Ok! here are the center and corner (Lower Left LL, Upper Left UL, Upper right UR, Lower right LR) 100% crops.
I ABSOLUTELY AND POSITIVELY HATED THE WHOLE EXPERIENCE
I haven't even looked at the results, and will do so I as I post.
METHOD: Lenses on a tripod with the target as perpendicular as possible, used a remote with 3 sec. timer. Av mode. Used LV under highest magnification to focus.
I will post the comparison with the 31mm limited in this reply and the 43 in the next and the 77 in the last.
The top image is from the FA*28-70 and the bottom image from the FA limiteds. I will mention the f-stop and the crop above each image.
31mm f2.8 center
31mm f2.8 LL
31mm f2.8 UL
31mm f2.8 UR
31mm f2.8 LR
31mm f4 center
31mm f4 LL
31mm f4 UL
31mm F4 UR
31mm F4 LR
31mm f5.6 Center
31mm f5.6 LL
Ok I am done with this, it is too tedious......It looks like the zoom is sharper. The 31 limited overexposes, so the bright image makes it look a little softer, but still the zoom is sharper.
