05-08-2010, 07:51 AM   #1
Can it be fixed?
I bumped by 16-45 mm lens, with hood attached, against my desk. One of the 4 plastic nubbins on the lens that hold the sunshade/hood on is now chipped away slightly. So the shade rests loosely on the lens. Can this be fixed?
(I now use a rubber screw-on shade that I actually like better, but I may want to sell the lens some day. )
05-08-2010, 07:59 AM   #2
imtheguy's Avatar
KEH occasionally lists the hood for sale much less than the outrageous price from Pentax for a new one. I ended up getting my hood from the PF Marketplace in response to a WANTED ad. Good luck with the fix....that is the only quick/cheap way.
05-08-2010, 08:21 AM   #3
In my case it's the lens itself that had the mishap, and which I hope to be able to fix.
However, I agree on the ridiculous cost of a hood. And once it's on, there's not way to attach the lens cap! With the inexpensive rubber hoods, you can put the cap on, and they offer far better protection than the "snazzy" looking plastic shades.
05-08-2010, 08:32 AM   #4
dgaies's Avatar
If you saved the "plastic nubbin" that broke off then you might be able to fix it. Same sort of thing happened to me once and I was able to super glue the chipped piece back on without an issue. So long as you're careful and get a good bond, it should as good as new. Certainly worth a shot if you still have the piece.
QuoteOriginally posted by tmacdon Quote
05-08-2010, 09:57 AM   #5
imtheguy's Avatar
Certainly can't hurt to try and glue it back but as you said, only to help with future resale. I used the rubber hoods and also bought a screw-on hard petal hood that I dremeled/filed until there was no vignetting at 16mm. But I added the original hood just for possible resale....someday. The modified hard petal hood looks a little cooler than the rubber but of course does not store reversed. If you can't repair your lens you are welcome to the 67mm screw-on petal hood I made for free.
k-mount, lens, pentax lens, shade, slr lens
Can this A50mm/1.2 still be fixed? shoebox Pentax SLR Lens Discussion 13 02-28-2010 11:45 AM
fixed 10mm insulinguy Pentax SLR Lens Discussion 7 09-24-2009 09:38 PM
Fixed the 18-55. Volvo244T Pentax SLR Lens Discussion 7 09-20-2009 05:27 PM
New Glass 28 mm fixed devs66 Post Your Photos! 6 06-23-2008 03:49 PM
Fixed K100D leaton Pentax DSLR Discussion 0 11-27-2007 03:33 PM
All times are GMT -7. The time now is 12:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
