Originally posted by dadipentak I have a 1000mm lens and 1.4x, 1.7x & 2x TCs and there are
still things that are out of reach!
Save your money & get close.
even when you stack them all together, the moon is still 250,000 miles away
But you do raise a point
Image size = subject size x focal length / distance
getting closer is the best approach and also the cheapest,
When you consider some of the shots I posted/linked earlier, all but the whooping crane (big white bird) are full frame shots, where I was close enough to fill the entire sensor, or almost do so, with the subject (in each case the whole bird). The whooping crane is an exception, it is 10% of the area cropped out of my K10D somewhat proving your point that things can be out of reach regardless of focal length attached.
