05-12-2010, 09:41 PM   #16
yeatzee's Avatar
QuoteOriginally posted by gofour3 Quote
Because of the location of the optical nodes in the K28/3.5, it is one of the best lenses available for reversing, examples:
Reversed will give you 1.9:1 magnification.
Reversed with Auto Extension Tube #1 will give you 2.32:1 magnification.
Reversed with Auto Extension Tube #2 will give you 2.56:1 magnification.
Reversed with Auto Extension Tube #3 will give you 2.81:1 magnification.
Reversed with Auto Extension Tube #1+2+3 will give you 3.90:1 magnification.
Reversed with Bellows K extension at 32mm will give you 3.02:1 magnification.
Reversed with Bellows K extension at 137mm will give you 6.72:1 magnification.
For the last listing the film plane to subject distance is 280.5mm.
Phil.
And wouldn't you know, i've been searching for this lense Thanks for the info!
Yeatzee, when you get into the greater than 1:1 realm, consider a tripod and focusing rail. That allows the actually moving of the camera for focusing. One of the first dedicated piece of macro equipment I bought was a focusing rail.
I've thought about it, but I still can't wrap my head around the idea of a tripod and focusing rail being useful in the photography of living creatures which I shoot exclusively.
05-12-2010, 09:46 PM   #17
Blue's Avatar
QuoteOriginally posted by yeatzee Quote
It takes some getting used to, but as magnification goes up, that arena is smaller. You have to think like a praying mantis an plan to ambush those flies. If they are going to a certain flower, mushroom or carrion, set up there and wait. Its a skill that has to be developed with practice.
Edit: I've been watching this for a few years. He has gotten relatively famous for his macro work.
Flickr: Thomas Shahan's Photostream
here's his setup:
Macrophotography Setup on Flickr - Photo Sharing!
05-12-2010, 10:03 PM   #18
yeatzee's Avatar
Yeah, but he says he's only used that specific setup for like two images on his flickr. I messaged him, fingers crossed he responds as I'd love to know his current setup (thats over 2 years old isn't it?).
Anyways, this is the story of my life: As soon as im almost focused the dang insect runs away. Now imagine if I had a tripod? Without I can chase the insect down and hopefully get the shot. With, not so much
Story of my life on Flickr - Photo Sharing!
05-12-2010, 10:15 PM   #19
Blue's Avatar
Actually, a large number of his images were with that setup or a variation on it, tubes, bellows reversed lenses etc. Some times you have to look under the tag list to see the info.
Edit: The A* or FA* 200mm macro or Sigma 180mm macro would give you more working distance but you still would need tubes, etc to get the mag and the trouble then is those lenses are already, HUGE.
05-12-2010, 10:20 PM   #20
yeatzee's Avatar
I know that, I meant that setup as is without any switching or removing of parts
I am VERY intrigued by the prospect of a reversed 28mm however because of him though....
05-12-2010, 10:22 PM   #21
Blue's Avatar
I know that, I meant that setup as is without any switching or removing parts
o.k. He just uses different combination of tubes, lenses, reversed lenses etc on it.
A 28 reversed on a 50mm would get you at about 1.78:1
05-12-2010, 10:25 PM   #22
yeatzee's Avatar
How much mag. for just a 28mm reversed?
05-12-2010, 10:42 PM   #23
Blue's Avatar
It will depend on whether or not if its a symmetrical or asymmetrical. If it is asymmetrical
Magnification can be calculated by measuring the entrance opening and exit opening.
m = exit/entrance
You can measure that with a ruler.
05-12-2010, 10:53 PM - 1 Like   #24
Douglas_of_Sweden's Avatar
Well I finally found some flies today only to be sorely disappointed by the amount of shots taken.... a whopping ZERO. This was because 1:1 was not enough magnification that I needed so I strapped the M 50mm reversed on the sigma 105mm macro for tha extra "oomph." BUT, with this setup my working distance is less than an inch away from the from element! All my macro shots in the last month have been taken using this technique (see: https://www.pentaxforums.com/forums/post-your-photos/100783-macro-jumping-spider.html, https://www.pentaxforums.com/forums/post-your-photos/100408-macro-arm-killer.html, https://www.pentaxforums.com/forums/post-your-photos/100412-macro-praying-mantis-portrait.html,etc. etc.). I am very happy with the results, but the efficiency is not there. 98% of my macro shoots are filled with me not taking a single picture, but rather trying to get close enough to the subject without scaring it away. Eventually, I *usually* get the opportunity to take the shot but If I miss it I often have to wait another 10+ minutes to get another opportunity. Its killing me...
