Hello all,
If you own this lens would mind checking & letting me know if you have the same play in the zoom ring. I've searched, and didn't find this question. One similar, but the play was fore & aft. Nor does anyone in my area carry it.
My warranty is about to expire on my DA* 50-135mm and I'm noticing some play up & down in the focus ring. As I recently received it back when having the K20D body serviced they also "adjusted manual focus" on this lens. I don't think it had this play prior, but not sure and my biggest concern is if the weather sealing been compromised, of course along with worn parts.
It's a bit fussy to notice and describe so I attached the below drawing for clarity. I have enough play that a 'tick' can be heard when moving it up/down.
Thank you in advance for your help,
Roger
