If you get a bad cable from ebay Chinese sellers they all are very eager to work with you on sending a replacement.
I ordered 2 rcrv-3 batteries and 2 chargers from ebay.
The chargers gave out about 4.6 volts (instead of 4.2 volts) and the batteries were about 3.9 volts instead of 3 volts.
I sent a message to each of the sellers.
They promptly and without any charge sent out replacements without requesting me to send back the ones I got.
So I ended up with 4 batteries and 3 chargers. The k100d works fine with them, so far, so ...
With the cable, if u receive a bad one, you can ask, nicely for a replacement (as you don't believe in negative feedback) and they will always send one.
Once you have 2 bad cables
, you can hack one a make a good one. After all it is a very simple cable to make (about 5 wires inside and you just need to match the connections).
