals
Pentax Q Review
Review Navigation:
Field of View Comparison
The images below were taken from the same vantage point and illustrates the range of field of view which is covered by the Q lenses. The images are JPGs straight out of the camera except for reduction in size. Lens distortion correction was set to on (the default value).
Field of View - Prime Lenses
The prime lenses cover a good and useful range. The wide angle lens disappoints with its pronounced barrel distortion whereas the telephoto lens, although marketed as a toy lens, performs well. The standard prime has some distortion but that is corrected to perfection by the camera's distortion correction function when shooting JPG (the distortion correction does not work on RAW files). Click on a thumbnail to view an image in a larger size (900 x 600).
03 Fish-eye 04 Wide
03 Fish-eye Lens (3.2mm) 04 Toy Lens Wide (6.3mm)
01 Standard Prime 05 Telephoto
01 Standard Prime (8.5mm) 05 Toy Lens Telephoto (18mm)
Field of View - Zoom Lens
The 02 Standard Zoom covers a range corresponding to a 28 - 85mm lens in the 24x36mm format, and 18 to 55mm in the APS-C format. In other words this zoom covers a very popular and useful range. The lens exhibits some distortion but that is corrected perfectly by the camera's distortion correction function when shooting JPG (the distortion correction does not work on RAW files). Click on a thumbnail to view an image in a larger size (900 x 600).
02 Standard Zoom at 5mm 02 Standard Zoom 6 mm
02 Standard Zoom at 5mm 02 Standard Zoom at 6mm
7 mm 8 mm
02 Standard Zoom at 7mm 02 Standard Zoom at 8mm
10 mm 02 Standard Zoom at 15mm
02 Standard Zoom at 10mm 02 Standard Zoom at 15mm
Buy the Pentax Q Review and Olympus Micro Four Thirds E-PL3 Comparison
