05-04-2010, 06:08 AM   #1
TheTenaciousOne's Avatar
Anyone use a protective filer for their DA15mm?
Hi,
Ive recently bought me a DA15mm and am wondering if anyone here uses a protective filter on it?
I usually dont use one on my other lenses but theyre a DA40mm which doesnt really need one thanks to the unique hood and some cheap M lenses where im not too worried about a little knockage. Being a fairly expensive lens, having a decent amount of exposed glass and being used at close distances all worry me but im not sure if im ready to trade off the amazing optical quality of it.
So opinions please =)
Chris
05-04-2010, 07:20 AM   #2
Hi, I think if you use a very good filter (not the cheap ones) it shouldn't compromise the optical quality all that much. In fact, you'd be hard pressed to notice any difference at all even at 100% magnification. However, there are situations where the light gets so complicated you might find a difference. On 90% of occasions, you should be just fine.
05-04-2010, 07:32 AM   #3
Clinton's Avatar
I was bummed that sigma doesn't make their EX DG multi-coated filters in the 49mm you need for this lens, so I picked up the Hoya HMC 49mm multi-coated UV filter for it and it seems to work well.
05-04-2010, 09:37 AM   #4
pacerr's Avatar
Using an old filter with the glass removed offers some protection from physical contact with the front element without the potential image degradation of a filter in front of the lens. Depending on the lens, there may or may not be slight vignetting.
H2
im, k-mount, lenses, pentax lens, slr lens
Protective Filters - Needed or Not Pentastic Troubleshooting and Beginner Help 26 12-06-2009 09:36 PM
K-7 dust between LCD and protective cover minator Pentax DSLR Discussion 4 09-08-2009 01:46 PM
Whether to use a UV protective filter? rdrum76 Pentax SLR Lens Discussion 13 11-03-2008 06:21 AM
Do you use a Protective Filter? mwcfire Pentax Camera and Field Accessories 13 03-05-2008 12:50 AM
Recommendation: Protective Cover for K10D rear LCD wil_war@comcast.net Pentax DSLR Discussion 18 11-16-2007 08:46 AM
All times are GMT -7. The time now is 02:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