<b>
So, What can I do to get ~2:1 magnification, yet have a much longer working distance? Anything I can do with my current equipment (see signature)?
</b>
First I must say that you have indeed been posting some very impressive macros. But I understand you perfectly when you try to say that you look for higher standards even though you are not there yourself and might not ever get there. I'm like that myself. Backside is that you never are really happy with your own achievements, even when they are pretty good.
I'm currently using two combos that gives me > 1:1 in combination with good working distance.
SMC Pentax DFA 100mm macro with a 1.7x soligor converter. Gives me up to 1.7:1 with good working distance. That's an AF converter so autofocus still work, and contrary to what is often said about macro, I do find AF usefull now and when with moving subjects.
https://www.pentaxforums.com/forums/post-your-photos/101219-macro-spider-cow-lip.html
https://www.pentaxforums.com/forums/post-your-photos/100790-macro-not-jumping-spider.html
https://www.pentaxforums.com/forums/post-your-photos/72147-bug-hemiptera.html
https://www.pentaxforums.com/forums/post-your-photos/73315-butterfly-dfa100-m...converter.html
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/72369-howerfli...10-photos.html
Same lens but with an extension tube made from a Kenko 2x AF converter where I have removed the glass. From measuring it appears to give me up to 2:1, though I'm not sure how to calculate it:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/60715-dfa-100m...airy-legs.html
Also this combo gives me working autofocus. This home made converter even give me AF on SDM lenses.
Dissclaimer: I don't mean any of these shots are near the standards you aim at, but it is at least >1:1 with good working distance.
Besides these I've been experimenting with combos of reversed lenses (up to 20mm lens reversed on a 200mm giving macro 10:1), bellows etc, but nothing I'm prepared to post yet. And they don't give me much working distance.
05-12-2010, 11:09 PM   #25
Blue's Avatar
Douglas, I didn't know Soligor made an AF 1.7x teleconverter.
05-13-2010, 05:00 AM   #26
audiobomber's Avatar
Here's a good article on calculating macro magnifications. www.peterforsell.com
05-13-2010, 06:01 AM   #27
pcarfan's Avatar
If I remeber this right, a forum memeber who posted the most breathtaking set of macros I've evnr seen mentioned something about spraying cold water from a spray bottle to keep the subjects still. I guess that is something to consider.
05-13-2010, 06:21 AM   #28
Digitalis's Avatar
Pcarfan, I have used that technique a lot myself...I can personally vouch for it's effectiveness. though it can cause a bit of a problem with the reflections from the water on the subject. using a polariser on the flash head and one on the lens can help diminish that though.
05-13-2010, 06:22 AM   #29
pcarfan's Avatar
Edit: I've been watching this Hidden content may not be quoted for a few years. He has gotten relatively famous for his macro work.
here's his setup:
WOW! incredible work.....Thanks for posting it here.
05-13-2010, 06:24 AM   #30
Ira
Id still be interested to here the response though, so go for it Ira!
Not MINE! I'll post what others have done!
distance, k-mount, macro, magnification, opportunity, pentax lens, shots, slr lens
Dilemma: Pentax 70 pancake or Sigma 70 macro? WMBP Pentax SLR Lens Discussion 31 10-01-2009 03:36 PM
Dilemma.. SteveM Pentax SLR Lens Discussion 6 08-09-2009 12:13 AM
K-7 Dilemma lawsonstone Photographic Technique 14 05-16-2009 04:18 PM
Dilemma, dilemma ... Bronco Pentax DSLR Discussion 31 04-15-2008 05:39 PM
Macro LBA Dilemma - FA100 f/2.8 or DFA100 f/2.8? Bud Pentax SLR Lens Discussion 12 04-19-2007 11:40 AM
All times are GMT -7. The time now is 08:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
