Originally posted by Parallax One advantage of lens based IS, is that the image in the viewfinder is stabilized.
You need to develop this concept a little further, because you are only touching the benefit of lens based OS over the sensor based IS
If the viewfinder image is stabalized, then you also get a stabalized image at the AF sensor. while this might seem trivial, but consider the following.
You are taking a shot of a fox at a distance in a field. vertical motion in you holding the lens may cause you to focus incorrectly on the grass in front of the fox. WHile the image may be stabalized and sharp it is focused on the wrong point. Optical stabilization may help this.
ALso consider metering, specifically spot metering. Optical stabilization keeps the image in the view finder stable, therefore it keeps the metering points looking at what you are looking at.
They may opr may not help you but OS will perform better in these areas as well.
IS only resolves camera shake because it is the sensor moving
