05-15-2010, 07:24 AM   #16
Ben_Edict's Avatar
With a string, there is no way to support the (perhaps heavy) lens while you are waiting for...the "shot".
If I understand the thread opener correctly, we are not talking about heavy lenses at all. Ofcourse the string pod will not add support for the weight, but it is an easy means to reduce camera shake and steady the camera. And its biggest advantage is, you can have it with you all the times in your pocket, even when travelling lightly.
Ben
05-15-2010, 08:01 AM   #17
Jewelltrail's Avatar
jholstein: BTW, my daughter takes a screw tied to a string with a big washer at the end, screws it into the tripod mount, stands on the washer and pulls the string tight for steady shots. She uses a point and shoot so I don't know how well it would work with a DSLR. But a cheap and easy to carry option!
Yes, I sometimes use the string when hiking long distance--it is effective, obviously not as much as a tri-pod, but effective.
cameras, k-mount, k-x, lens, macro, pentax, pentax lens, slr, slr lens, telephoto, trip
Help with deciding on a second lens! NathanSanch Troubleshooting and Beginner Help 31 04-11-2010 06:36 PM
Gear advice for Alaska trip Unruely Travel, Events, and Groups 2 01-12-2010 12:17 PM
Help deciding best effect... shiestmiester Post Your Photos! 6 07-13-2009 06:06 AM
need some help deciding catsman50 Pentax SLR Lens Discussion 1 06-22-2009 07:59 AM
Alaska Trip palmor Pentax SLR Lens Discussion 0 05-22-2007 03:20 PM
All times are GMT -7. The time now is 05:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
