05-04-2010, 06:33 AM   #1
benjikan's Avatar
Pentax 70 Ltd Problem Yikes
I was doing another shoot for VOGUE on the 21 April. I was using my Ltd 70mm lens, which I have only used on a few occasions. What happens? Around the front element a piece of double sided tape starts to appear around the periphery ring, I take off my filter and the periphery ring that holds the element is loose. As I turn it to tighten it, more tape starts to appear. it is very narrow around 1/16th to 1/8th of an inch wide. The tape is very very sticky. I try to clean the lens and it gets worse. The tape leaves a residue on the front element that I cannot remove.
It gets even worse, as I cannot remove the residue with 90 alcohol. Don't want to use acetone. I finally give up.
Well I sent it off to Pentax and being that they now use a third party repair service I will have to pay a shit load..This is a first. Anyone experience this problem?
05-04-2010, 06:58 AM   #2
Blue's Avatar
Is that how they attached the band on those things?
05-04-2010, 11:32 AM   #3
benjikan's Avatar
No idea, but it is being repaired. That lens is sooooooo sharp and I need it for my beauty stuff.
05-04-2010, 05:49 PM   #4
Digitalis's Avatar
If you have a friend that has one, borrow his FA77. At f/2.8 and up, no one will be able to tell the difference...
05-04-2010, 06:44 PM   #5
wlachan's Avatar
Duct tape is great for removing sticky stuffs. Gaffer tape will do too. Too late though for you.
05-04-2010, 06:51 PM   #6
Voe
Voe's Avatar
Benjikan, may be it's a sign that finally you have to get that FA 77mm Limited. From my experience having both lenses for a while, the 77mm is sharper and it also has it's magic.
Don't want to sound pushy, but I strongly suggest you buy that FA 77mm Limited.
Cheers,
Voe
05-04-2010, 11:55 PM   #7
Laurentiu Cristofor's Avatar
Scary stuff. I heard stories about front elements falling off certain lenses. But sticky tapes are a first. Good luck with the repairs!
element, front, k-mount, lens, ltd, pentax, pentax lens, periphery, residue, slr lens, tape
My first wedding EVER!!! Yikes!!!! creoleart Post Your Photos! 19 09-07-2009 07:59 AM
LX part - YIKES! ChrisPlatt Pentax Camera and Field Accessories 3 08-09-2008 08:10 PM
1989...Yikes benjikan Photographic Technique 6 07-07-2008 09:29 AM
yikes how long is my lens ? simons-photography Pentax SLR Lens Discussion 17 03-24-2008 03:55 AM
Yikes! James- did you see this??? Tom Lusk Pentax SLR Lens Discussion 3 12-18-2006 09:55 PM
All times are GMT -7. The time now is 11:37 AM. | See also: NikonForums.com, part of our network of photo forums!
